SQL report examples
Examples of queries that can be run using the SQL custom reports.
This section provides some examples of queries that can be run using the SQL custom reports.
Jobs grouped by return codes
For each return code, this query returns the number of jobs that ended with the corresponding return code:
SELECT DISTINCT return_code AS RC count(job_name) AS ,#JOB
FROM mdl.job_history_v
GROUP BY return_code
Table 1. Example of query outcome
RC #JOB
0 1670
5 11
6 1
50 2
127 352
Job statistics grouped on job status
For each job status, this query returns the number of jobs that ended with the corresponding job status and also the planned duration time, the total elapsed time, and total CPU time:
SELECT job_status, count(job_name) AS job count, floor(sum(planned_duration/1000)) AS
planned duration, floor(sum(total_elapsed_time/1000)) AS total elapsed,
floor(sum(total_cpu_time/1000)) AS total cpu
FROM mdl.job_history_v GROUP BY job_status
Table 2. Example of query outcome
JOB_STATUS JOB COUNT PLANNED DURATION TOTAL ELAPSED TOTAL CPU
A 366 0 21960 0
S 1670 1413360 1423500 183
Jobs in a range of return code
This query returns the number of job in a range of return codes
SELECT *
FROM (select DISTINCT return_code, count(job_name) AS #JOB
GROUP BY return_code) AS temp
WHERE return_code > 0 AND return_code ˂ 6
Table 3. Example of query outcome
RETURN_CODE #JOB
5 11
Jobs that ran within a time range and finished with a specific job status
SELECT WORKSTATION_NAME, JOB_NAME, JOB_RUN_DATE_TIME
FROM MDL.JOB_HISTORY_V
WHERE JOB_RUN_DATE_TIME BETWEEN '2008-05-19 10:00:00.0' AND '2008-05-19
21:00:00.0' AND JOB_STATUS ˂> 'S'
ORDER BY JOB_RUN_DATE_TIME
Table 4. Example of query outcome
WORKSTATION_NAME JOB_NAME JOB_RUN_DATE_TIME
NC122072 PEAK_A_06 2008–08–03 23:23:00.0
NC122072 JOB_RER_A 2008–08–03 23:23:00.0
NC122072 PEAK_A_13 2008–08–03 23:23:00.0
NC122072 PEAK_A_20 2008–08–03 23:23:00.0
NC122072 PEAK_A_27 2008–08–03 23:23:00.0
NC122072 PEAK_A_43 2008–08–03 23:23:00.0
NC122072 PEAK_B_19 2008–08–03 23:24:00.0
