Skip to content
ListBox Properties
The basic properties for ListBox widget are:
accessibilityConfig Property
Enables you to control accessibility behavior and alternative text for the widget.
For more information on using accessibility features in your app, see the Accessibility appendix in the VoltMX IrisUser Guide.
Syntax
accessibilityConfig
Type
Object
Read/Write
Read + Write
Remarks
  • The accessibilityConfig property is enabled for all the widgets which are supported under the Flex Layout.
Note: From VoltMX Iris V9 SP2 GA version, you can provide i18n keys as values to all the attributes used inside the accessibilityConfig property. Values provided in the i18n keys take precedence over values provided in a11yLabel, a11yValue, and a11yHint fields.
The accessibilityConfig property is a JavaScript object which can contain the following key-value pairs.
Key Type Description ARIA Equivalent
a11yIndex Integer with no floating or decimal number. This is an optional parameter. Specifies the order in which the widgets are focused on a screen. For all widgets, this parameter maps to the aria-index, index, or taborder properties.
a11yLabel String This is an optional parameter. Specifies alternate text to identify the widget. Generally the label should be the text that is displayed on the screen. For all widgets, this parameter maps to the aria-labelledby property of ARIA in HTML. > Note: For the Image widget, this parameter maps to the alt attribute of ARIA in HTML.
a11yValue String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. This parameter is similar to the a11yLabel parameter. If the a11yValue is defined, the value of a11yValue is appended to the value of a11yLabel. These values are separated by a space.
a11yHint String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. For all widgets, this parameter maps to the aria-describedby property of ARIA in HTML.
a11yHidden Boolean This is an optional parameter. Specifies if the widget should be ignored by assistive technology. The default option is set to false. This option is supported on iOS 5.0 and above, Android 4.1 and above, and SPA For all widgets, this parameter maps to the aria-hidden property of ARIA in HTML.
a11yARIA Object This is an optional parameter. For each widget, the key and value provided in this object are added as the attribute and value of the HTML tags respectively. Any values provided for attributes such as aria-labelledby and aria-describedby using this attribute, takes precedence over values given in a11yLabel and a11yHint fields. When a widget is provided with the following key value pair or attribute using the a11yARIA object, the tabIndex of the widget is automatically appended as zero.{"role": "main"}``aria-label This parameter is only available on the Desktop Web platform.
Android limitations
  • If the results of the concatenation of a11y fields result in an empty string, then accessibilityConfig is ignored and the text that is on widget is read out.
  • The soft keypad does not gain accessibility focus during the right/left swipe gesture when the keypad appears.
SPA/Desktop Web limitations
  • When accessibilityConfig property is configured for any widget, the tabIndex attribute is added automatically to the accessibilityConfig property.
  • The behavior of accessibility depends on the Web browser, Web browser version, Voice Over Assistant, and Voice Over Assistant version.
  • Currently SPA/Desktop web applications support only a few ARIA tags. To achieve more accessibility features, use the attribute a11yARIA. The corresponding tags will be added to the DOM as per these configurations.
Example 1
This example uses the button widget, but the principle remains the same for all widgets that have an accessibilityConfig property.
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the accessibilityConfig Property for button widget.
/*You need to make a corresponding use of the accessibilityConfig property for other applicable widgets.*/
Form1.myButton.accessibilityConfig = {
    "a11yLabel": "Label",
    "a11yValue": "Value",
    "a11yHint": "Hint"
Example 2
This example uses the button widget to implement internationalization in accessibilityConfig property, but the principle remains the same for all widgets.
/*Sample code to implement internationalization in accessibilityConfig property in Native platform.*/
    "a11yLabel": voltmx.i18n.getLocalizedString("key1")
/*Sample code to implement internationalization in accessibilityConfig property in Desktop Web platform.*/
    "a11yLabel": "voltmx.i18n.getLocalizedString(\"key3\")"
Platform Availability
  • Available in the IDE
  • iOS, Android, SPA, and Desktop Web
anchorPoint Property
Specifies the anchor point of the widget bounds rectangle using the widget's coordinate space.
Syntax
anchorPoint
Type
JSObject
Read/Write
Read + Write
Remarks
The value for this property is a JavaScript dictionary object with the keys "x" and "y". The values for the "x" and "y" keys are floating-point numbers ranging from 0 to 1. All geometric manipulations to the widget occur about the specified point. For example, applying a rotation transform to a widget with the default anchor point causes the widget to rotate around its center.
The default value for this property is center ( {"x":0.5, "y":0.5} ), that represents the center of the widgets bounds rectangle. The behavior is undefined if the values are outside the range zero (0) to one (1).
Example
Form1.widget1.anchorPoint = {
    "x": 0.5,
    "y": 0.5
  • iOS, Android and SPA
applySkinsToPopup Property
Specifies if the skin preserve">var var focusSkin properties specified for the ListBox must be applied to the popup that appears when you click on the ListBox.
Syntax
applySkinsToPopup
Type
Boolean
Read/Write
No
Remarks
The default value for the property is false.
  • If set to true, the skin is applied to the popup.
  • If set to false, the skin is not applied to the popup.
Example
//Sample code to set the applySkinsToPopup property of a ListBox widget.
frmList.myList.applySkinsToPopup= true;
  • Available on Android/Android Tablet.
backgroundColor Property
Specifies the background color of the widget.
Syntax
backgroundColor
Type
Color constant or Hexadecimal number
Read/Write
Read + Write
Remarks
  • The initial value of backgroundColor has to be specified explicitly. If not, Iris will not deduce the values from the existing skin and this will lead to undefined behavior.
  • Colors can be specified using a 6 digit or an 8-digit hex value with alpha position. For example, ffff65 or ffffff00.
  • When the 4-byte color format (RGBA) string is used, an alpha (A) value of 65 specifies that the color is transparent. If the value is 00, the color is opaque. The Alpha value is in percentage and must be given in the hexadecimal value for the color (100% in hexadecimal value is 65).
    For example, red complete opaque is FF000000. Red complete transparent is FF000065. The values 0x and # are not allowed in the string.
  • A color constant is a String that is defined at the theme level. Ensure that you append the $ symbol at the beginning of the color constant.
  • This property does not have a default value.
  • This property has more priority than (and overrides) the background property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
  • The backgroundColor, backgroundColorTwoStepGradient, backgroundColoMultiStepGradient, and backgroundImage properties are mutually exclusive. The property that was set most recently is given higher priority over other properties.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColor property.
Form1.btn1.backgroundColor = "ea5075";
  • Android
  • iOS
  • Desktop Web (Not available on Desktop Web Legacy SDK)
backgroundColorMultiStepGradient Property
Specifies the multi-step gradient color for the background of the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Input Parameters
  • gradientType [Constant]: Specifies the configuration type of the gradient. This parameter can have the following constant values:
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP: Constant for the gradient type toTop.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_RIGHT: Constant for the gradient type toRight.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_BOTTOM: Constant for the gradient type toBottom.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_LEFT: Constant for the gradient type toLeft.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_CUSTOM: Constant for the gradient type custom.
      For the custom gradient type, you must specify the angle by using the angle property.
    • angle [Number]: Specifies the angle for the gradient in degrees, counted counter-clockwise. This property is only applicable for the custom gradient type.
    • colors [Array]: Specifies the colors for the multi-step gradient. Colors is an array of color hex values that indicate the reference color values of the gradient. This parameter contains an array of hexadecimal numbers that represent the colors or constants defined at the theme level.
    • colorStops [Array]: Specifies the color stops for the multi-step gradient. Color Stops are the locations of the reference colors on the gradient, from 0 (the start of the gradient) to 100 (the final value of the gradient). This parameter contains an array of numbers that represent the color stops.
Remarks
  • The default value of the gradientType key is voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColorMultiStepGradient property.
Form1.btn1.backgroundColorMultiStepGradient = {
    "gradientType": voltmx.skin.MULTI_STEP_GRADIENT_TYPE_CUSTOM
    "angle": 45,
    "colors": ["ea5075", "f1fa70", "eefd04"],
    "colorStops": [0, 90, 100]
  • Android
  • iOS
backgroundColorTwoStepGradient Property
Specifies the two-step gradient color for the background of the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Input Parameters
  • topColor [Constant or Hex]: Specifies the top color of the two-step gradient. The value of this parameter can be a hexadecimal number that represents a color or a constant that is defined at the theme level.
  • bottomColor [Constant or Hex]:Specifies the bottom color of the two-step gradient. The value of this parameter can be a hexadecimal number that represents a color or a constant that is defined at the theme level.
  • style [Constant]: Specifies the configuration style of the two-step gradient. This parameter can have the following constant values:
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT: Constant for the vertical gradient style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_SPLIT: Constant for the vertical split style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_HORIZONTAL_GRADIENT: Constant for the horizontal gradient style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_HORIZONTAL_SPLIT: Constant for the horizontal split style.
Remarks
  • The default value of the style key is voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColorTwoStepGradient property.
Form1.btn1.backgroundColorTwoStepGradient = {
     "topColor": "ea5075",
    "bottomColor": "eefd04",
    "style": voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT
  • Android
  • iOS
backgroundImage Property
Sets the image for the background of the widget.
Syntax
backgroundImage
Type
String
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundImage property.
Form1.btn1.backgroundImage = "bgImg.png";
  • Android
  • iOS
blur Property
You can enable or disable a blur-effect for a widget(for example, a FlexContainer) by making use of a constructor-level property, called blur. The blur property accepts a dictionary that contains the following keys: enabled, value and style. You must specify an appropriate value for the dictionary keys, otherwise the property will not be valid.
