Skip to content
voltmx.automation Namespace
The voltmx.automation Namespace consists of the following API groups.
Widget APIs
Widget Path
Widget ID from root element (form, and master, etc.). Comma-separated strings from root to widget represented in an array. It is applicable for almost all widget APIs.
Note: When you build an app in Test Mode, if the app contains components (with contract), the programmatic names of the properties must be unique. Ensure that the properties do not have the same name as that of any child widgets in the component or the parent FlexContainer widget. If a property and a widget (child or parent) have the same name, the property will not be honored.
Note: Whenever a Segment row is a part of Widget path, it refers to the top level flex. This flex ID should not be provided in the subsequent path.
Syntax
<widgetpath> [array of strings];
Mandatory/Optional
Mandatory
Example
  • Each string denotes the widget ID in the hierarchy.
voltmx.automation.button.click(["frmHomeLogin", "btnLogin"]);
//Here, ["frmHomeLogin","btnLogin"]is the widget path.
  • The widget path string can consist of an array indexer for SegmentedUI widget to denote the corresponding row.
voltmx.automation.button.click(["frmHomeLogin", "segUi1[0,2]", "btnLogin"]);
voltmx.automation.button.click(["frmHomeLogin", "segUi1[2]", "btnLogin"]);
  • The widget path string can be a date for a Calendar cell template.
voltmx.automation.button.click(["frmHomeLogin", "calendar11[05,05,2016]", "btnLogin"]);
  • The widget path string can be the friendly name of a form.
voltmx.automation.button.click(["Login Page", "userwidget1", "btnLogin"]);
Platform Availability
  • Android
  • iOS
  • SPA and ResponsiveWeb
The voltmx.automation Namespace comprises the following Widget APIs.
voltmx.automation.actionSheet.click
Triggers the click event on the provided action item, if it is visible. If the action item is not available, this API returns the No matching actionItem found message.
Syntax
voltmx.automation.actionSheet.click("actionItemTitle");
Input Parameters
Parameters Description
actionItemTitle [string] [Mandatory] The name of the actionSheet item.
Example
Return Values
None
Remarks
Support for the record and playback features for this API is available from the V9 Service Pack 2 Fixpack 16 version of Volt MX Iris.
  • iOS
voltmx.automation.alert.click
Clicks the provided button, if visible, for the Alert. If multiple alerts are simultaneously shown, this API clicks the most recent alert displayed on the screen.
Syntax
voltmx.automation.alert.click(<buttonIndex>);
Input Parameters
buttonIndex [0 or 1] [Optional] Alert widget supports two buttons. This APIs triggers the click on the YES label if the index is 0, and it triggers the click on the NO label if the index is 1. If the alert type is information, this API triggers the click on the OK label if the index is 0. If you do not pass any buttonIndex, the API triggers the click on the NO label for confirmation alerts and the OK label for information alerts.
Example
voltmx.automation.alert.click(0);
Return Values
None
  • Android
  • iOS
Remarks
While using Jasmine Test Automation on the Adaptive Web or Responsive Web platforms, you can use the spyon API that is provided by Jasmine to gain more control over the alerts.
For Example, you can use the var spy = spyOn(window, '<method>').and.returnValue(<value>); code snippet to always return the value that you specify.
The value of and depend on the type of alert.
  • For information and error alerts, replace <method> with alert, and replace the <value> parameter with true.
  • For confirmation alerts, replace <method> with confirm, and replace the <value> parameter with either true or false.
Example
if("testcase", async function() { var spy = spyOn(window, 'confirm').and.returnValue(true); voltmx.automation.button.click(["Form", "btn"]); expect(spy).toBe(true); });
voltmx.automation.box.click
Triggers the Box click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.box.click (<widgetpath>);
Input Parameters
widgetpath [array of strings] [Mandatory] Widget ID from root element (form, and master, etc.). Comma-separated strings from root to widget represented in an array.
