Configuring connection credentials
- Edit the ldap.properties file.
- Configure the following properties.
- ldap.connectionName
- The user name that is used to authenticate to a read-only LDAP connection. If left not set, an anonymous connection is attempted. For example, administrator@mydomain.mycompany.com.
- ldap.connectionPassword
- The password that is used to establish a read-only LDAP connection. The password can be entered here in plain text or it can be encrypted.
- ldap.connectionPasswordEncrypted
- True
- The LDAP password is encrypted.
- False
- The LDAP password is not encrypted and entered as plain text.
Use the following method to generate the encrypted password.
In a Windows® system.
- Open a command prompt window and type
where installdir is the IBM® BigFix® Remote Control server installation directory For example,cd [installdir]\wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\ WEB-INF\libcd \Program Files\IBM\Tivoli\TRC\server\wlp\usr\servers\trcserver\ apps\TRCAPP.ear\trc.war\WEB-INF\lib - Type the following command
java -cp ./trc.jar com.ibm.uk.greenock.authentication.Encrypt <password>
Where password is the LDAP password to be encrypted
For example,
java -cp ./trc.jar com.ibm.uk.greenock.authentication.Encrypt myPassw0rd
Note: This command is all on one line with a space between jar and com. - The following output from the command can be displayed.
Encrypted Password : [encrypted password]
Decrypted Password : [text version of password ]
For example,
Encrypted Password: 10|ydEBl67atSSbrAA=
Decrypted Password: myPassw0rd
Edit the ldap.properties file and set the ldap.connectionPassword property to the encrypted password value. The decrypted password is shown to verify that the encryption is valid.
In a UNIX or Linux® system.
- Open a terminal window and type
where installdir is the IBM BigFix Remote Control server installation directory[installdir]/wlp/usr/servers/trcserver/apps/TRCAPP.ear/trc.war/ WEB-INF/lib - Type the following command
- The output from the command is the following
- ldap.connectionURL
- The directory URL used to establish an LDAP connection. Type in the URL of your LDAP server.
ldap://myldapserver.mydomain.mycompany.com