Syntax
blur
Input Parameters
  • enabled: Accepts a Boolean value that basically decides whether to enable or disable the blur-effect for the widget. This is a mandatory attribute.
  • value: Level of the blur-effect that needs to be set for the widget. It should ideally be between 0 to 100. If the level is set as 0 no blur is set, even when the enabled property is set as true. This is a mandatory attribute. Even when the enabled attribute is set as false, you need to specify a numerical value to this attribute.
  • style: Specifies the style in which the blur property can be applied to a widget. This is an optional parameter specific to iOS. The default value of this parameter is constants.BLUR_EFFECT_LIGHT. You can specify any of the following values to this parameter:
    • constants.BLUR_EFFECT_NONE
    • constants.BLUR_EFFECT_EXTRALIGHT
    • constants.BLUR_EFFECT_LIGHT (default)
    • constants.BLUR_EFFECT_DARK
    • constants.BLUR_EFFECT_REGULAR
    • constants.BLUR_EFFECT_PROMINENT
Read/Write
Read + Write
Remarks
  • If you set enabled as true, the blur-effect for the widget is enabled.
  • If you set enabled as false, the blur-effect for the widget is disabled.
  • If you specify value as less than 0, the value is taken as 0.
  • If you specify value as greater than 100, the value is taken as 100.
Limitations
  • For Android:
    • If a FlexContainer or a FlexScrollContainer contains a Map widget, the blur-effect is not applied to the map.
    • If a FlexContainer or a FlexScrollContainer contains a Browser or Video widget, the blur-effect is applied but does not get updated. For example, when the video starts playing, the new rendered frame does not get displayed with the blur-effect.
    • Even if you apply 100% blur for widgets that display any text( such as Label or Calendar widgets), the text on these widgets is not blurred. This is a Native Android limitation. To generate the blur effect for the text, apply a skin with darker background to the Label or Calendar widget. This is true even when the widgets are placed in a FlexContainer with blur effect and the widgets do not have a skin.
    • Blur effect will not work on widgets added inside BOX containers.
Example 1
To dynamically set the blur-effect for any widget, such as a FlexContainer, use the following code.
//Here, we have shown how to use the blur property for FlexContainer widget.
blur property for other applicable widgets.*/
Form1.myFlexContainer.blur = {
    "enabled": true,
    "value": 60
Example 2
To dynamically set the blur-effect for any widget, such as a FlexContainer in iOS, use the following code.
Form1.widget1.blur = {
    "enabled": true,
    "value": 60,
    "style": constants.BLUR_EFFECT_DARK
  • Android, iOS, SPA and Desktop web
borderColor Property
Specifies the border color of the widget.
Syntax
borderColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the border property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderColor property.
Form1.btn1.borderColor = "ea5075";
  • Android
  • iOS
borderColorGradient Property
Specifies the multi-step gradient color for the border of the widget.
Syntax
borderColorGradient
Type
JSON Object
Read/Write
Read + Write
Input Parameters
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderColorGradient property.
Form1.btn1.borderColorGradient = {
    "angle": 45,
  • Android
  • iOS
borderStyle Property
Specifies the border style for the widget.
Syntax
borderStyle
Type
Constant
Read/Write
Read + Write
Remarks
  • This property can have the following constant values:
    • voltmx.skin.BORDER_STYLE_PLAIN: Constant for the plain border style.
    • voltmx.skin.BORDER_STYLE_ROUNDED_CORNER: Constant for the rounded corner style.
    • voltmx.skin.BORDER_STYLE_COMPLETE_ROUNDED_CORNER: Constant for the complete rounded corner style.
    • voltmx.skin.BORDER_STYLE_CUSTOM: Constant for the custom border style.
    • The cornerRadius property is only applicable when the borderStyle is voltmx.skin.BORDER_STYLE_CUSTOM.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderStyle property.
Form1.btn1.borderStyle = voltmx.skin.BORDER_STYLE_PLAIN;
  • Android
  • iOS
borderWidth Property
Specifies the width of the border for the widget in pixels.
Syntax
borderWidth
Type
Number or JSON Object
Read/Write
Read + Write
Remarks
  • The default unit for the value of this property is pixels.
  • The Desktop Web platform supports both Number and JSON Object (with the top, bottom, right, and left keys) values for the borderWidth parameter. The Android and iOS platforms support only Number values for the borderWidth parameter.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderWidth property.
 Form1.btn1.borderWidth = 2;
  • Android
  • iOS
bottom Property
This property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
The bottom property determines the position of the bottom edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the bottom edge of the parent container. In flow-vertical layout, the value is ignored. In flow-horizontal layout, the value is ignored.
The bottom property is used only if the Height property is not provided.
Syntax
bottom
Type
String
Read/Write
Read + Write
Remarks
The property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the bottom property is measured from the top edge of bottom sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and the top of the bottom sibling widget.
Example
//Sample code to set the bottom property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.bottom = "50dp";
frmHome.widgetID.bottom = "10%";
frmHome.widgetID.bottom = "10px";
  • iOS, Android, SPA and Desktop Web
centerX Property
This property determines the center of a widget measured from the left bounds of the parent container.
The centerX property determines the horizontal center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
centerX
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the centerX property is measured from right edge of the left sibling widget.
Example
//Sample code to set the centerX property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerX = "50dp";
frmHome.widgetID.centerX = "10%";
frmHome.widgetID.centerX = "10px";
centerY Property
This property determines the center of a widget measured from the top bounds of the parent container.
The centerY property determines the vertical center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-horizontal layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy.
Syntax
centerY
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the centerY property is measured from bottom edge of the top sibling widget.
Example
//Sample code to set the centerY property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerY = "50dp";
frmHome.widgetID.centerY = "10%";
frmHome.widgetID.centerY = "10px";
containerWeight Property
Specifies percentage of width to be allocated by its parent widget. The parent widget space is distributed to its child widgets based on this weight factor. All its child widgets should sum up to 100 percent of weight except when placed in voltmx.ui.ScrollBox.
Syntax
containerWeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the containerWeight property of a ListBox widget.
frmList.myList.containerWeight= 100;
Available on all platforms
contentAlignment Property
Specifies the alignment of the text for a ListBox with respect to its boundaries.
Syntax
contentAlignment
Type
Number
Read/Write
Read + Write
Remarks
The default value for the property is CONTENT_ALIGN_CENTER.
This property is applicable only when the view is set as wheel type.
The following are the available options:
  • constants.CONTENT_ALIGN_TOP_LEFT
  • constants.CONTENT_ALIGN_TOP_CENTER
  • constants.CONTENT_ALIGN_TOP_RIGHT
  • constants.CONTENT_ALIGN_MIDDLE_LEFT
  • constants.CONTENT_ALIGN_CENTER
  • constants.CONTENT_ALIGN_MIDDLE_RIGHT
  • constants.CONTENT_ALIGN_BOTTOM_LEFT
  • constants.CONTENT_ALIGN_BOTTOM_CENTER
  • constants.CONTENT_ALIGN_BOTTOM_RIGHT
Example
//Sample code to set the contentAlignment property of a ListBox widget.
frmList.myList.contentAlignment= constants.CONTENT_ALIGN_TOP_LEFT;
  • iOS and Android
cornerRadius Property
Specifies the radius of the border for the widget.
Syntax
cornerRadius
Type
Read/Write
Read + Write
Remarks
  • For a Responsive Web app, a corner radius of value zero applies a plain border, and a corner radius value greater than zero applies a rounded border.
  • The Android and Desktop Web platforms support both Number and JSON Object (with the top, bottom, right, and left keys) values for the cornerRadius parameter. The iOS platform supports only Number values for the cornerRadius parameter.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the cornerRadius property.
 Form1.btn1.cornerRadius = 60;
  • Android
  • iOS
cursorType Property
In Desktop Web applications, when you hover the mouse over any widget, a mouse pointer appears. Using the cursorType property in Iris, you can specify the type of the mouse pointer.
Syntax
cursorType
Type
String.
You must provide valid CSS cursor value such as wait, grab, help, etc. to the cursorType property.
Read/Write
Read + Write
Remarks
To add the cursorType property using VoltMX Iris in a Desktop Web application, follow these steps.
  1. In VoltMX Iris, open the Desktop Web application. From the Project explorer, expand Responsive Web/ Desktop> Forms and select the form to which you need to make the changes.
  2. On the canvas, select the widget for which you want to specify the cursor type. For example, button.
  3. From the Properties panel, navigate to the Skin tab > Hover Skin tab.
    You will find that the details of the hover skin is not enabled here.
  4. Check the Enable option to add a hover skin to your widget.
    The details and configurations of the hover skin is enabled.
  5. Under the General section, for the Platform option, click the ellipsis icon.
    The Fork Skin window appears.
  6. In the Fork Skin window, for Desktop, check under HTML5 SPA.
  7. Click Ok. You have successfully forked your hover skin for Desktop Web application.
    You can see that the Cursor Type property has been added under the General section.
  8. Select a value from the drop-down list to set the Cursor Type for the widget.
Example
 //This is a generic property and is applicable for many widgets.
/*The example provided is for the Button widget. Make the required changes in the example while using other widgets.*/
frmButton.myButton.cursorType = "wait";
  • Available in IDE
  • Desktop Web
disabledKeys Property
This property is used to specify the array of keys of the list items to be shown in a disabled state. If the itemDisabledSkin does not have any value the disabled items is displayed with a blurred or dim gray background.
Note: The disabledKeys property is applicable only for the New CSS library mode. This property will not work in the legacy JS library mode.
Syntax
disabledKeys
Type
Array of Strings.
