Skip to content
<object>.getPendingRecordsForUpload
The <object>.getPendingRecordsForUpload API fetches the list of records that are yet to be uploaded.
  • This API is supported from V8 SP4 onwards.
  • Supported for Mobile Web and Desktop Web channels from V8 SP4 Fix Pack 12 onwards.
  • The column names and values provided as key value pairs are case sensitive.
Volt MX Iris (JavaScript)
Signature
<object>.getPendingRecordsForUpload(options, onSuccessCallback, onFailureCallback)
Parameters
Parameter Type Description Required
options JSON Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. Yes
onSuccessCallback Function The function is invoked when the pending records for upload are successfully fetched. Yes
onFailureCallback Function The function is invoked when the pending records for upload are not successfully fetched. Yes
Return Type
void
Example
var category = new voltmx.sdk.VMXObj("CATEGORY");
function successCallback(response) {
    //response holds the list of records which are yet to be uploaded.
    //response={"pendingSyncRecords": [{"UserId":123}]
function errorCallback(error) {
    voltmx.print("Failed to fetch pending records for uploads with error: " + JSON.stringify(error));
category.getPendingRecordsForUpload({}, successCallback, errorCallback);
Android (Java)
Signature
void <object>.getPendingRecordsForUpload(HashMap<String, Object> options, final VMXCallback syncCallback) throws Exception
Parameters
options HashMap <String, Object> Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. Yes
syncCallback VMXCallback The function is invoked when the pending records for upload are successfully fetched or on an error. Yes
Return Type
void
Example
HashMap < String, Object > options = new HashMap < String, Object > ();
try {
    VMXObj category = new VMXObj("CATEGORY");
    category.getPendingRecordsForUpload(options, new VMXCallback() {
        @Override
        public void onSuccess(Object object) {
            Log.d("Pending records for upload", "Records are fetched
 successfully.");
        @Override
        public void onFailure(object error) {
            OfflineObjectsException e = (OfflineObjectsException) error;
            Log.e("Pending records for upload ", "Fetching pending
 records for upload unsuccessful for category with Error :" + e.getMessage());
} catch (Exception e) {
        e.getMessage());
iOS (Objective C)
Signature
void <object> getPendingRecordsForUpload:(NSDictionary <NSString *, id> *)options
        onSuccess:(VMXSuccessCompletionHandler)onSuccess
        onFailure:(VMXFailureCompletionHandler)onFailure
Parameters
options NSDictionary<NSString *, id> Reserved for future use, so the parameter is insignificant. But, the developer must pass some value such as null or { }. Yes
onSuccess VMXSuccessCompletionHandler The function is invoked when the pending records for upload are successfully fetched. Yes
onFailure VMXFailureCompletionHandler The function is invoked when the pending records for upload are not successfully fetched. Yes
Return Type
void
Example
NSError * error;
VMXObj * category = [
    [VMXObj alloc] initWithName: @"CATEGORY"
    error: & error
if (!error) {
    [category getPendingRecordsForUpload: options
        onSuccess: ^ (id object) {
            NSLog(@"Records pending for upload fetched
        successfully.");
        onFailure: ^ (id object) {
            OfflineObjectsError * error = (OfflineObjectsError) object;
            NSLog(@"Records pending for upload couldn’t be
        fetched with error %@", [error.userInfo localizedDescription]);
} else {
    NSLog(@"VMXObj couldn’t be
    initialized with error %@", [error.userInfo localizedDescription]);
