Skip to content
<object>.markForUpload
The <object>.markForUpload API selects the changes made to the records and sent to the server. If the markForUpload flag is not enabled, the changes made are deferred from uploading to the server until marked for upload using specific markForUpload APIs.
The markForUpload flag is set to true, by default.
  • Supported for Mobile Web and Desktop Web channels from V8 SP4 Fixpack 12 onwards.
Volt MX Iris (JavaScript)
Signature
<object>.markForUpload(options, successCallback, failureCallback)
Parameters
ParameterTypeDescriptionRequired
optionsJSONA dictionary containing mandatory key primaryKeys which contains the PK (column name and value). In case of a composite PK, the dictionary will contain multiple key-value pairs.Yes
successCallbackFunctionThe function is invoked when the changes are successfully uploaded to the server.Yes
failureCallbackFunctionThe function is invoked when the changes are deferred from uploading to the server.Yes
Options Keys
Key Type Description Required
primaryKeys JSON Specify the primary keys of the record to select a query. Key Name: primaryKeys and value is a dictionary of primary keys. Yes
whereCondition JSON Specify the where condition for the select query if the primary keys are not provided. Key Name: whereCondition and values are column names and their respective values.
Note: Supported only on Desktop Native SQLite starting from V9.5.61.
Yes
whereConditionAsAString String Specify the where condition for the select query if the primary key is not provided. Key Name: whereConditionAsAString and the value is a string.
Yes
Return Type
void
Example
var category = new voltmx.sdk.VMXObj("CATEGORY");
var options = {};
var primaryKeys["CategoryID"] = "1";
options["primaryKeys"] = primaryKeys;
//mark the deferred record for upload with primary key 1
category.markForUpload(options, successCallback, failureCallback);
var whereCondition = {};
whereCondition["CategoryID"] = "10";
var options = {};
options["whereCondition"] = whereCondition;
//mark the deferred records for upload satisfying whereCondition
var whereClause = "Category_PN = '7'";
var options = {};
options["whereConditionAsAString"] = whereClause;
//mark the deferred records for upload satisfying whereClause
function successCallback() {
voltmx.print("markForUpload successful");
function errorCallback(error) {
voltmx.print("markForUpload failed " + error.code);
Android (Java)
Signature
<VMXObj>.markForUpload(final HashMap<String, Object> options, final VMXCallback callback)
Parameters
optionsHashMap<String, Object>key: primaryKeys. Value: HashMap<String, Object>: Pass a hashmap of primary keys and its value. HashMap containing PK (column name and value). In case of a composite PK, the dictionary will contain multiple key-value pairs.Yes
callbackVMXCallbackTakes onSuccess and onFailure methods.Yes
Options Keys
KeysTypeDescriptionRequired
primaryKeysHashMap<String, Object>Specify the primary keys of the record for the select query. Key Name: primaryKeys and respective values to populate primaryKeys map.Yes
Return Type
void
Examples
VMXObj category = new VMXObj("CATEGORY");
HashMap < String, Object > options = new HashMap < String, Object > ();
HashMap < String, Object > primaryKeys = new HashMap < String, Object > ();
primaryKeys.put("CATEGORY_ID", "1");
options.put("primaryKeys", primaryKeys);
category.markForUpload(options, new VMXCallback() {
        @Override
        public void onSuccess(Object object) {
            Log.d("Object markforupload", "Object markforupload Successful ");
        @Override
        public void onFailure(object error) {
            OfflineObjectsException e = (OfflineObjectsException) error;
            Log.e("Object markforupload", "Object markforupload unsuccessful for category with Error :" + e.getMessage());
iOS (Objective C)
Signature
void <VMXObj> markForUpload:(NSDictionary <NSString *, id> *)options
               onSuccess:(VMXSuccessCompletionHandler)onSuccess
               onFailure:(VMXFailureCompletionHandler)onFailure
Parameters
optionsNSDictionarykey: primaryKeys. Value: Dictionary containing PK (column name and value). In case of composite PK, the dictionary will contain multiple key-value pairs.Yes
onSuccessCallbackVMXSuccessCompletionHandlerThe function is invoked when the changes are successfully uploaded to the server.Yes
onFailCallbackVMXFailureCompletionHandlerThe function is invoked when the changes are deferred from uploading the server.Yes
Options Keys
primaryKeysNSDictionary<NSString*, id>Specify the primary keys of the record to select the query. Key name: primaryKeys and value is a dictionary of primary keys.Yes
Return Type
void
Example
NSError error = nil;
VMXObj * _categories = [
    [VMXObj alloc] initWithName: @"CATEGORY"
    error: & error
NSDictionary * primaryKeys = @ {@
    "CATEGORY_ID": "1"
NSDictionary * options = @ {
    "primaryKeys": primaryKeys
[_categories markForUpload: options
    onSuccess: ^ () {
        NSLog(@"Object markforupload successful ");
    onFailure: ^ (id object) {
        OfflineObjectsError * error = (OfflineObjectsError) object;
        NSLog(@"Object markforupload unsuccessful because of error:%@", [error.userInfo
            localizedDescription
Utility API
The API returns all the deferred records primary keys for a particular object.
  • Not supported for Mobile Web, and Desktop Web channels.
Signature
<object>.getUploadDeferredRecordKeys(successCallback, failureCallback)
Example
category.getUploadDeferredRecordKeys(successCallback, failureCallback);
function successCallback(result) {
    for (var pks in result) {
        voltmx.print("deferred records with primary keys " + JSON.stringify(pks));
function failureCallback(error) {
    voltmx.print("failed with error " + error.code);
Android (Java)
Signature
void <VMXObj>. getUploadDeferredRecordKeys (final VMXCallback callback)
Example
category.getUploadDeferredRecordKeys(new VMXCallback() {
        @Override
        public void onSuccess(Object result) {
            List < HashMap < String, Object >> pksList = (List < HashMap < String, Object > ) result;
            for (HashMap < String, Object > pks: pksList) {
                for (Map.Entry < String, Object > e: pks.entrySet()) {
                    Log.d("deferred record with key : " + e.getKey() + "value: "+e.getValue());
    @Override
    public void onFailure(Object error) {
        Log.e("getDeferredUpload", "getDeferredUpload failed with error " + e.getMessage());
iOS (Objective C)
Signature
<void> [<VMXObj> getUploadDeferredRecordKeys: (VMXSuccessCompletionHandler) onSuccess
         onFailure: (VMXFailureCompletionHandler) onFailure]
Example
    error: & error
[_categories getUploadDeferredRecordKeys: onSuccess: onFailure: onFailure];
VMXSuccessCompletionHandler onSuccess = ^ void(id result) {
    NSArray * pks = (NSArray * ) result;
    for (id obj in pks) {
        for (id key in obj) {
            NSLog(“key % @, value % @“, key, [obj objectForKey: key]);
VMXFailureCompletionHandler onFailure = ^ void(id error) {
    NSLog("failed with error " + error.code);