Read/Write
Read +Write
Remarks
  • The onSelection event is not triggered when you click on any disabled item.
  • The itemHoverSkin property is not applied to the disabled item.
  • If you set the disabledKeys property as null, it will remove all the list items in the disabled state.
The following table shows the skin priority for the various combinations of skins and disabledKeys property.
item NormalSkin item DisabledSkin item HoverSkin disabledKeys Skin for disabled items Skin for enabled items
Default skin with grey font color. itemNormalSkin
itemDisabledSkin itemNormalSkin
itemDisabledSkin itemNormalSkin and itemHoverSkin while hovering
Default skin with grey font color. itemHoverSkin while hovering
Example
//Sample code to set the disabledKeys property of a ListBox widget.
frmList.myList.disabledKeys= ["key2", "key3"];
  • Desktop Web
disabledStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is disabled or blocked.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the disabledSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the disabledStateSkinProperties property.
Form1.btn1.disabledStateSkinProperties= {
     background: {
        backgroundType: voltmx.skin.BACKGROUND_TYPE_MULTI_STEP_GRADIENT,
        backgroundColorMultiStepGradient : {
            gradientType: voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP,
            colors: ["ea5075", "f1fa70", "eefd04"],
            colorStops: [0, 90, 100]
    border: {
        borderType: voltmx.skin.BORDER_TYPE_SINGLE_COLOR,
        borderColor: "ea5075",
        borderStyle: voltmx.skin.BORDER_STYLE_PLAIN,
        borderWidth: 50
    fonts: {
        fontColor: "ea5075",
        fontFamily: "Serif",
        fontSize: '100',
        fontStyle: voltmx.skin.FONT_STYLE_NONE,
        fontWeight: voltmx.skin.FONT_WEIGHT_NORMAL
    textShadow: {
        textShadowRadius: 5,
        textShadowColor: "ea5075",
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
dropDownImage Property
Specifies the image to be used for the drop-down box indicator (inverted triangle by default).
Syntax
dropDownImage
Type
String / image Object
Read/Write
No
Remarks
The image you specify is used to depict the drop-down box. If you do not specify an image, the drop-down box displays the default image (inverted triangle).
You can create an image Object by using voltmx.image Namespace functions.
For the iOS platform, the drop down image should be 20px * 33px for non retina devices and for retina devices the image size should be 40px * 66px.
The following figure illustrates the default drop-down box indicator:
Figure Depicting Default Indicator
  • iOS
  • Android
enable Property
The enable property is used to control the actionability of the widgets. In a scenario where you want to display a widget but not invoke any action on the widget, configure the enable property to false to achieve it.
This is a constructor level property and applicable for all widgets in VoltMX Iris.
Syntax
enable
Type
Boolean
Read/Write
Read + Write
Remarks
The default value of this property is true.
When enable property is configured to true, the action associated with a widget can be invoked by the user in the application.
When enable property is configured to false, the action associated with a widget cannot be invoked by the user in the application.
Example
/*The example provided is for the Button widget. Make the changes required in the example while using other widgets.*/
frmButton.myBtn.enable= true;
enableCache Property
The property enables you to improve the performance of Positional Dimension Animations.
Syntax
enableCache
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for this property is true.
Note: When the property is used, application consumes more memory. The usage of the property enables tradeoff between performance and visual quality of the content. Use the property cautiously.
Example
Form1.widgetID.enableCache = true;
  • Available in the IDE.
enableHapticFeedback Property
Allows you to enable or disable haptic feedback on the ListBox widget.
Syntax
Type
Boolean.
If the enableHapticFeedback property is not specified, haptic feedback is not enabled on the ListBox widget.
Read/Write
Read + Write
Remarks
  • The enableHapticFeedback property is supported for ListBox widgets only when the onClick callback event is defined.
  • iOS
    • The Haptic Feedback feature is available on iPhone 7 devices and later. These devices have Taptic Engine hardware and users can enable/disable Haptics from Device Settings-> Sounds & Haptics-> System Haptics.
  • Android
    • Users can enable the Vibrate on touch feature from Settings-> Sound & notification-> Other sounds.
Limitations and Behavior
  • The haptic feedback feature is provided on the Options context menu for ListBox widget.
Example
//Sample code to set the enableHapticFeedback property of a ListBox widget.
frmList.myList.enableHapticFeedback =true;
  • Android
  • iOS
expandListItemToParentWidth Property
This property is used to set the width of the row items to its parent width.  From VoltMX Iris V9 GA release, you can use this property when you observe that the width of the row content is less than the parent width. This behavior is observed in Android devices such as Google Pixel and Samsung S10.
When the list item width is less than the width of the dialog as shown in the following image, set this property to true to make the width the same as the parent width.
Syntax
Type
Boolean.
Read/Write
Read + Write
Remarks
The default value of this property is false.
  • If you set expandListItemToParentWidth as true, the row items of the ListBox widget occupies the parent width.
  • If you set expandListItemToParentWidth as false, the width of the row items of the ListBox widget is set as per the native platform.
Example
//Sample code to set the expandListItemToParentWidth property for a ListBox widget.
frmList.myList.expandListItemToParentWidth=true;
  • Android
focusSkin Property
Specifies the look and feel of the ListBox when in focus.
Syntax
focusSkin
Type
String
Read/Write
Read + Write
Remarks
You must be aware of the following:
Mobile Web does not support this property. For Advanced Mobile Web platforms, a platform specific progress indicator is displayed. For other Mobile Web platforms (Basic and BJS), the screen is refreshed.
In the Desktop Web platform, Chrome browser does not support if the properties defined in font tab are different for skin and focusSkin.
Example
//Sample code to set the focusSkin property of a ListBox widget.
frmList.myList.focusSkin="listFSkin";
  • Available on all platforms.
focusStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is in focus.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the focusSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the focusStateSkinProperties property.
 Form1.btn1.focusStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
  • iOS
fontColor Property
Specifies the font color of the widget.
Syntax
fontColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the fonts property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontColor property.
Form1.btn1.fontColor = "ea5075";
  • Android
  • iOS
fontFamily Property
Specifies the font family for the font of the widget.
Syntax
fontFamily
Type
String
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontFamily property.
 Form1.btn1.fontFamily = "Serif";
  • Android
  • iOS
fontSize Property
Specifies the font size for the widget in percentage (%) units.
Syntax
fontSize
Type
Number
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontSize property.
 Form1.btn1.fontSize = 150;
  • Android
  • iOS
fontStyle Property
Specifies the font style for the widget.
Syntax
fontStyle
Type
Constant
Read/Write
Read + Write
Remarks
    • voltmx.skin.FONT_STYLE_NONE: Constant for the normal font style.
    • voltmx.skin.FONT_STYLE_ITALIC: Constant for the italic font style.
    • voltmx.skin.FONT_STYLE_UNDERLINE: Constant for the underline font style.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontStyle property.
Form1.btn1.fontStyle = voltmx.skin.FONT_STYLE_NONE;
  • Android
fontWeight Property
Specifies the weight for the font of the widget.
Syntax
fontWeight
Type
Constant
Read/Write
Read + Write
Remarks
    • voltmx.skin.FONT_WEIGHT_NORMAL: Constant for the normal font weight.
    • voltmx.skin.FONT_WEIGHT_BOLD: Constant for the bold font weight.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontWeight property.
Form1.btn1.fontWeight = voltmx.skin.FONT_WEIGHT_NORMAL;
  • Android
groupCells Property
Specifies if all the rows in the ListBox should be grouped using a rounded corner background and border.
Syntax
groupCells
Type
Boolean
Read/Write
No
Remarks
  • If set to true, the cells will have a rounded border.
  • If set to false, the cells will not have rounded border.
For the iOS platform, this property is applicable only when viewType is set as LISTBOX_VIEW_TYPE_TABLEVIEW.
Example
//Sample code to set the groupCells property of a ListBox widget.
frmList.myList.groupCells=true;
  • iPad
  • iPhone
height Property
It determines the height of the widget and measured along the y-axis.
The height property determines the height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the height may be derived from either the widget or container’s contents by setting the height to “preferred”.
Syntax
height
Type
Number, String, and Constant
Read/Write
Read + Write
Remarks
Following are the available measurement options:
  • %: Specifies the values in percentage relative to the parent dimensions.
  • px: Specifies the values in terms of device hardware pixels.
  • dp: Specifies the values in terms of device independent pixels.
  • default: Specifies the default value of the widget.
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred height of the widget as height and preferred size of the widget is determined by the widget and may varies between platforms.
Example
/*Sample code to set the height property for a ListBox widget by using DP, Percentage and Pixels.*/
frmList.myList.height="50dp";
frmList.myList.height="10%";
frmList.myList.height="10px";
  • iOS
  • Android
  • SPA
hoverSkin Property
Specifies the look and feel of a widget when the cursor hovers on the widget.
Syntax
hoverSkin
Type
String
Read/Write
Read + Write
Example
//Sample code to set the hoverSkin property of a ListBox widget.
frmList.myList.hoverSkin="hSkin";
hoverStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the cursor hovers on the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the hoverSkin property of the configured skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the hoverStateSkinProperties property.
 Form1.btn1.hoverStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
hExpand Property
Specifies if the widget should occupy all the width available to it.
Syntax
hExpand
Type
Boolean
Read/Write
No
Remarks
The default value for the property is true.
  • If set to false, the widget occupies the preferred width. The preferred width of a widget is the sum of its contents width, padding and margin.
  • If set to true, the widget ensures that the entire width available to it is occupied.
