Disable previous Historical Tracking
The previous version of Endpoint Manager for Power Management used a user-defined scheduled task in Windows to run the Store Historical Power Data process. If you previously set up this task, you must disable it after you remove the older Power Management Fixlet site.
To disable previous historical tracking, remove the scheduled task for storing the power results utility. To do this, access the Windows Control Panel and select Scheduled Tasks. Delete the Store Historical Power Data task.
