Receiving files from the target
Use the Pull file option to transfer files from the target system to the controller system during an active remote control session.
To receive a file from the target complete the following steps :
  1. Click File transfer menu > Pull file.
    If the Enable user acceptance for file transfers policy is enabled for the session the target user must accept or refuse the request to transfer the file. If they accept the request, the Choose file to send window opens displaying the contents of the targets file transfer directory. If they refuse, or do not respond in a given time, a refusal message is displayed and the file transfer is not allowed.
    If the target user does not respond in the given time and the Acceptance timeout action server policy is set to PROCEED, the Choose file to send window opens.
    If Enable user acceptance for file transfers is set to No, user acceptance is not required by the target user and you can continue with the file transfer.
  2. Click the up arrow to change to a different location if required.
  3. Select the required file and click OK.
    The Pull file to Destination window opens displaying the contents of your file transfer directory. Select a different location if required.
  4. Click Save.
The file is transferred to the file transfer directory or the selected destination folder on your system .