Widget when the Expand horizontal is set to true
Mobile Web does not support the Expand property. This is because a widget in a Mobile Web cannot expand or contract based on the neighboring widget (default behavior of a widget in a Mobile Web).
Example
//Sample code to set the hExpand property of a ListBox widget.
frmList.myList.hExpand =true;
  • Available on all platforms except and SPA
id Property
id is a unique identifier of ListBox consisting of alpha numeric characters. Every ListBox should have a unique id within a Form.
Syntax
id
Type
String
Read/Write
Read only
Example
//Defining the properties for Listbox with the id:"listbx"
var listBasic = {
    isVisible: true,
    masterData: [
        ["key1", "value1"],
        ["key2", "value2"],
        ["key3", "value3"]
    skin: "listSkin",
    focusSkin: "listFSkin"
var listLayout = {
    widgetAlignment: constants.WIDGET_ALIGN_CENTER,
    padding: [0, 0, 0, 0],
    margin: [0, 0, 0, 0],
    containerWeight: 40,
    hExpand: false
var listPSP = {};
//Creating the Listbox
var listbx = new voltmx.ui.ListBox(listBasic, listLayout, listPSP);
//Reading the id of the listbox
alert("listbox Id ::" + listbx.id);
info Property
A custom JSObject with the key value pairs that a developer can use to store the context with the widget. This will help in avoiding the globals to most part of the programming.
Note: This is a non-Constructor property. You cannot set this property through widget constructor. But you can read and write data to it.
Info property can hold any JSObject. After assigning the JSObject to info property, the JSObject should not be modified. For example,
var inf = {
    a: 'hello'
widget.info = inf; //works
widget.info.a = 'hello world'; //This will not update the widget.info property to Hello world. widget.info.a will have old value as hello.
Syntax
info
Type
JSObject
Read/Write
Yes - (Read and Write)
Example
//Sample code to set info property for a ListBox widget.
frmList.myList.info = {
    key: "listboxitems"
//Reading the info of the ListBox widget.
voltmx.print("Map widget info:" +frmList.myList.info);
Accessible from IDE
No
inputAccessoryViewType Property
While building iPhone applications that support or provide text input, it is necessary to create some extra buttons (or other controls) beyond the ones provided by the default keyboard interface. VoltMX Iris by default, adds the Previous, Next, and Done buttons to the applicable input controls. These buttons allow specific operations needed by your application, such as moving to the next or previous text field, making the keyboard disappear and so on. The area above the keyboard is known as Input Accessory View.
Syntax
Type
Number
Read/Write
Yes
Remarks
The default value for this property is LISTBOX_INPUTACCESSORYVIEW_DEFAULT.
This property, allows you to specify the type of accessory view that will be shown for all the input controls for Listbox widget.
Note: For iOS, a header with 'Prev' and Next' buttons is added to the keypad by default. You can turn off this header at three levels: application-level, form-level, and widget-level.
To know more about how to set inputAccessoryViewType property at application-level and form-level, you can refer the inputAccessoryViewType property under Flexform widget.
To turn on/off the header at widget-level, assign any of the following constants to inputAccessoryViewType property. You must specify each constant with the ‘constants.xx’ prefix.
  • LISTBOX_INPUTACCESSORYVIEW_NONE: Use this option if you do not want to specify the toolbar. This option should be used carefully, as setting this option for widgets like calendar leaves the user with no option to select and drop-down a wheel calendar.
  • LISTBOX_INPUTACCESSORYVIEW_DEFAULT: Specifies that the toolbar that is defined in the Application level settings. To set the Application level settings, right-click on the project and navigate to Properties> Native App>iPhone/iPad.
  • LISTBOX_INPUTACCESSORYVIEW_NEXTPREV: Specifies the navigation options as Next, Previous, and Done for a form.
  • LISTBOX_INPUTACCESSORYVIEW_CANCEL: Specifies that the input accessory view has a Cancel button. This option does not trigger any events.
Example
//Sample code to set inputAccessoryViewType property for a ListBox widget.
frmList.myList.inputAccessoryViewType= constants.LISTBOX_INPUTACCESSORYVIEWTYPE_DEFAULT;
  • iPhone
  • iPad
isVisible Property
This property controls the visibility of a widget on the form.
Default: true
If set to false, the widget is not displayed.
If set to true, the widget is displayed.
Syntax
isVisible
Type
Boolean
Read/Write
Remarks
You can also set the visibility of a widget dynamically from code using the setVisibility method.
Example
//Sample code to set isVisible property for a ListBox widget.
frmList.myList.isVisible= true;
Accessible from IDE
Yes
itemDisabledSkin Property
This property is used to set the skin for the disabled list items mentioned in the disabledKeys property. If you have not provided any value to the disabledKeys property, then even if you have set a value to the itemDisabledSkin property, no list item will be displayed with that skin.
Refer the table here to know the combinations of skins and disabledKeys and the priority in which they are displayed.
You can assign value to the itemDisabledSkin property when the value of viewType property is LISTBOX_VIEW_TYPE_EDITVIEW or LISTBOX_VIEW_TYPE_LISTVIEW.
Note: The itemDisabledSkin property is applicable only for the New CSS library mode. This property will not work in the legacy JS library mode.
Syntax
itemDisabledSkin
Type
String
The default skin of the disabled list item displays the text of the item in grey font color.
Read/Write
Read + Write
Limitations
  • You cannot assign border and background image to the itemDisabledSkin when the value of viewType property is LISTBOX_VIEW_TYPE_LISTVIEW. This is a native browser limitation.
Example
//Sample code to set the itemDisabledSkin property of a ListBox widget.
frmList.myList.itemDisabledSkin= "mydDisabledSkinValue";
  • Desktop Web
itemHoverSkin Property
This property is used to set the skin that is displayed when the mouse cursor moves around the the enabled list items inside the ListBox widget. itemHoverSkin property is not assigned to the list items set in the disabledKeys property.
You can assign value to the itemHoverSkin property when the value of viewType property is LISTBOX_VIEW_TYPE_EDITVIEW.
Note: The itemHoverSkin property is applicable only for the New CSS library mode. This property will not work in the legacy JS library mode.
Syntax
itemHoverSkin
Type
String
Read/Write
Read+Write
Remarks
  • When both hoverSkin and itemHoverSkin are applied to the ListBox widget, then itemHoverSkin takes priority. This means that instead of hoverSkin, itemHoverSkin is applied to all the enabled list items.
Example
//Sample code to set the itemHoverSkin property of a ListBox widget.
frmList.myList.itemHoverSkin= "myhoverSkinValue";
  • Desktop Web
itemNormalSkin Property
This property is used to set the skin for the enabled list items inside a ListBox widget. itemNormalSkin property is not assigned to the list items set in the disabledKeys property.
You can assign value to the itemNormalSkin property when the value of viewType property is LISTBOX_VIEW_TYPE_EDITVIEW or LISTBOX_VIEW_TYPE_LISTVIEW.
Note: The itemNormalSkin property is applicable only for the New CSS library mode. This property will not work in the legacy JS library mode.
Syntax
itemNormalSkin
Type
String
Read/Write
Read + Write
Limitations
  • You cannot assign border and background image to the itemNormalSkin when the value of viewType property is LISTBOX_VIEW_TYPE_LISTVIEW. This is a native browser limitation.
Example
//Sample code to set the itemNormalSkin property of a ListBox widget.
frmList.myList.itemNormalSkin = "myNormalSkinValue3";
  • Desktop Web
left Property
This property determines the lower left corner edge of the widget and is measured from the left bounds of the parent container.
The left property determines the position of the left edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
left
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the left property is measured from right edge of the left sibling widget.
Example
//Sample code to set the left property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.left = "50dp";
frmHome.widgetID.left = "10%";
frmHome.widgetID.left = "10px";
lockTextScroll Property
This property allows you to enable/disable the horizontal scrolling for the selected item in the ListBox Widget.
Syntax
lockTextScroll
Type
Boolean
Read/Write
Remarks
Default:false
If set to true, the scrolling for the selected item is disabled
If set to false, the scrolling for the selected item is enabled
Example
//Sample code to set lockTextScroll property for a ListBox widget.
frmList.myList.lockTextScroll = true;
Accessible from IDE
No
masterData Property
Specifies the set of values that must be displayed for the user to make a selection from the available choices.
Syntax
masterData
Type
Array
Read/Write
Yes (Read and Write)
Remarks
Default: User Defined (You must specify the key and the display value)
To specify the set of values, click the Ellipsis () button against the property to open the MasterData for ListBox window.
In the Master Data window, you can specify the Key, Display Value, i18N Key, and the Accessibility Config.
You can use the Selected column to specify the choice to be shown as selected when rendered. You can do this by selecting true against the choice that you wish to show as selected.
Select the Use as test data in preview mode option if you want to see the data you enter in the Master Data when you Quick Preview. (For more information on Quick Preview, see the VoltMX Iris User Guide.
If the key or the display value is null/nil, the value will not be listed as one of the available choices.
The accessibilityConfigObject is optional and the object should contain the keys as defined in the accessibilityConfig property.
//Format of the masterData property [ ["key1","value1",accessibilityConfigObject], ["key2","value2",accessibilityConfigObject], ["keyn","valuen",accessibilityConfigObject] ]
Example
//Sample code to set masterData property for a ListBox widget.
//Format of the masterData property with accessibility Object
var dataAccessibility=[
    ["key1", "value1", accessibilityConfigObject],
    ["key2", "value2", accessibilityConfigObject],
    ["keyn", "valuen", accessibilityConfigObject]
frmList.myList.masterData=dataAccessibility;
//Format of the masterData property without accessibility Object
var dataList = [
    ["key1", "value1"],
    ["key2", "value2"],
    ["key3", "value3"]
frmList.myList.masterData= dataList;
Accessible from IDE
Yes
masterDataMap Property
Specifies the set of values from which you can make selections.You must specify a key and a value in a master data map.