Example
voltmx.automation.box.click(["frmHomeLogin","boxId"]);
Return Values
None
  • Android
  • iOS
  • SPA and Responsive Web
Triggers the Button click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.button.click (<widgetpath>);
Input Parameters
Example
voltmx.automation.button.click(["frmHomeLogin","btnLogin"]);
voltmx.automation.button.click(["frmHomeLogin","segUi1[0,2]", "btnLogin"]);
voltmx.automation.button.click(["frmHomeLogin","segUi1[2]", "btnLogin"]);
Return Values
None
  • Android
  • iOS
voltmx.automation.calendar.selectDate
Triggers the Calendar click event on the specified widget, if it is visible and enabled.
Note: Supported view type is pop-up grid
Syntax
voltmx.automation.calendar.selectDate (<widgetpath>, <newDate>);
Input Parameters
newDate [array] [Mandatory] Array representation of a date in mm/dd/yyyy format as [mm, dd, yyyy] co-ordinate. This format is irrespective of the calendar format.
Example
voltmx.automation.calendar.selectDate(["frmHomeLogin","calenderId"], [12,15,2017]);
Return Values
None
Note: Automation is supported only for the Calendar default view.
  • Android
  • iOS
voltmx.automation.checkboxgroup.click
Triggers the CheckBoxGroup click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.checkboxgroup.click (<widgetpath>, <chkBoxKey>);
Input Parameters
chkBoxKey [array/integer] [Mandatory] CheckBoxGroup item that is to be clicked. > Note: The value of the chkBoxKey must be an Integer for the Table viewType. For all other viewTypes, the value of the chkBoxKey must be an array.
Example
voltmx.automation.checkboxgroup.click(["frmHomeLogin","checkboxgroupId"], "checkBoxKey");
Return Values
None
  • Android
  • iOS
voltmx.automation.flexcontainer.click
Triggers the FlexContainer click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.flexcontainer.click (<widgetpath>);
Input Parameters
Example
voltmx.automation.flexcontainer.click(["frmHomeLogin","flexContainerId"]);
Return Values
None
  • Android
  • iOS
voltmx.automation.listbox.selectItem
Triggers the ListBox click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.listbox.selectItem(<widgetpath>, <key>);
Input Parameters
key [string/integer] [Mandatory] Indicates the key in the ListBox for which item is to be clicked. > Note: The value of the key must be an Integer for the Table viewType. For all other viewTypes, the value of the key must be a string.
Return Values
None
Example
voltmx.automation.listbox.selectItem(["frmHomeLogin","listbox"], "key1");
  • Android
  • iOS
voltmx.automation.navigationBar.click
Triggers the click event on the barButton item of the navigation bar, if it is visible and enabled.
Syntax
voltmx.automation.navigationBar.click("barButtonId");
Input Parameters
barButtonId [string] [Mandatory] The ID of the BarButtonItem.
Return Values
None
Example
Remarks
  • iOS
voltmx.automation.radiobuttongroup.click
Triggers the RadioButtonGroup click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.radiobuttongroup.click(<widgetpath>, <key>);
Input Parameters
key [string/integer] [Mandatory] Radiobutton key that needs to be clicked. > Note: The value of the key must be an Integer for the Table viewType. For all other viewTypes, the value of the key must be a string.
Example
voltmx.automation.radiobuttongroup.click(["frmHomeLogin","rdBtnId"], "rdBtnkey");
Return Values
None
  • Android
  • iOS
voltmx.automation.segmentedui.click
Triggers the SegmentedUI click event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.segmentedui.click(<widgetpath>);
Input Parameters
Example
voltmx.automation.segmentedui.click(["frmHomeLogin","segmentedUIId[0,2]"]);
Return Values
None
Note: Automation is supported only for the Segment table view.
  • Android
  • iOS
voltmx.automation.segmentedui.pull
Triggers the onPull event on the SegmentedUI, if it is set.
Syntax
voltmx.automation.segmentedui.pull(<widgetpath>);
Input Parameters
Example
voltmx.automation.segmentedui.pull(["frmHomeLogin","segmentedUIId"]);
Return Values
None
  • Android
  • iOS
  • ResponsiveWeb
voltmx.automation.segmentedui.push
Triggers the onPush event on the SegmentedUI, if it is set.
