You can configure controller properties to store a history
of the target IP addresses, user IDs, and domain names that are used
to start a peer to peer session.
These items are then available for selection in the open
connection window when a controller user starts a peer to peer session.
The history is stored in the trc_history.properties file
in the home directory of the controller user. Edit the trc_controller.cfg file
to configure these properties. For more information about configuring
propertiess, see Configuring global controller properties.
Property definitions
enable.address.history=
| Modifiable Field |
enable.address.history |
| Field Description |
Determines whether the controller stores a history
of recently used IP addresses that were used when you started a peer
to peer session. Any IP address that was used to successfully start
a session is stored in the IP address history. The history is stored
in a file named trc_history.properties. Default
value is true. |
| Possible Values |
True or False |
| Value Definition |
- True
- the IP address history is enabled in the connection window when
you are starting a peer to peer session. Select the required IP address
from the list.
- False
- the IP address history is not enabled in the connection window.
enable.user.history=
| Modifiable Field |
enable.user.history |
| Field Description |
of recently used user IDs that were used when you started a peer to
peer session. Any user ID that was used to successfully start a session
is stored in the IP address history. The history is stored in a file
named trc_history.properties. Default value is
false. |
| Possible Values |
True or False |
| Value Definition |
- True
- the user history is enabled in the connection window when you
are starting a peer to peer session. Select the required user ID from
the list.
- False
- the user history is not enabled in the connection window.
enable.domain.history=
| Modifiable Field |
enable.domain.history |
| Field Description |
of recently used domain names that were used when you started a peer
to peer session. Any domain name that was used to successfully start
a session is stored in the domain history. The history is stored in
value is true. |
| Possible Values |
True or False |
| Value Definition |
- True
- the domain history is enabled in the connection window when you
are starting a peer to peer session. Select the required domain name
from the list.
- False
- the domain history is not enabled in the connection window.
history.max.items=
| Modifiable Field |
| Field Description |
Sets a limit to the size of the history lists for
IP addresses, user IDs, and domains. The oldest item in the history
list is removed if the list reaches the history.max.items limit
and a new item needs to be added. |
| Possible Values |
0 - 20 |
| Value Definition |
A value greater than 20 gives a maximum length
of 20 items only in the lists in the connection window. A value of
0 disables the history lists. |