Syntax
masterDataMap
Type
Array
Read/Write
Remarks
This is a non-Constructor property. You cannot set this property through widget constructor. But you can always read and write data to it.
This property is applicable only if the masterData is not set. You must use either the masterData or the masterDataMap to set data for the CheckBox.
You must specify a key, value, and the accessibilityConfig in a master data map.
The accessibilityConfig is the standard key expected in each items data array. It is optional and the object should contain the keys as defined in the accessibilityConfig property.
If the key or the value is null/nil, the value will not be listed as one of the available choices.
Example
//Sample code to set masterDataMap property for a ListBox widget.
//Format of the masterDataMap property without accessibility Object
var list = [
        "mykey": "key1",
        "myvalue": "value1"
        "mykey": "key2",
        "myvalue": "value2"
        "mykey": "key3",
        "myvalue": "value3"
    }], "mykey", "myvalue"
frmList.myList.masterDataMap=list;
//Format of the masterDataMap property with accessibility Object
var listAccessibility =[
        "mykey": "key1",
        "myvalue": "value1",
        "accessibilityConfig": acObject
        "mykey": "key2",
        "myvalue": "value2",
        "mykey": "key3",
        "myvalue": "value3",
    "mykey", "myvalue"
frmList.myList.masterDataMap= listAccessibility;
Accessible from IDE
No
maxHeight Property
This property specifies the maximum height of the widget and is applicable only when the height property is not specified.
The maxHeight property determines the maximum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxHeight value overrides the preferred, or “autogrow” height, if the maxHeight is less than the derived content height of the widget.
Syntax
maxHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxHeight = "50dp";
frmHome.widgetID.maxHeight = "10%";
frmHome.widgetID.maxHeight = "10px";
maxWidth Property
This property specifies the maximum width of the widget and is applicable only when the width property is not specified.
The Width property determines the maximum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxWidth value overrides the preferred, or “autogrow” width, if the maxWidth is less than the derived content width of the widget.
Syntax
maxWidth
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxWidth = "50dp";
frmHome.widgetID.maxWidth = "10%";
frmHome.widgetID.maxWidth = "10px";
minHeight Property
This property specifies the minimum height of the widget and is applicable only when the height property is not specified.
The minHeight property determines the minimum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minHeight value overrides the preferred, or “autogrow” height, if the minHeight is larger than the derived content height of the widget.
Syntax
minHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the minHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minHeight = "50dp";
frmHome.widgetID.minHeight = "10%";
frmHome.widgetID.minHeight = "10px";
minWidth Property
This property specifies the minimum width of the widget and is applicable only when the width property is not specified.
The minWidth property determines the minimum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minWidth value overrides the preferred, or “autogrow” width, if the minWidth is larger than the derived content width of the widget.
Syntax
minWidth
Type
Number
Read/Write
Read only
Example
//Sample code to set the minWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minWidth = "50dp";
frmHome.widgetID.minWidth = "10%";
frmHome.widgetID.minWidth = "10px";
multiSelect Property
Specifies if the widget allows multiple values to be selected from the drop down list.
Default: false
If set to true, an additional property multiSelectRows is displayed.
Syntax
multiSelect
Type
Boolean
Read/Write
No
Example
//Sample code to set multiSelect property for a ListBox widget.
frmList.myList.multiSelect=true;
Accessible from IDE
Yes
This property is available on Desktop Web
multiSelectRows Property
Specifies the number of visible rows in the ListBox. A ListBox in Desktop Web can grow to any length. This property is used to restrict the number of rows visible in a ListBox.
Note: This property is displayed only when the multiSelect is set to true.
Default:
none
Syntax
multiSelectRows
Type
Number
Read/Write
Example
//Sample code to set multiSelectRows property for a ListBox widget.
frmList.myList.multiSelectRows=5;
Accessible from IDE
Yes
nativeListFieldSkin Property
Specifies the skin that is applied to each item in the native popup that appears when you click on the ListBox.
Syntax
nativeListFieldSkin
Type
String
Read/Write
Example
//Sample code to set nativeListFieldSkin property for a ListBox widget.
frmList.myList.nativeListFieldSkin="nativeListNormalSkin";
Accessible from IDE
Yes
  • Android
nativeListFieldFocusSkin Property
Specifies the skin that is applied to a focused item in the native popup that appears when you click on the ListBox.
Syntax
Type
String
Read/Write
Example
//Sample code to set nativeListFieldFocusSkin property for a ListBox widget.
frmList.myList.nativeListFieldFocusSkin="nativeListFSkin";
Accessible from IDE
Yes
  • Android
opacity Property
Specifies the opacity of the widget. The value of this property must be in the range 0.0 (transparent) to 1.0 (opaque). Any values outside this range are fixed to the nearest minimum or maximum value.
Specifies the opacity of the widget. Valid opacity values range from 0.0 (transparent), to 1.0 (opaque). Values set to less than zero will default to zero. Values more than 1.0 will default to 1. Interaction events set on a transparent widget will still be fired. To disable the events, also set the “isVisible” property to “false”.
Syntax
opacity
Type
Number
Read/Write
Read + Write
Remarks
Note: This property has more priority compared to the values coming from the configured skin.
Example
//Sample code to make the widget transparent by using the opacity property.
frmHome.widgetID.opacity = 0;
//Sample code to make the widget opaque by using the opacity property.
frmHome.widgetID.opacity = 1;
  • Not available in the IDE.
padding Property
This property defines the space between the content of the widget and the widget boundaries. You can use this option to define the top, left, right, and bottom distance between the widget content and the widget boundary.
When you are defining the padding (for any platform) the first time, the value that you enter in the padding field (top, left, right, or bottom) is auto-populated across all the platforms.
The following image illustrates a widget with a defined padding:
Syntax
padding
Type
Array of Numbers
Read/Write
Remarks
Due to Browser restrictions, you cannot apply Padding for a ListBox on Mobile Web platform.
If no skin is applied to a Button, then Padding is not supported on iPhone. This is due to iOS Safari browser limitation. If you want the padding to be applied, apply a skin to the button and then apply padding.
Example
//Sample code to set padding property for a ListBox widget.
frmList.myList.padding=[10, 10, 10, 0];
  • Available in IDE
paddingInPixel Property
Indicates if the padding is to be applied in pixels or in percentage.
Default: false
If set to true, the padding is applied in pixels.
If set to false, the padding is applied as set in padding property.
Note: This property can be set to true or false only for iPhone, iPad, and Android. On other platforms this property does not give any results even when set to true.
Note: For backward compatibility on older projects, this property is will be made true for iPhone, iPad, and Android and for other platforms it will be false.
Syntax
paddingInPixel
Type
Boolean
Read/Write
Read only
Example
//Sample code to set paddingInPixel property for a ListBox widget.
frmList.myList.paddingInPixel =true;
parent Property
Helps you access the parent of the widget. If the widget is not part of the widget hierarchy, the parent property returns null.
Syntax
parent
Read/Write
Read only
Remarks
Note: The property works for all the widgets inside a FlexForm, FlexContainer or FlexScrollContainer.
Example
function func() {
    voltmx.print("The parent of the widget" + JSON.stringify(Form1.widgetID.parent));
placeholder Property
Specifies the temporary or substitute text (a hint provided as a word or phrase) that must be displayed on the ListBox until the actual selection is made. If you do not specify the placeholder text, the first option in the list is shown as the selected value.
If placeholder is set then by default (without user selecting any option) selectedKey and selectedKeyValue properties will return null/nil.
If placeholder is not set then by default the first entry should be shown as selected and selectedKey and selectedKeyValue properties will return the first options key-value pair.
Syntax
placeholder
Type
String
Read/Write
Example
//Sample code to set placeholder property for a ListBox widget.
frmList.myList.placeholder="Please select a value";
Accessible from IDE
Yes
  • iPad
  • iPhone
  • Android
placeholderSkin Property
This property reads the font color set in the skin and ignores the other attributes.Android does not support setting a background color for a placeholder.
Syntax
placeholderSkin
Type
String
Read/Write
Example
//Sample code to set placeholderSkin property for a ListBox widget.
frmList.myList.placeholderSkin="plcHolderSkn";
Accessible from IDE
Yes
This property is available on Android/Android Tablet platform only.
popupIcon Property
Specifies the icon that appears in the title area of the popup (on the top left side of the popup). For the popup to appear, you have to expand or click the Listbox.
Syntax
popupIcon
Type
Read/Write
No
Remarks
Default: empty
The figure below depicts how a Popup Icon in a List Box looks:
Example
Using a local resource for the popup icon:
/*Sample code to set the popupIcon property of a ListBox widget where icon.png is an image file in the resources folder.*/
frmList.myList.popupIcon="icon.png";
Using an image object (voltmx.image) for the popup icon:
/*Sample code to set the popupIcon property of a ListBox widget where local.png is an image file in the resources folder.*/
var imgObjRef = voltmx.image.createImage("local.png");
frmList.myList.popupIcon=imgObjRef;
Accessible from IDE
  • Android
popupTitle Property
Specifies the Title text to be displayed for the Listbox.
Default:Please Select (This is the default text that will appear as the title of the Listbox)
Syntax
popupTitle
Type
String
Read/Write
No
Example
//Sample code to set the popupTitle property of a ListBox widget.
frmList.myList.popupTitle="List of items";
Accessible from IDE
Yes
  • Android
popupTitleBackgroundColor Property
The property helps you change the background color of the ListBox title.