Syntax
voltmx.automation.segmentedui.push(<widgetpath>);
Input Parameters
Example
voltmx.automation.segmentedui.push(["frmHomeLogin"," segmentedUIId "]);
Return Values
None
  • Android
  • iOS
  • ResponsiveWeb
voltmx.automation.segmentedui.scrollToRow
Triggers the segment to scroll to the row specified by the index of the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.segmentedui.scrollToRow(<widgetpath>);
Input Parameters
Example
voltmx.automation.segmentedui.scrollToRow(["frmHomeLogin"," segmentedUIId[12]"]);
voltmx.automation.segmentedui.scrollToRow(["frmHomeLogin"," segmentedUIId[1,3]"]);
Return Values
None
Remarks
The voltmx.automation.segmentedui.scrollToRow API does not work on the section header of the Segment.
  • Android
  • iOS
voltmx.automation.scrollToWidget
Scrolls to ensure that the widget appears in view. It is an awaitable API.
Syntax
voltmx.automation.scrollToWidget(<widgetpath>);
Input Parameters
Parameter Description
Example
await voltmx.automation.scrollToWidget(["frmHomeLogin","btnLogin"]);
Return Values
None
Note: If segment is a part of widgetpath, then it scrolls only to the segment.
  • Android
  • iOS
voltmx.automation.slider.slide
Triggers the Slider slide event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.slider.slide(<widgetpath>, <newValue>);
Input Parameters
newValue [number] [Mandatory] New slider value within a minimum and maximum range.
Example
voltmx.automation.slider.slide(["frmHomeLogin","sliderId"], 25);
Return Values
None
  • Android
  • iOS
voltmx.automation.switch.toggle
Toggles the Switch between ON/OFF on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.switch.toggle(<widgetpath>);
Input Parameters
Example
voltmx.automation.switch.toggle(["frmHomeLogin","switchId"]);
Return Values
None
  • Android
  • iOS
voltmx.automation.tabpane.click
Clicks the tab with the specified tabID on the TabPane widget, if it is visible and enabled.
Syntax
voltmx.automation.tabpane.click(<widgetpath>, <tabID>);
Input Parameter
tabID [string] [Mandatory] The tabID name.
Example
voltmx.automation.tabpane.click(["frmHomeLogin","tabpaneId"], ”tabId”);
Note: Automation is supported only for the TabPane default view.
Return Values
None
  • Android
  • iOS
voltmx.automation.textbox.enterText
Enters the specified text into the TextBox, if it is visible and enabled.
Syntax
voltmx.automation.textbox.enterText(<widgetpath>, <newText>, <Array of objects with options to raise an event>);
Input Parameters
newText [string] [Mandatory] New text to be set to the TextBox. Specify null to clear the text.
Array of Objects [array of objects] [Optional] An array of JSON Objects where each object contains options that can be specified as part of the KeyboardEvent Object, such as key, keyCode, Event Modifier Initializers. > Note: This parameter is only available on the Responsive Web platform.
Example
voltmx.automation.textbox.enterText(["frmHomeLogin","textbox"], “sampleText”, [{ modifierCapsLock: true,
        key: 'A'
        key: 'B'
        modifierCapsLock: false,
        key: 'c'
        key: 'f'
        key: 'd'
        key: 'E'
        keyCode: 13
    } // For enter key
Return Values
None
Remarks
When textInputMode is Numeric for TextBox widget, the newText Input Parameter can be [number] [Mandatory].
  • Android
  • iOS
  • SPA
  • Responsive Web
voltmx.automation.textarea.enterText
Enters the specified text into the TextArea, if it is visible and enabled.
Syntax
voltmx.automation.textarea.enterText(<widgetpath>, <newText>, <Array of objects with options to raise an event>);
Input Parameters
newText [string] [Mandatory] New text to be set to the TextArea. Specify null to clear the text.
