Folder
A folder is an object that can be used to organize job streams into lines of business or other custom categories.
With the folder you can organize jobs and job streams in folders categorized by departments or adaptable tagging concepts.
You can also quickly move a set of jobs or job streams that use a specific naming convention into folders that are named after tokens contained in the object names. See Organizing scheduling objects into folders for more information.
