Configuring Dynamic Workload Console to connect to a remote SAP system
You can create a new SAP connection.
The scope of the scenario is to create a new SAP connection named “S4HANA” with the workstation named “DYN_AGENT”, using an options file named “FILE_AGENT1_r3batch.opts”.
Create a new SAP connection as follows:
- From the Administration menu, click Manage SAP Connections page, and then select the engine.
- Click New Connection.
- In SAP Connection Name, type S4HANA.
- In Workstation, click the lookup icon, search the workstation named "DYN_AGENT", and select it.
- In Option file, click the lookup icon, search the option file named "FILE_AGENT1_r3batch.opts", and select it.
- Test the connection.
- Click Ok to save it.
You successfully created a SAP connection named “S4HANA”, and now you can start creating, scheduling, and control your SAP jobs directly from the HCL Workload Automation.