Example
voltmx.automation.textarea.enterText(["frmHomeLogin","textAreaId"], "sample", [{
        key: 'A'
        key: 'B'
        key: 'c'
        key: 'f'
        key: 'd'
        key: 'E'
        keyCode: 13
 } // For enter key
Return Values
None
  • Android
  • iOS
  • SPA
  • Responsive Web
Low-level Touch and Gesture APIs
The voltmx.automation Namespace comprises of the following Low-level Touch and Gesture APIs.
voltmx.automation.widget.touch
Triggers the touch event on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.widget.touch(<widgetpath>, <startPoint>, <movePoints>, <endpoint>, <Object with options for raising an event>);
Input Parameters
startPoint [array] [Mandatory] Represents the start point as [x, y] co-ordinates. Alternatively, this can be assigned a null value.
movePoints [array] [Mandatory] Represents an array of interim points such as [[x1, y1], [x2, y2]…[xn, yn]]. Alternatively, this can be assigned a null value.
endpoint [array] [Mandatory] Represents the end point as [x, y] co-ordinates. Alternatively, this can be assigned a null value.
Array of Objects [array of objects] [Optional] An array of JSON Objects where each object contains options that can be specified as part of the KeyboardEvent Object, such as Event Modifier Initializers. > Note: This parameter is only available on the Responsive Web platform.
Example
voltmx.automation.widget.touch(["Home Page", "appMenuOption2"], [1, 1], [
    [30, 1],
    [50, 1],
    [60, 1],
  [100,1]
  {modifierCapsLock: true}
Return Values
None
  • Android
  • iOS
  • SPA
  • Responsive Web
voltmx.automation.gesture.swipe
Use this API to automate the Swipe gesture on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.gesture.swipe([<widgetpath>], <gestureInfo>);
Parameters
widgetpath [array of strings] [Mandatory] Widget ID from root element (such as form, master, etc.). It is an array of comma-separated strings from root to widget.
gestureInfo [object] [Mandatory]
A JSON object that contains the following key-value pairs:
  • point [X co-ordinate, Y co-ordinate]: The coordinates at which the gesture must be applied.
  • swipeDirection [Integer]: The direction in which the swipe gesture must be applied. You can provide the following values for the swipeDirection key:
    • 1 → Right to left
    • 2 → Left to right
    • 3 → Bottom to top
    • 4 → Top to bottom
  • fingers [Number]: The number of fingers to be used for the gesture.
Return Values
None
Example
voltmx.automation.gesture.swipe(["Home Page", "appMenuOption2"], {
   “point”:[30,1],
  “swipeDirection”: 2,
  “fingers”:1
  • Android
  • iOS
voltmx.automation.gesture.tap
Use this API to automate the Tap gesture on the specified widget, if it is visible and enabled.
Syntax
voltmx.automation.gesture.tap([<widgetpath>], <gestureInfo>);
Parameters
  • taps [Number]: The number of taps for the gesture to be applied.
Return Values
None
Example
voltmx.automation.gesture.tap(["Home Page", "appMenuOption2"], {
“point”:[30,1],
“taps”: 2,
“fingers”:1
  • Android
  • iOS
Miscellaneous Automation APIs
The voltmx.automation Namespace comprises of the following miscellaneous Automation APIs.
voltmx.automation.getCurrentForm
Returns the name of the current Form.
Syntax
voltmx.automation.getCurrentForm();
Input Parameters
None
Example
Return Values
String - Returns the Form ID of the current Form.
  • Android
  • iOS
  • SPA
  • Responsive Web
voltmx.automation.getWidgetsByFilter
Retrieves the paths of the child widgets of the container widget, based on the filters applied.
Syntax
voltmx.automation.getWidgetsByFilter(ContainerWidgetPath, Filters, SearchableWidgets);
Input Parameters
containerWidgetPath[Array] This is a mandatory parameter. This parameter specifies the path of the container widget for which the search and filter criteria must be applied. The ContainerWidgetPath parameter only accepts the paths of container widgets such as Form and FlexContainer and FlexScrollContainer widgets. > Note: Volt MX Iris does not provide support to apply search filters for the child widgets of group widgets (such as Segment, ListBox, TabPane, and Components). However, you can search for the properties of the group widgets.