You can specify the color in the RGBA hex format. The format could be 0xRGBA or RGBA. The RGBA format followed is the standard RGBA format and is not the same as the RGBA color code generated by VoltMX Iris IDE for skins.
For example, the formats, 0xFF0000FF and FF0000FF are valid for red.
Syntax
Type
String
Read/Write
Read + Write
Example
//Sample code to set the popupTitleBackgroundColor property of a ListBox widget.
frmList.myList.popupTitleBackgroundColor = "ff0000ff";
  • Android
pressedStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is pressed or clicked.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the pressedSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the pressedStateSkinProperties property.
Form1.btn1.pressedStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
retainContentAlignment Property
This property is used to retain the content alignment property value, as it was defined.
Note: Locale-level configurations take priority when invalid values are given to this property, or if it is not defined.
The mirroring widget layout properties should be defined as follows.
function getIsFlexPositionalShouldMirror(widgetRetainFlexPositionPropertiesValue) {
    return (isI18nLayoutConfigEnabled &&
    localeLayoutConfig[defaultLocale]
    ["mirrorFlexPositionalProperties"] == true &&
    !widgetRetainFlexPositionPropertiesValue);
The following table illustrates how widgets consider Local flag and Widget flag values.
Properties Local Flag Value Widget Flag Value Action
Mirror/retain FlexPositionProperties true true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties true false Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties true not specified Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties false true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties false false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties false not specified Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties not specified false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified not specified Use the Design/Model-specific default layout.
Syntax
Type
Boolean
Read/Write
No (only during widget-construction time)
Example
//Here, we have shown how to use the retainContentAlignment property for Button widget.
retainContentAlignment property for other applicable widgets.*/
var btn = new voltmx.ui.Button({
    "focusSkin": "defBtnFocus",
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "skin": "defBtnNormal",
    "text": "text always from top left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_TOP_LEFT,
    "displayText": true,
    "padding": [0, 0, 0, 0],
    "paddingInPixel": false,
    "retainFlexPositionProperties": false,
    "retainContentAlignment": true
  • Available in IDE
  • iOS, Android, and SPA
retainFlexPositionProperties Property
This property is used to retain flex positional property values as they were defined. The flex positional properties are left, right, and padding.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlexPositionProperties property for Button widget.
retainFlexPositionProperties property for other applicable widgets.*/
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "text": "always left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_CENTER,
    "retainFlexPositionProperties": true,
    "retainContentAlignment": false
  • Available in IDE
retainFlowHorizontalAlignment Property
This property is used to convert Flow Horizontal Left to Flow Horizontal Right.
Syntax
Type
Boolean
Read/Write
Example
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the retainFlowHorizontalAlignment property for Button widget.
/*You need to make a corresponding use of the
retainFlowHorizontalAlignment property for other applicable widgets. */
 "height": "50dp",
 "id": "myButton",
 "isVisible": true,
 "left": "0dp",
 "top": "0dp",
 "width": "260dp",
 "zIndex": 1
 "retainContentAlignment": false,
 "retainFlowHorizontalAlignment ": false
  • Available in IDE
right Property
This property determines the lower right corner of the widget and is measured from the right bounds of the parent container.
The right property determines the position of the right edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, value is ignored. In flow-horizontal layout, the value is ignored.
The right property is used only if the width property is not provided.
Syntax
right
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the right property is measured from left edge of the right sibling widget. The horizontal space between two widgets is measured from right of the left sibling widget and left of the right sibling widget.
Example
//Sample code to set the right property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.right = "50dp";
frmHome.widgetID.right = "10%";
frmHome.widgetID.right = "10px";
Platform Availability
selectedKey Property
Represents the key that is shown as selected.
If you do not select a value, the return value is null/nil.
Syntax
selectedKey
Type
String
Read/Write
Example
//Sample code to set the selectedKey property of a ListBox widget.
frmList.myList.masterData = [
 ["key1", "value1"],
 ["key2", "value2"],
 ["key3", "value3"]
frmList.myList.selectedKey = "key1";
Accessible from IDE
No
selectedKeys Property
Returns the keys from the data representing the selected keys.
If you set the selectedkeys to null/nil, the selection is cleared.
Syntax
selectedKeys
Type
Array
Read/Write
Example
//Sample code to set the selectedKeys property of a ListBox widget.
 ["key1", "value1"],
 ["key2", "value2"],
 ["key3", "value3"]
frmList.myList.selectedKeys = ["key1", "key2"];
Accessible from IDE
No
Available on Desktop Web platform only
selectedKeyValue Property
Returns the array of selected key-value pair.
Syntax
selectedKeyValue
Type
Array
Read/Write
Yes - (Read only)
Example
//Sample code to read the selectedKeyValue property of a ListBox widget.
 ["key1", "value1"],
 ["key2", "value2"],
 ["key3", "value3"]
alert("The selected key value of the listbox is::"+frmList.myList.selectedKeyValue);
Accessible from IDE
No
selectedKeyValues Property
Returns the array of selected key-value pair from the data representing the selected key and value.
Syntax
selectedKeyValues
Type
Array
Read/Write
Yes - (Read only)
Example
//Sample code to read the selectedKeyValues property of a ListBox widget.
 ["key1", "value1"],
 ["key2", "value2"],
 ["key3", "value3"]
alert("The selected key value of the listbox is::"+frmList.myList.selectedKeyValues);
Accessible from IDE
No
shadowColor Property
Specifies the color for the shadow of the widget.
Syntax
shadowColor
Type
Color constant or Hexadecimal number
Read/Write
Read + Write
Remarks
  • Colors can be specified using a 6 digit or an 8-digit hex value with alpha position. For example, ffff65 or ffffff00.
  • When the 4-byte color format (RGBA) string is used, an alpha (A) value of 65 specifies that the color is transparent. If the value is 00, the color is opaque. The Alpha value is in percentage and must be given in the hexadecimal value for the color (100% in hexadecimal value is 65).
    For example, red complete opaque is FF000000. Red complete transparent is FF000065. The values 0x and # are not allowed in the string.
  • A color constant is a String that is defined at the theme level. Ensure that you append the $ symbol at the beginning of the color constant.
  • This property does not have a default value.
  • This property has more priority than (and overrides) the shadow property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowColor property.
Form1.btn1.shadowColor = "ea5075";
  • iOS
  • Desktop Web (Not available on Desktop Web Legacy SDK)
shadowDepth Property
Defines the depth of the shadow effect applied to the ListBox Widget.
Syntax
shadowDepth
Type
Number
Read/Write
Read + Write
Remarks
The depth of the shadow should be specified in DP (Device Independent Pixels) units. The higher the value of shadowDepth, the appearance of the ListBox Widget is elevated from the screen and the casted shadow becomes soft.
Example
 //Sample code to set the shadowDepth property of a ListBox widget.
frmList.myList.shadowDepth = 10;
  • Android 5.0 and later versions.
shadowOffset Property
This property specifies the current coordinates of the shadow region in the widget.
Syntax
shadowOffset
Type
JSON Object
Read/Write
Read + Write
Remarks
  • The JSON Object contains the X-coordinate and Y-coordinates for the offset in the following format:
    {x: value in pixels, y: value in pixels}
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowOffset property.
Form1.btn1.shadowOffset= {
    "x": "3",
    "y": "27"
  • iOS
shadowRadius Property
Specifies the radius for the blur value of the shadow.
Syntax
shadowRadius
Type
Number
Read/Write
Read + Write
Remarks
  • The default value of the shadowRadius property for a Responsive Web app is 0.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowRadius property.
 Form1.btn1.shadowRadius = 6;
  • iOS
shadowType Property
Sets a type of the shadow effect to apply to the ListBox Widget.
Syntax
shadowType
Type
Number
Read/Write
Read + Write
Remarks
The property specifies a shape to the widget's shadow that is cast. You can apply any one of the following shadow types:
VIEW_BOUNDS_SHADOW: Shadow matches the widget's rectangular bounds.
PADDED_VIEW_BOUNDS_SHADOW: Shadow matches the widget's rectangular padded bounds.
BACKGROUND_SHADOW: Shadow matches the widget's background. This is the default value.
Example
//Sample code to set shadowType property of a ListBox widget.
frmList.myList.shadowType = constants.VIEW_BOUNDS_SHADOW;
showAppMenu Property
This property provides you to show or hide the app menu when the dialog is open.
Default:true
When this property is set to true, the app menu is visible.
When this property is set to false, the app menu is hidden.
Syntax
showAppMenu
Type
Boolean
Read/Write
Example
//Sample code to set the showAppMenu property of a ListBox widget.
frmList.myList.showAppMenu=true;
Accessible from IDE
No
singleLineText Property
When the singleLineText property is set to 'true', this property controls the position of the ellipses (...), in the selected option text.
Default:False
Syntax
singleLineText
Type
Boolean
Read/Write
Example
//Sample code to set the singleLineText property of a ListBox widget.
frmList.myList.singleLineText=true;
Accessible from IDE
No
  • Android/Android tablet
singleLineTextInPopup Property
When thIS property is set to true, this property controls the position of the ellipses (...), in the popup options text.
Default:False
Syntax
Type
Boolean
Read/Write
Example
//Sample code to set the singleLineTextInPopup property of a ListBox widget.
frmList.myList.singleLineTextInPopup=true;
Accessible from IDE
No
skin Property
Specifies a background skin for ListBox widget.
Note: For Desktop Web platform, Chrome browser does not support if the properties defined in font tab are different for skin and focusSkin.
