Exporting and downloading a recording from the server
After a recording of a remote control session is saved to the server, use the Export session recording function to export and save the recording to your system.
This function can be useful in a number of ways
- If a local recording was not made during the session.
- If you want to use the recordings for education or training purposes.
To export one or more recordings complete the following steps:
- Click . Note:If you are an administrator, you can also click
- Select one or more sessions.
- Choose the appropriate method for selecting Export
session recording.
- Click Export session recording from the action list on the left
- OR click
Note:If the recording export function is enabled on the server, the following message is displayed.The recording export functionality is disabled. Please consult the documentation for details on how to enable it.
. For more information about enabling the export functions, see the BigFix® Remote Control Administrator's Guide - Select the relevant file compression
- Lossless
- To compress the file without losing any detail. This option produces a larger file size. Choose this file type if you require a better image quality or if the recording might be used for editing to provide educational material. To play back this type of recording you must install a QuickTime codec.
- Compressed
- To compress the file and lose minor details. This option produces a smaller file size. Choose this file type if the recording is only for viewing. To play back this type of recording you must install an Xvid codec. The codec can be found on the Xvid.org:Home of the XVid Codec website.
- filename
- Is in the format SSS-nnnnnnnn.
- SSS
- The session id.
- nnnnnnnn
- The computer name of the target.
For example, 152-mytarget - file extension
- Is .mov or .avi.
- .mov
- Is applied when Lossless is chosen for the file compression.
- .avi
- Is applied when Compressed is chosen for the file compression.
- Click Export recording.When the recording is exported, the status changes to Exported and a Download option is available.
- Click Download.
- Click Save.
- On the Save As window, browse to
the relevant location for saving the recording file to. You can change
or keep the name that is given and click Save.
Note:If you click Cancel, the file is not downloaded.
The recording is exported and downloaded from the BigFix® Remote Control
Server and
saved to your local system. To ensure that it can be played back correctly
you must install the correct codec as indicated in step 4.
For Linux systems,
you® must download and install
MPlayer with support for the Xvid codec.