filters [Array] This is a mandatory parameter. This parameter contains an array of search conditions. If you provide multiple filters, only the widget paths that satisfy all the filters are returned. The array for the Filters parameter must contain the following information: property [String]: Specifies the widget property for which the search criteria applies. value [Object]: Specifies the value of the widget property for which the search criteria applies. The JSON Object can have a String, Number, or Boolean value. caseSensitive [Boolean]: Specifies if the search criteria for the property parameter must consider the case of the string. The default value for this key is true. This is an optional parameter and is only applicable if the type of the value parameter is String. searchCriteria [Constant]: Specifies the criteria for searching the value of a property. This is an optional parameter and can have the following constant values for supported criteria:voltmx.automation.SEARCH_CRITERIA_EQUALvoltmx.automation.SEARCH_CRITERIA_CONTAINSvoltmx.automation.SEARCH_CRITERIA_STARTSWITHvoltmx.automation.SEARCH_CRITERIA_ENDSWITHvoltmx.automation.SEARCH_CRITERIA_GREATERvoltmx.automation.SEARCH_CRITERIA_GREATER_EQUALvoltmx.automation.SEARCH_CRITERIA_LESSERvoltmx.automation.SEARCH_CRITERIA_LESSER_EQUAL> Note: The default value for this parameter is voltmx.automation.SEARCH_CRITERIA_EQUAL.
searchableWidgets [Array of Constants] This is an optional parameter. This parameter contains an array of constants that specify the widgets to be searched. The array for the searchableWidgets parameter can contain the following widget constants: voltmx.automation.widget.BUTTON voltmx.automation.widget.CALENDAR voltmx.automation.widget.CHECKBOXGROUP voltmx.automation.widget.FLEXCONTAINER voltmx.automation.widget.FLEXSCROLLCONTAINER voltmx.automation.widget.LABEL voltmx.automation.widget.LISTBOX voltmx.automation.widget.RADIOBUTTONGROUP voltmx.automation.widget.SEGMENTEDUI voltmx.automation.widget.SLIDER voltmx.automation.widget.SWITCH voltmx.automation.widget.TABPANE voltmx.automation.widget.TEXTAREA voltmx.automation.widget.TEXTBOX
Example 1
widgetList= voltmx.automation.getWidgetsByFilter(
  [“form1”],
      property: “text”,
      value: “Buttontext”,
      caseSensitive: false,
      searchCriteria: voltmx.automation.SEARCH_CRITERIA_CONTAINS
  [voltmx.automation.widget.BUTTON]
voltmx.automation.button.click(widgetList[0]);
Example 2
  [“form1”, “flex1”],
      property: “text”,
      searchCriteria: voltmx.automation.SEARCH_CRITERIA_STARTSWITH
      property: “isVisible”,
      value: true,
      searchCriteria: voltmx.automation.SEARCH_CRITERIA_EQUAL
      property : "zIndex",
      value : 2,
      searchCriteria :voltmx.automation.SEARCH_CRITERIA_GREATER_EQUAL
    voltmx.automation.widget.BUTTON,
    voltmx.automation.widget.LABEL,
voltmx.automation.waitFor(widgetList[0]);
Return Values
Array of widget paths (in an array format) that satisfy the search criteria.
For Example, [ [“Form1”, “bnt1”], [“Form2”, “btn2”] ]
  • Android
  • iOS
  • SPA
  • Responsive Web
voltmx.automation.playback.isLoadingScreenVisible
Returns the status of visibility of the loading screen.
Syntax
voltmx.automation.playback.isLoadingScreenVisible();
Input Parameters
None
Example
await voltmx.automation.playback.isLoadingScreenVisible();
Return Values
Boolean
Returns true if the loading screen is visible on the screen.
Returns false if the loading screen is not visible on the screen.
  • Android
  • iOS
voltmx.automation.playback.wait
Introduces a delay time in the playback as specified. It is an awaitable API.
Syntax
voltmx.automation.playback.wait(<delayTime>);
Input Parameters
delayTime [number] [Mandatory] Time delay in millisecond.
Example
await voltmx.automation.playback.wait(2000);
Return Values
None
  • Android
  • iOS
voltmx.automation.playback.waitFor
Waits for the widget to load completely. It is an awaitable API.
Syntax
voltmx.automation.playback.waitFor(<widgetpath> , <timeout in ms>);
Input Parameters
timeout [number] It is an optional parameter. The timeout parameter must be specified in milliseconds. If the timeout is not specified, the API waits until the widget appears.
