Remove previous version
You can run the previous and current versions of both versions of Power Management simultaneously. However, the new version of Power Management uses different collection techniques. When you remove the old version, your historical data is not transferred.
Note: Remove the previous version of IBM Endpoint Manager
Power Management after the new version is installed.
