Downloading the Windows™ controller software
Use Agent Downloads option to run or save the file that is required for installing the Windows™ controller software.
  1. Click Tools > Downloads.
  2. Click Agent Downloads.
  3. Select trc_controller_setup.exe.
  4. Select Run or Save.
    Run
    To begin installing the controller software.
    1. Click Next at the welcome panel.
    2. Accept the license agreement, click Next.
    3. Accept or change the location for the installation files, click Next.
    4. Click Install.
    5. Click Finish.
    If the controller software is already installed, repair or remove options are available.
    Save
    To save the trc_controller_setup.exe file to a selected location.
    Run the executable file to install the controller software.
