Monitoring your objects in the plan
Define a task to monitor objects in the plan by specifying a query in a query line. The objects for which you can create a monitoring task query are: jobs, critical jobs, job streams, workstations, files, resources, domains, and prompts.
Note: For all the
details about options and fields displayed in the panels, see the online help by clicking the
question mark located at the top-right corner of each panel.
- In the navigation toolbar, click .
From the Engine drop-down list, select the check box related to the
engine where the task must run.
You can specify more than one engine only if the type of object you want to monitor is job or job stream.
- From the Object Type drop-down
list, select the type of object you want to monitor. The available
object types correspond to the type of engine and number of engines
you selected.
For a distributed engine, you can create a monitoring task query for: Job, Critical Job, Job Stream, Workstation, File, Resource,Domain, and Prompt.
For a z/OS engine, you can create a monitoring task query only for: Job, Critical Job, Job Stream, Workstation, and Resource.
- From the List Plans drop-down list, you can select the current plan or an archived plan related to the selected engine. Plans are only stored for the distributed engines, you cannot select the field for critical jobs.
- In the Query text box,
type the query that specifies the filter criteria to apply to the
object type you selected. If you are familiar with the conman syntax,
the query syntax is quite similar; for example, the syntax for filtering
jobs is similar to conman showjobs. If you are
not familiar with conman, click Edit to
create your query by selecting the options from the filter criteria
that are displayed (for details, see step 7).In general, the following rules apply to the query syntax:
- The plus symbol (+) is used to separate filter parameters.
- The hash key symbol (#) is used to separate the workstation name from the job stream name, for a distributed engine.
- The exclamation mark (!) is used to separate the workstation from the job stream name, for a z/OS engine.
- The ampersand symbol (@) replaces one or more alphanumeric characters (wild card).
- The period (.) separates the workstation name, job stream name from the job name.
- The slash (/) separates the folders.
For example, to display the status of all jobs in theacctg
job stream on workstationsite3
for a distributed engine, type the following string in the Query text box:
or:site3#/foo/acctg.@
For more example about queries and syntax, see Example.site3#/foo/acctg
- Click Run to run the task immediately.
The results are displayed in table format in a new page. From this page you can continue to edit the query in the query line or click Edit to make changes to the user interface selections. The list of results are updated with the changes you make.Note: After running, the query is automatically saved in the Query drop-down list, enabling you to reuse it for future monitoring. You can manage the list either by removing a single query by selecting the minus (-) next to the query to be removed, or clearing all saved queries by selecting Clear Query History.
- Alternatively, click Edit to
select the filter criteria from a list of options rather than specifying
them in the Query text box. The Query text field is automatically populated with the appropriate syntax.For details about the filter criteria that apply to the object type you selected, refer to the following sections:
- Type a name for the monitoring task in the Task Name text box.
Click Save to save the task.
Each task you create and save is included in the Query drop-down list. You can reuse or modify each saved task, as required.
- Select a task from the Query drop-down list and click Edit. Duplicate to create a new task exactly like the one you selected. This is useful if you want to work with a task that is not your own, but is shared with you.
- Select one or more tasks from the Query drop-down list and click Edit. Click Delete to delete them. You cannot delete tasks that are not your own.
- Click Run to run the task.
A list of results is displayed in table format in a new page. Alternatively you can view the output of the selected task in a report format in a separate HTML file. Click View as Report to view the output.
Example
The following examples
show the syntax used to create some specific queries:
- Job query in a distributed environment
- To query for all jobs, in all job streams and on all workstations on a specific distributed
engine, with the following characteristics:
- Having a dependency on a workstation with a name beginning with FTA_1
- Beginning with Job_A in a job stream beginning with
JS_A
in FOLDERA folder
- Scheduled to run at 10 a.m. on October 31, 2015
- Currently in Waiting state with a priority in the range of 1 - 50
/@/@#/@/@.@+follows=/@/FTA_1#/FOLDERA/JS_A@(1000 10/31/2015).JOB_A@+state=#Waiting,#Ready+priority=1,50
- Job query in a z/OS environment
- To query for all jobs in a job stream ending in 001,
on all workstations beginning with HR in a
z/OS environment, with the following characteristics:
- Having an internal status of Interrupted and Error
- Having a priority of 1
HR@!@001.@+jsfrom=1000 10/10/2015+state=E,I+priority=1
