BigFix® Remote Control Target for macOS toolbar
A floating toolbar is available for the BigFix® Remote Control Target for macOS. Various options are available in the toolbar. For example, to disconnect from a session, switch session mode, and send files to the controller.
During a remote control session, the toolbar opens and is displayed in front of other application windows. You can close or minimize the toolbar. When the session ends, the toolbar closes unless it was open before the session started. When you are not in a remote control session, you can open the toolbar by using the Open Remote Control Target option in the status menu or dock icon menu.
The toolbar contains the following options.
Disconnect
Click this option to disconnect from the session.
Session mode
Click and select a new session mode. The session mode list is blank when you are not in a remote control session.
Actions
The Actions menu contains the following options. For more information about the options, see BigFix Remote Control Target for macOS menu bar.
  • Connection info
  • Who is connected?
  • Transfer folder
  • Send file to controller
  • Enter connection code.
Help
The Help menu contains the following options. For more information about the options, see BigFix Remote Control Target for macOS menu bar.
  • About
  • Online help