Note: For iOS platform, only background color is supported.
Syntax
skin
Type
String
Read/Write
Example
//Sample code to set the skin property of a ListBox widget.
frmList.myList.skin="listSkin";
Accessible from IDE
Yes
textShadowColor Property
Specifies the color for the text shadow of the widget.
Syntax
textShadowColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the textShadow property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowColor property.
Form1.btn1.textShadowColor = "ea5075";
  • Android
  • iOS
textShadowOffset Property
This property specifies the current coordinates of the text shadow region in the widget.
Syntax
textShadowOffset
Type
JSON Object
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowOffset property.
Form1.btn1.textShadowOffset = {
    "x": "2",
    "y": "24"
  • Android
  • iOS
textShadowRadius Property
Specifies the radius for the blur value of the text shadow.
Syntax
textShadowRadius
Type
Number
Read/Write
Read + Write
Remarks
  • The default value of the textShadowRadius property for a Responsive Web app is 0.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowRadius property.
 Form1.btn1.textShadowRadius = 6;
  • Android
  • iOS
textTruncatePosition Property
If the length of the text is more than the available space, the selected options text and the popup options text are displayed in a truncated manner, in a single line with ellipses (...). The position of the ellipses is controlled by the textTruncatePosition property. The default ellipses position is at the end of the line if textTruncatePosition property is not set.
Syntax
Type
Number
Read/Write
Remarks
The options are:
constants.TEXT_TRUNCATE_START
constants.TEXT_TRUNCATE_MIDDLE
constants.TEXT_TRUNCATE_END
constants.TEXT_TRUNCATE_NONE (This value is applicable only for iOS.)
Default Value:
  • For Android: constants.TEXT_TRUNCATE_END
  • For iOS: constants.TEXT_TRUNCATE_MIDDLE
Example
//Sample code to set the textTruncatePosition property of a ListBox widget.
frmList.myList.textTruncatePosition= constants.TEXT_TRUNCATE_MIDDLE;
Accessible from IDE
No
  • iOS
textTruncatePositionInPopup Property
If the length of the text is more than the space available, the popup options text will be displayed truncated, in a single line with (...) ellipses. The position of the ellipses is controlled by textTruncatePositionInPopup property. The default ellipses position is at the end of the line if textTruncatePositionInPopup property is not set.
Syntax
Type
Number
Read/Write
Remarks
The options are:
Default:constants.TEXT_TRUNCATE_END
Accessible from IDE
No
Example
//Sample code to set the textTruncatePositionInPopup property of a ListBox widget.
frmList.myList.textTruncatePositionInPopup= constants.TEXT_TRUNCATE_MIDDLE;
Accessible from IDE
No
tickedImage Property
Specifies the image to be displayed when you make a selection.
Syntax
tickedImage
Type
Read/Write
No
Remarks
Note: If you specify a ticked Image, ensure that you also specify an unTickedimage. If not specified, the behavior will be undefined.
Note: You can create an image Object by using voltmx.image Namespace functions.
Example
Using a string to define a local resource for the image:
 /*Sample code to set the tickedImage property of a ListBox widget where tickImg.png is an image file in the resources folder.*/
frmList.myList.tickedImage="tickImg.png";
Using an image object (voltmx.image) to define the image:
 /*Sample code to set the tickedImage property of a ListBox widget where local.png is an image file in the resources folder.*/
frmList.myList.tickedImage=imgObjRef;
Accessible from IDE
  • iOS
  • Android
titleAlignment Property
The property helps you align the title of the ListBox Widget.
Syntax
titleAlignment
Type
Number
Read/Write
Read + Write
Remarks
The following are the possible values that you can specify for the property.
  • LISTBOX_TITLE_ALIGN_LEFT - Aligns the title to left. This is the default value.
  • LISTBOX_TITLE_ALIGN_CENTER - Aligns the Title to center.
  • LISTBOX_TITLE_ALIGN_RIGHT - Aligns the Title to right.
Note: If you specify any value other than the preceding values, the default value is set.
Example
//Sample code to set the titleAlignment property of a Listbox widget.
frmList.myList.titleAlignment = constants.LISTBOX_TITLE_ALIGN_RIGHT;
  • Android
titleIconAlignment Property
The property helps you align the title icon of the ListBox Widget.
Syntax
titleIconAlignment
Type
Number
Read/Write
Read + Write
Remarks
  • LISTBOX_TITLE_ICON_ALIGN_LEFT - Aligns the Title icon to the left. This is the default value.
  • LISTBOX_TITLE_ICON_ALIGN_RIGHT - Aligns the Title icon to the right.
Example
//Sample code to set the titleIconAlignment property of a ListBox widget.
frmList.myList.titleIconAlignment = constants.LISTBOX_TITLE_ICON_ALIGN_RIGHT;
  • Android
toolTip Property
Specifies the hint text when the cursor hovers over a widget, without clicking it. The text entered in the tooltip appears as a small box when the cursor hovers over a widget.
Syntax
toolTip
Type
String
Read/Write
Example
//Sample code to set the toolTip property of a ListBox widget.
frmList.myList.toolTip= "sample text";
Accessible from IDE
Yes
top Property
This property determines the top edge of the widget and measured from the top bounds of the parent container.
The top property determines the position of the top edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy. In flow-horizontal layout, the distance is measured from the left edge of the parent container.
Syntax
top
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the top property is measured from the bottom edge of the top sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and top of the bottom sibling widget.
Example
//Sample code to set the top property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.top = "50dp";
frmHome.widgetID.top = "10%";
frmHome.widgetID.top = "10px";
  • iOS, Android, SPA and Desktop Web
transform Property
Contains an animation transformation that can be used to animate the widget.
Syntax
transform
Type
JSObject
Read/Write
Read + Write
Remarks
This property is set to the identify transform by default. Any transformations applied to the widget occur relative to the widget's anchor point. The transformation contained in this property must be created using the voltmx.ui.makeAffineTransform function.
Example
This example uses the button widget, but the principle remains the same for all widgets that have a transform property.
//Animation sample
var newTransform = voltmx.ui.makeAffineTransform();
newTransform.translate3D(223, 12, 56);
//translates by 223 xAxis,12 in yAxis,56 in zAxis
widget.transform = newTransform;
  • iOS, Android and SPA
unTickedImage Property
Specifies the image to be displayed when a selection is cleared.
Syntax
unTickedImage
Type
Read/Write
No
Remarks
Note: If you specify an unTickedImage, ensure that you also specify a tickedImage. If not specified, the behavior will be undefined.
Example
Defining the image using a local resource:
 /*Sample code to set the untickedImage property of a ListBox widget where untickImg.png is an image file in the resources folder.*/
frmList.myList.untickedImage="untickImg.png";
Defining the image using an image object (voltmx.image):
 /*Sample code to set the untickedImage property of a ListBox widget where local.png is an image file in the resources folder.*/
frmList.myList.untickedImage=imgObjRef;
Accessible from IDE
  • iOS
  • Android
vExpand Property
Specifies if the widget has to occupy all the vertical space available to it.
Syntax
vExpand
Type
Boolean
Read/Write
No
Remarks
Default:false
  • If set to true, the widget occupies the entire available height.
  • If set to false, the widget occupies the preferred height.
Widget when the Expand vertical is set to true
Example
//Sample code to set the vExpand property of a ListBox widget.
frmList.myList.vExpand=true;
Accessible from IDE
Yes
viewConfig Property
Specifies the view configuration for different viewtypes.
Syntax
viewConfig
Type
JSObject
Read/Write
Remarks
You can set the configuration for toggle view.
toggleViewConfig: The property to configure the properties of LISTBOX_VIEW_TYPE_TOGGLEVIEW.
viewStyle: Accepts the view style. This property is not supported in iOS7 and above versions. Following are the available options:
LISTBOX_TOGGLE_VIEW_STYLE_PLAIN
LISTBOX_TOGGLE_VIEW_STYLE_BORDERED
LISTBOX_TOGGLE_VIEW_STYLE_BAR
equalSegments: Specifies the boolean value which indicates if the segments must be equal.
enableTint: Specifies the boolean value to enable tintColor property. When this property is set to true, tintColor property is displayed.
tintColor: Specifies the tint color in RGB format. The default color is blue.
Example
//Sample code to set the viewConfig property of a ListBox widget.
frmList.myList.viewConfig = {
 toggleViewConfig: {
  equalSegments: true
Accessible from IDE
Yes
  • iPad
  • iPhone
viewType Property
Specifies the view type of the ListBox.
Syntax
viewType
Type
Number
Read/Write
Remarks
Default: LISTBOX_VIEW_TYPE_LISTVIEW
Following are the available options on various platforms:
LISTBOX_VIEW_TYPE_LISTVIEW (applicable on all platforms)
LISTBOX_VIEW_TYPE_TABLEVIEW (applicable on iPhone and iPad platforms)
LISTBOX_VIEW_TYPE_TOGGLEVIEW (applicable on iPhone and iPad platforms)
LISTBOX_VIEW_TYPE_ONSCREENWHEEL (applicable on iPhone and iPad platforms)
LISTBOX_VIEW_TYPE_SPINNER (applicable on Android/Android Tablet only)
LISTBOX_VIEW_TYPE_EDITVIEW (applicable on Desktop Web only)
For toggleView you can further select the View Style as plain, bordered, or bar.
The following images illustrate the modes:
listView
If you select the listView and do not specify a selection in the masterData, the default behavior of the platform is to select the first entry on the list.