Example
await voltmx.automation.playback.waitFor(["Home Page", "amountSpentLabel"]);
Return Values
Boolean
Returns true if the widget is found within the timeout period.
Returns false if the wdget is not found within the timeout period.
  • Android
  • iOS
voltmx.automation.playback.waitForLoadingScreenToDismiss
This API blocks user action until the loading screen is dismissed (or disappears). This is an awaitable API.
Syntax
voltmx.automation.playback.waitForLoadingScreenToDismiss(<timeout in ms>);
Input Parameters
timeout [number] It is an optional parameter. The timeout parameter must be specified in milliseconds. If the timeout is not specified, the API waits until the loading screen disappears.
Example
await voltmx.automation.playback.waitForLoadingScreenToDismiss("amountSpentLabel");
Return Values
Boolean
Returns true if the loading screen has disappeared or the loading screen has not been rendered.
Returns false when the timeout is reached.
  • Android
  • iOS
  • SPA
  • ResponsiveWeb
voltmx.automation.widget.getWidgetProperty
Returns the particular Volt MX-defined property on the specified widget.
Syntax
voltmx.automation.widget.getWidgetProperty(<widgetpath>, <propertyName>);
Input Parameters
propertyName [string] [Mandatory] Widget property name.
Example
var labelText = voltmx.automation.widget.getWidgetProperty (["Home Page", "amountSpentLabel"], "text");
Return Values
The value of the property specified for the widget
  • Android
  • iOS
voltmx.automation.device.deviceBack
Invokes the back action of the device. It is an awaitable API.
Syntax
voltmx.automation.device.deviceBack();
Input Parameters
None
Example
await voltmx.automation.device.deviceBack();
Return Values
None
  • Android
  • iOS
voltmx.automation.capture
The api takes a screenshot of the widget passed. If the widget does not pass, the screenshot captures the entire screen.
Syntax
voltmx.automation.capture(<widgetpath>);
Input Parameters
widgetpath [array of strings] [Mandatory] Widget ID from root element (form, and master, etc.). Comma-separated strings from root to widget represented in an array. If you do not specify this parameter, the screenshot of the entire current screen is taken.
Example
voltmx.automation.capture(["frmHomeLogin","btnLogin"]);
voltmx.automation.capture();
Return Values
None
  • Android
  • iOS
voltmx.automation.takeScreenshotAndCompare
This API allows the framework to capture a screenshot and send it to the Volt MX Automator tool along with a filename for the screenshot. The API then waits for the Automator tool to compare the screenshot with the baseline image and returns the result. This is an awaitable API.
Syntax
voltmx.automation.takeScreenshotAndCompare(screenshotFilename, options);
Input Parameters
screenshotFilename [String] [Mandatory] The file name for the screenshot. Volt MX Iris saves the screenshot for a particular platform (and channel) in the respective folder with this file name.
options [JSON Object] [Mandatory]
The configuration details used to capture and compare the screenshot. A JSON Object that contains the following key-value pairs:
  • threshold[Number]: The threshold value used to compare the images. The value must be a number between 0 and 100 in percentage (for example, if you provide the value as 20, the threshold is 20%). The default value of this parameter is 0.
  • screenshotType: The type of screenshot to be captured. The supported values for this parameter are fullscreen and widget.
  • widgetpath[array of strings]: The path of the widget (Widget ID) from the root element (for example, form or master) represented in an array of comma-separated strings. You must provide the value for this parameter in case of widget-level screenshots. If you do not specify this parameter, Volt MX Iris captures the screenshot of the entire current screen.
Example
var options = {
    threshold = 1000,
    screenshotType = widget,
    widgetpath = ["frmHomeLogin", "btnLogin"]
voltmx.automation.takeScreenshotAndCompare("TestScreen", options);
Return Values
Boolean
  • Returns true if both the images match.
  • Returns false if the images do not match or if the images are not available.
  • Android
  • iOS
  • Responsive Web
Cross App Testing APIs
From the V9 Service Pack 2 Fixpack 16 release, Volt MX Iris introduces support for the following APIs for cross-app testing:
voltmx.automation.getParentInfo
This API returns a JSON Object (dictionary) that contains the details of the application that launched the current app.
