Customizing your portfolio
How to customize your portfolio.
Many different elements can be customized in the navigation toolbar across the top and on the left side of you Dynamic Workload Console.
You can create a list of your favorite pages, including only the tasks you use most often.
The Favorites icon , lets you access your daily tasks.
To add a task to Favorites, simply click the icon when opening the drop-down menu. To remove an item from your list of favorites, click the
icon
What to do next
You can also define which pages must be automatically launched when logging into the Dynamic Workload Console by pinning them. On the left bar, when the page is
opened, click the icon
Customizing your startup page
How to customize the startup page
when the page is displayed. Alternatively from the Manage Roles
section, users with role Administrator, can add or remove the pinned pages for each role.Create and customize your boards
In the Dynamic Workload Console, users can create and customize a Board not only with widgets to monitor the scheduling environment but also with web contents. For example, you can add a widget in the dashboard with your company's website and other external contents.
- To add a web content to your dashboard, from the Dynamic Workload Console click the tab .
- Enter the name of the custom Board.
Click
to add the widget.
- Select Static widgets and Web content.
- Enter the name and the source of your content.
Click Save.
The new frame is displayed in the board.