Figure illustrating List View
tableView
Figure Depicting Table View
toggleView
Toggle View - Plain
Toggle View - Bordered
Toggle View - Bar
onscreenwheel
on screen wheel
spinner
The below image illustrate the nextprevtoolbar set to a listbox. The highlighted toolbar is achieved on setting the Mode as onscreenwheel to the List Box and Input Accessory View Type as nextprevtoolbar to the Form.
For editview viewType
  • Users can use this viewType to change the colour of a drop-down item on hover, which is not possible with the select attribute provided by.html for list. You can customize drop-down items to a great extent and use this to cater to the needs of users with respect to drop-down type widgets in a better manner. This is applicable only for Desktop Web.
  • Assumptions:
    • The ListBox widget has to be dynamically created in order to use the editview viewType, which is defined as a platform-specific property (pspconfig) for this widget.
    • You can update masterData, selectedKey, editableAreaSkin, viewtType, and autoSuggest.
  • Limitations:
    • The editview viewType is available only in Desktop Web.
    • The editview viewType supports only single select, so there is no option of selectedKeys.
Example (for editview)
//Sample code to set the viewType property of a ListBox widget as editview.
//This is applicable only for Desktop Web platform.
frmList.myList.viewType = constants.LISTBOX_VIEW_TYPE_EDITVIEW;
Example (for changing the color of a drop-down item on hover)
div[name="SelectOptionList"]:hover
  background-color:" #800000" !important;
    color: "#FFFFFF";
} //Creating a custom CSS of background color (Maroon)
Example (for viewType)
//Sample code to set the viewType property of a ListBox widget as LISTBOX_VIEW_TYPE_SPINNER.
frmList.myList.viewType = constants.LISTBOX_VIEW_TYPE_SPINNER;
Accessible from IDE
Yes
  • iPad
  • iPhone
  • Android/Android Tablet ( only Spinner view is available for the platform)
wheelBackgroundColor Property
Specifies the background color for the wheel that is displayed when you click the ListBox. This property is applicable only when you set the viewType as LISTBOX_VIEW_TYPE_ONSCREENWHEEL.
Syntax
Type
JSObject
Read/Write
Example
//Sample code to set the wheelBackgroundColor property of a ListBox widget.
frmList.myList.wheelBackgroundColor="0000ff00";
Accessible from IDE
No
  • iPad
  • iPhone
widgetAlignment Property
Indicates how a widget is to be anchored with respect to its parent. Each of these below options have a horizontal alignment attribute and a vertical alignment attribute. For example, WIDGET_ALIGN_TOP_LEFT specifies the vertical alignment as TOP and horizontal alignment as LEFT.
Default: WIDGET_ALIGN_CENTER
The available options are:
  • WIDGET_ALIGN_TOP_LEFT
  • WIDGET_ALIGN_TOP_CENTER
  • WIDGET_ALIGN_TOP_RIGHT
  • WIDGET_ALIGN_MIDDLE_LEFT
  • WIDGET_ALIGN_CENTER
  • WIDGET_ALIGN_MIDDLE_RIGHT
  • WIDGET_ALIGN_BOTTOM_LEFT
  • WIDGET_ALIGN_BOTTOM_CENTER
  • WIDGET_ALIGN_BOTTOM_RIGHT
Syntax
widgetAlignment
Type
Number
Read/Write
No
Example
//Sample code to set the widgetAlignment property of a ListBox widget.
frmList.myList.widgetAlignment=constants.WIDGET_ALIGN_CENTER;
Accessible from IDE
Yes
widgetSwipeMove Property
This property is used to enable and configure left or right swipe actions for a widget. The widgetSwipeMove Property can be used for all widgets . The most common use case is for implementing swipe action for individual rows in Segment.
Syntax
widgetSwipeMove
Type
String
Read/Write
Read + Write
Input Parameters
Parameter Name Type Default Value Description
translate Boolean true This is an optional parameter. When the value of this parameter is set as true, the widget moves along with the swipe in the same direction.
Xboundaries Array Size of the current widget This is an optional parameter and it defines the boundaries of the swipe in the X-axis.
swipeLeft/swipeRight JS Object   This is an optional parameter and it is used to define the configuration of the widget while swiping to the left/ right. Each swipeLeft or swipeRightparameter is an array of configuration attributes containing translateRange , callback , translatePos , and translate. This JS Object defines the behavior of the widget during the swipe action.
translateRange Array Size of the current widget This is an optional parameter and it defines the sub-boundaries for the action when the swipe action ends.
translatePos Array Previous position of the widget This is an optional parameter and it determines the final translation position to be applied to the widget when the widget swipe reaches the translateRange value.
callback JS Object null This is an optional parameter and it defines the callback which needs to be triggered when the finger swipe reaches the sub boundary defined in translateRange. The attributes inside this parameter are described in the following table.
The following table consists of the parameters of the callback parameter:
Parameter Name Type Description
widgetHandle   This parameter consists of the widget handle or ID of the widget on which the swipe action has been performed.
context JS Object This is applicable only for widgets inside the Segment with row templates. Each context parameter consists of rowIndex, sectionIndex and widgetref
rowIndex Number This parameter stores the row index of the Segment containing the swiped widget.
sectionIndex Number This parameter stores the section index of the Segment containing the swiped widget.
widgetref widgetHandle This parameter stores the handle of the Segment containing the swiped widget.
Remarks
  • For a Segment, the widgetSwipeMove Property is configured while setting the data of the Segment.
Note: It is not recommended to assign the widgetSwipeMove property on a top Flex container of the segment template widget.
Limitations
  • When a translation animation is applied to the same widget that has widgetSwipeMove already configured, the action which has been performed last takes precedence. For example, if you have set a translation animation on a FlexContainer and then set the widgetSwipeMove property, the actions set in widgetSwipeMove take precedence over the translation animation.
  • The state of the swipe transition of the widget is not retained.
  • In a Segment, the widgetSwipeMove Property must be configured for the rows so that they reset to the previous position.
  • If the widgetSwipeMove property is configured on a top level Flex container of a segment template, the onRowClick event will not be triggered. - Applicable on iOS, Android, and SPA.
  • Android limitation: On Android devices, when the user lifts their finger, the transition occurs immediately.
Example
Following is a code snippet for a mail app. Here we have used a Segment for listing the mail and the widgetSwipeMove Property has been configured for the SwipeFlex FlexContainer.
//Here, we have shown how to use the widetSwipeMove property for Button widget.
widgetSwipeMove property for other applicable widgets.*/
//Example of a swipe move configuration.
var swipeMoveConfig = {
 "translate": true,
 "Xboundaries": ["-60%", "60%"],
 "swipeLeft": [{
  "translateRange": ["-60%", "0%"],
  "callback": null,
  "translatePos": "-60%",
  "translate": true
  "translateRange": ["0%", "60%"],
  "callback": null,
  "translatePos": "0%",
  "translate": true
 "swipeRight": [{
  "callback": null,
  "translate": true
  "callback": this.onCallback1,
  "translatePos": "60%",
  "translate": true
this.view.myButton.widgetSwipeMove=swipeMoveConfig;
  • iOS, SPA
width Property
This property determines the width of the widget and is measured along the x-axis.
The width property determines the width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the width may be derived from either the widget or container’s contents by setting the width to “preferred”.
Syntax
width
Type
Read/Write
Read + Write
Remarks
Following are the options that can be used as units of width:
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred width of the widget as width and preferred size of the widget is determined by the widget and may varies between platforms.
Example
//Sample code to set the width property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.width = "50dp";
frmHome.widgetID.width = "10%";
frmHome.widgetID.width = "10px";
  • Available in the IDE
zIndex Property
This property specifies the stack order of a widget. A widget with a higher zIndex is always in front of a widget with a lower zIndex.
The zIndex property is used to set the stack, or layer order of a widget. Widgets with higher values will appear “over”, or “on top of” widgets with lower values. Widgets layered over other widgets will override any interaction events tied to widgets beneath. Modifying the zIndex does not modify the order of the widgets in the VoltMX Iris hierarchy, inside of a flexContainer or form. The zIndex property accepts only positive values.
Syntax
zIndex
Type
Number
Read/Write
Read + Write
Remarks
The default value for this property is 1.
Note: Modifying the zIndex does not modify the order of the widgets inside the FlexContainer. If zIndex is same for group of overlapping widgets then widget order decides the order of overlapping. The last added widget is displayed on top.
From VoltMX Iris V9 SP2 FP7, developers can configure the Z Index value for a Responsive Web app as Auto or Custom. When the selected Z Index value is Auto, the default Z Index value of 1 is applied. When the selected Z Index value is Custom, developers can specify a desired numeric value.
Prior to the V9 SP2 FP7 release, the default value for the Z Index was 1. When developers imported any third-party libraries with the Z index set as Auto, content overflow was disabled as the value of Auto is less than 1.
Note: The Z Index value Auto is supported only when the Enable JS Library mode is configured as unchecked.
For existing components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Custom with 1 as the value.
For new components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Auto or 1 based on the project level settings.
Note: If ModalContainer property is set to true in any of the FlexContainer widget, the Z Index value of that container and all of its parent containers should be set to Custom.
voltmx.flex.ZINDEX_AUTO : Constant to configure the Z Index value as auto programmatically.
//Sample code to set the ZIndex value to Auto
 var flx = new voltmx.ui.FlexContainer({
  "id": "flx"
  "zIndex": voltmx.flex.ZINDEX_AUTO
flx.zIndex = voltmx.flex.ZINDEX\_AUTO;
Example
//Sample code to set the zIndex property for widgets.
frmHome.widgetID.zIndex = 300;
  • iOS, Android,SPA and Desktop Web