Syntax
voltmx.automation.getParentInfo();
Return Values
A JSON Object that contains the following keys:
appName [String] The name of the parent application.
windowRef [Object] A window reference object of the parent application.
queryParams [JSON Object] A JSON Object that contains all the queryParams that are passed while launching the current application. The return value is null if no params are passed.
  • Responsive Web
voltmx.automation.launchApp
This API is used to launch a new app from the current app .Each time you invoke this API with a proper URL, a new window is launched with the specified URL.
This API retrieves the following keys from the IntegrationTests.json file:
The Application URL to be launched is derived from the URL key.
The testresources URL is derived from protocol and ScriptURL keys.
These keys are associated with the appName and are appended to the query parameters as the parentApp parameter, which is the name of the current application.
Syntax
voltmx.automation.launchApp(options);
Input Parameters
appName [String] - Mandatory The name of the application to be launched.
queryParams [JSON Object] - Optional A JSON Object that contains a list of all the parameters to be sent in the queryParams that are passed to the application being launched. The JSON Object contains the following key that can be passed along with other custom keys:
. testPlan [Optional]: The Test Plan that is to be used by the app after it is launched. If this parameter is not specified, the API uses the testPlan.js file for execution.
Example
var options = {
    "appName": "AppTwo",
    "queryParams": {
        "testPlan": "signUpPlan"
var targetWindow = voltmx.automation.launchApp(options);
Return Values
A WindowProxy (window reference) object which is a reference to the newly opened window.
If the specified window is not opened, the API returns a Null value.
  • Responsive Web
voltmx.automation.sendEvent
This API is used to send a message to another app that is associated with the current app. By using this API, you can resume the second application from the first and vice versa.
Syntax
voltmx.automation.sendEvent(options);
Input Parameters
options - A JSON Object that contains the following keys:
windowRef [Object] A window reference object returned from the launchApp API.
eventName [String] The name of the event for which the API must wait. The event name can be any user-defined string.
appName [String] The name of the app to which the event must be sent.
data The data that needs to be sent to the other app. The data can be of any datatype.
Example
var options = {
    "windowRef": targetWindow,
    "eventName": 'emailid',
    "data": {
        "email": "test@test.com"
Return Values
Boolean
Returns true if the app is already launched and the message is posted.
Returns false if the recipient app is not launched and open.
  • Responsive Web
voltmx.automation.sendEventToParent
This API is used to send a message to the parent app that is associated with the current app. By using this API, you can resume the application that launched the current application.
Syntax
voltmx.automation.sendEventToParent(options);;
Input Parameters
Example
var options = {
    "data": {
Return Values
Boolean
  • Responsive Web
voltmx.automation.waitForEvent
This API waits for the instructions from the other app that this API is used for. This API waits indefinitely to receive the instruction (with the same eventName) from the other app to resume execution.
Syntax
voltmx.automation.waitForEvent(options);
Input Parameters
maxWait[number] It is an optional parameter. The maximum time in milliseconds for which the API must wait for the specified event to occur.
Example
var options = {
maxWait : 2000,
eventName : "resume"
Return Values
A JSON Object with the following key-value pairs:
  • eventReceived: A boolean value that indicates if the event is received in time or not.
  • data: A data object that is sent from the second app.
  • Responsive Web
voltmx.automation.webSocket.sendMessage
This API is used to send messages to other client apps that are connected to the same WebSocket Server.
Syntax
voltmx.automation.webSocket.sendMessage(options);
Input Parameters
eventName [String] The name of the event that must be executed in App Factory.
data [String/Number/Object] Additional data that must be passed in the message.
to [String] - Optional The Selenium client receiver of the non-voltmx app that uses the same WebSocket for communication.
The default value of this parameter is the clientID of the app from App Factory.
To send a message to a client app that is not on App Factory, set the value of this parameter as the clientID of the app.
Example
voltmx.automation.webSocket.sendMessage ({
  "eventName": "<authenticate>",
 "data":string/number/object,
 "to": "<seleniumClientId/AppiumClientId>"
  • Android
  • iOS
  • Responsive Web
voltmx.automation.webSocket.waitForMessage
This API waits until the specified event is received. This is an awaitable API.
