Creating Remote Control server installation tasks
With the Remote Control Server Installer Wizard, you can create an installation task to install a remote control server.
Run the task on a Windows™® system or Linux™ (Red Hat and SUSE) systems to install a fully functional, self-contained Remote Control server with either of the following component setups:
  • Remote Control server with WebSphere® Application Server Liberty Profile version 16.0.0.2 and a Derby version database.
  • Remote Control server with WebSphere® Application Server Liberty Profile version 16.0.0.2 and one of the following databases:
    • IBM DB2 11.5 Virtual Processor Core (VPC), IBM DB2 12.1.
    • Oracle 11g, 12c, and 19c.
      When you use an Oracle database, if you are using the Oracle 11g drivers, set oracle.increment.keys.off=1 in the trc.properties file. Restart the server service.
    • Microsoft SQL server 2016, 2017, 2019, 2022, and 2025.
      Remote Control Server does not support connections to Microsoft SQL Server named instances or clusters. To connect to a Microsoft SQL Server database, configure the database to use a static port.
      You must use a JDBC driver whose version is higher than or equal to 13.4. Older versions do not support TLS1.2 or JRE25.
      When you use an MS SQL database, Windows™ authentication is not supported. You cannot log on with a domain user. You must use mixed mode authentication and create an SQL user to connect to the database.
    • Azure SQL managed Instance for Microsoft SQL Server 2022 database
  1. If you choose the DB2®, MS SQL or Oracle database options, you must install the database and create a database instance before you run the server installation task.
  2. If you are using DB2® 9.7 GA version, you must upgrade to DB2® 9.7 fix pack 1 due to a DB2® issue where NULL values are returned in generated key values.
To access the Remote Control Server Installer Wizard, complete the following steps:
  1. In the Remote Control navigation tree, select Manage Configurations > Remote Control Server Installer Wizard.
    Server installer wizard
  2. Set your configuration values by using one of the following options.
    Load Settings from Existing Task
    The wizard initially displays server configuration default values that you can change to your own requirements. To load previously saved settings, complete the following steps.
    1. Click Load Settings from Existing Task.
    2. On the Wizard Fixlets screen, select the task.
      Choose a server installation task from the displayed list
    3. Click Load Wizard with Fixlet. The configuration values are loaded into the wizard.
    4. Follow the steps in Create a new configuration task to create a new configuration task.
    Reset to default values
    You can use this feature to clear any selections that are made and return the values in the wizard to the default configuration values.
    Follow the steps that are relevant to the database that you are using.
  3. When you set your values, save the installation task by completing step 5.
