<object>.getPendingRecordsForUpload
The <object>.getPendingRecordsForUpload API fetches the list of records that are yet to be uploaded.
- This API is supported from V8 SP4 onwards.
- Supported for Windows from V8 SP4 Fix Pack 6 onwards.
- Supported for Mobile Web and Desktop Web channels from V8 SP4 Fix Pack 12 onwards.
- The column names and values provided as key value pairs are case sensitive.
Volt MX Iris (JavaScript)
Signature
<object>.getPendingRecordsForUpload(options, onSuccessCallback, onFailureCallback)
Parameters
Parameter | Type | Description | Required |
options | JSON | Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. | Yes |
onSuccessCallback | Function | The function is invoked when the pending records for upload are successfully fetched. | Yes |
onFailureCallback | Function | The function is invoked when the pending records for upload are not successfully fetched. | Yes |
Return Type
void
Example
var category = new voltmx.sdk.VMXObj("CATEGORY");
function successCallback(response) {
//response holds the list of records which are yet to be uploaded.
//response={"pendingSyncRecords": [{"UserId":123}]
function errorCallback(error) {
voltmx.print("Failed to fetch pending records for uploads with error: " + JSON.stringify(error));
category.getPendingRecordsForUpload({}, successCallback, errorCallback);
Android (Java)
Signature
void <object>.getPendingRecordsForUpload(HashMap<String, Object> options, final VMXCallback syncCallback) throws Exception
Parameters
options | HashMap <String, Object> | Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. | Yes |
syncCallback | VMXCallback | The function is invoked when the pending records for upload are successfully fetched or on an error. | Yes |
Return Type
void
Example
HashMap < String, Object > options = new HashMap < String, Object > ();
try {
VMXObj category = new VMXObj("CATEGORY");
category.getPendingRecordsForUpload(options, new VMXCallback() {
@Override
public void onSuccess(Object object) {
Log.d("Pending records for upload", "Records are fetched
successfully.");
@Override
public void onFailure(object error) {
OfflineObjectsException e = (OfflineObjectsException) error;
Log.e("Pending records for upload ", "Fetching pending
records for upload unsuccessful for category with Error :" + e.getMessage());
} catch (Exception e) {
e.getMessage());
iOS (Objective C)
Signature
void <object> getPendingRecordsForUpload:(NSDictionary <NSString *, id> *)options
onSuccess:(VMXSuccessCompletionHandler)onSuccess
onFailure:(VMXFailureCompletionHandler)onFailure
Parameters
options | NSDictionary<NSString *, id> | Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. | Yes |
onSuccess | VMXSuccessCompletionHandler | The function is invoked when the pending records for upload are successfully fetched. | Yes |
onFailure | VMXFailureCompletionHandler | The function is invoked when the pending records for upload are not successfully fetched. | Yes |
Return Type
void
Example
NSError * error;
VMXObj * category = [
[VMXObj alloc] initWithName: @"CATEGORY"
error: & error
if (!error) {
[category getPendingRecordsForUpload: options
onSuccess: ^ (id object) {
NSLog(@"Records pending for upload fetched
successfully.");
onFailure: ^ (id object) {
OfflineObjectsError * error = (OfflineObjectsError) object;
NSLog(@"Records pending for upload couldn’t be
fetched with error %@", [error.userInfo localizedDescription]);
} else {
NSLog(@"VMXObj couldn’t be
initialized with error %@", [error.userInfo localizedDescription]);