Syntax
voltmx.automation.webSocket.waitForMessage(options);
Input Parameters
eventName [String] - Mandatory The event that needs to be executed.
The API internally waits until it receives a message from the Selenium client with the same eventName.
maxWait [Number] - Optional The maximum amount of time (in milliseconds) that the API must wait for the event to be received.
Example
await voltmx.automation.webSocket.waitForMessage(
 "eventName" : "executionDone"
  • Android
  • iOS
  • Responsive Web
Page Object Model APIs
From the V9 Service Pack 5 release, Volt MX Iris introduces support for the following APIs to support the Page Object Model approach in Jasmine Test Automation:
voltmx.automation.pageObjectModel.getPageObjects
Use this API to retrieve and return the Page Objects for a specified Page.
Syntax
voltmx.automation.pageObjectModel.getPageObjects();
Input Parameters
An array of JavaScript Objects that contains the following keys:
appName [String] [Mandatory] The name of the app or project that the Page Object Model belongs to.
id [String] [Mandatory] The name of the Form, Template, or Component for which the Page Object Model is to be retrieved.
type [Constant] [Optional] It is an optional parameter. The type of Page for which the Page Objects are to be retrieved.
The type parameter can have the following values:
. voltmx.automation.pageObjectModel.TYPE_FORM [Constant]: Retrieve Page Objects for Forms.
. voltmx.automation.pageObjectModel.TYPE_COMPONENT [Constant]: Retrieve Page Objects for Components.
. voltmx.automation.pageObjectModel.TYPE_TEMPLATE [Constant]: Retrieve Page Objects for Templates.
Example 1
var pageobjects = voltmx.automation.pageObjectModel.getPageObjects([
    {"appName" : "App1",  "id": "Form1", "type" : voltmx.automation.pageObjectModel.TYPE_FORM},
    {"appName" : "App1", "id": "comp.jasmineComp.comp1.comp1", "type" : voltmx.automation.pageObjectModel.TYPE_COMPONENT},
    {"appName" : "App1",  "id": "segRowTemplate1", "type" : voltmx.automation.pageObjectModel.TYPE_TEMPLATE}
Example 2
var [form1_pom, form2_pom] = voltmx.automation.pageObjectModel.getPageObjects([
    {"appName" : "App1",  "id": "Form1"},
    {"appName" : "App1",  "id": "Form2"}
Return Values
An array of Page Objects for the specified Pages in the JavaScript Object format. The order of the Page Objects returned and the size of the array returned is the same as the input array.
The API returns a Null value if a Page Object is not found for the specified Page.
Remarks
Use this API in a Test Case that uses Page Objects.
Here is a sample Test Case that uses the voltmx.automation.pageObjectModel.getPageObjects API to retrieve Page Object Models:
it("testCase1", async function () {
    var _pageobjects = voltmx.automation.pageObjectModel.getPageObjects([
        { "appName": "App1", "id": "Form1", "type": voltmx.automation.pageObjectModel.TYPE_FORM },
        { "appName": "App1", "id": "comp.jasmineComp.comp1.comp1", "type": voltmx.automation.pageObjectModel.TYPE_COMPONENT },
        { "appName": "App1", "id": "segRowTemplate1", "type": voltmx.automation.pageObjectModel.TYPE_TEMPLATE }
    var Form1_pom = _pageobjects[0];
    var comp1_pom = _pageobjects[1];
    var template1_pom = _pageobjects[2];
    await voltmx.automation.playback.waitFor([Form1_pom._path, Form1_pom.Button1]);
    voltmx.automation.button.click([Form1_pom._path, Form1_pom.Button1]); //Form
    voltmx.automation.button.click([Form1_pom._path, Form1_pom.comp1Id, comp1_pom.BtnInComponent]); //Component
    voltmx.automation.button.click([Form1_pom._path, template1_pom.BtnInTemplate]); //Template
  • Android
  • iOS
  • Responsive Web
Existing Volt MX Iris APIs
You can use the following existing Volt MX Iris APIs for Automation. The respective Syntax and usage remain the same.
