Enabling FIPS compliance on a server installation with a stand-alone Open Liberty Application Server
The BigFix® Remote Control Server uses the middleware infrastructure that is provided by Open Liberty® secure HTTP communications. Therefore, to enable FIPS for a manual BigFix® Remote Control Server installation requires that you configure Open Liberty® for FIPS-compliant mode. You must also configure the BigFix® Remote Control Server through a setting in the common.properties configuration file.
To enable FIPS compliance for a manual installation, complete the following steps:
Configure WebSphere
Note:Running in FIPS mode in IBM® WebSphere® with the IBM® JRE and the IBM® JSSE provider currently does not work when you use an MS SQL database. These options work with MS SQL when FIPS is not enabled in IBM® WebSphere.
- Log on to the BigFix® Remote Control Server with a valid admin ID and password.
- Click
- In the common.properties file set FIPS.compliance to true.
- Click Submit.
- Click .
The FIPS enablement changes in WebSphere affect all other applications that are running on
the server. Therefore, browser settings for the users who access the other applications must
be changed to support Transport Layer Security (TLS), if required by their browser
version.
