Configuring connection credentials
Use the following properties to set valid credentials for connecting to the LDAP server.
Check that a successful connection to the LDAP browser can be established by using these credentials to verify that they are valid.
  1. Edit the ldap.properties file.
  2. Configure the following properties.
    ldap.connectionName
    The user name that is used to authenticate to a read-only LDAP connection. If left not set, an anonymous connection is attempted. For example, administrator@mydomain.mycompany.com.
    ldap.connectionPassword
    The password that is used to establish a read-only LDAP connection. The password can be entered here in plain text or it can be encrypted. Use the LDAP wizard to encrypt your password. For more information, see Configure LDAP properties by using the LDAP wizard.
    ldap.connectionPasswordEncrypted
    True
    The LDAP password is encrypted.
    False
    The LDAP password is not encrypted and entered as plain text.
    Use the following method to generate the encrypted password. In a Windows system.
    1. Open a command prompt window and type
      cd [installdir]\wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\
      WEB-INF\lib
      where installdir is the Remote Control server installation directory For example,
      cd \Program Files\BigFix\TRC\server\wlp\usr\servers\trcserver\
      apps\TRCAPP.ear\trc.war\WEB-INF\lib
    2. Type the following command
      java -cp ./trc.jar com.ibm.uk.greenock.authentication.Encrypt <password>
      Where password is the LDAP password to be encrypted.
      For example,
      java -cp ./trc.jar com.ibm.uk.greenock.authentication.Encrypt myPassw0rd
      This command is all on one line with a space between jar and com.
    3. The following output from the command can be displayed.
      Encrypted Password : [encrypted password]
      Decrypted Password : [text version of password ]
      For example,
      Encrypted Password: 10|ydEBl67atSSbrAA=
      Decrypted Password: myPassw0rd
      Edit the ldap.properties file and set the ldap.connectionPassword property to the encrypted password value. The decrypted password is shown to verify that the encryption is valid.
    In a UNIX or Linux® system.
    1. Open a terminal window and type
      [installdir]/wlp/usr/servers/trcserver/apps/TRCAPP.ear/trc.war/
      WEB-INF/lib
    3. The output from the command is the following
    ldap.connectionURL
    The directory URL used to establish an LDAP connection. Type in the URL of your LDAP server.
    ldap://myldapserver.mydomain.mycompany.com
