Interacting with Clara
You can chat with Clara through the following user interfaces:
where:
IP is the IP address of Clara machine.
PORT is the port of Clara machine. You can skip it if you use the default port (443).
Clara avatar
Clara avatar has been redesigned to show emotions, so users can immediately understand the status of an action.
Clara can switch from a status to another of the following:
When integrating Clara in the Dynamic Workload Console, even when Clara's chat window is closed, the avatar can show you if an action completes successfully or anything goes wrong in the background.
Selecting a conversation language
After the installation, to enable the availability of multiple languages with Clara, you must configure the translation service of your choice (see Translations). The first time you chat with Clara, she asks you to select a conversation language from the set of languages defined during the configuration steps.
You can change the conversation language at any time, by selecting Language in the drop-down menu of Clara chat window.
If you are using a language other than English, you can view the English version of a message by clicking Show in English in the message box.
Changing the working environment
From Clara Control Panel > Environments page, Clara administrator can set the default environment for Clara to use. You, as a Clara user, might want to work with a different environment.
Clara chat window shows you information about the environment in use. It can be either the default environment selected by the administrator, or an environment you have previously selected.
Click the Change button to select a new environment.
Clara shows you the environments for which you have an access defined in the Clara Control Panel > Access Manager page. Select the environment that you want to use.
Once you have changed the environment, it will remain set as environment in use until you clear the conversation with Clara.
How to start a conversation with Clara
To start a conversation with Clara on a specific topic, proceed as follows:
Clara maintains a history of the messages you have entered. By using the up and down arrow keys, you can recall previously-entered messages to the input field.
By clicking the three dots menu on the upper right corner of Clara chat window, you can find the following options:
During a conversation, Clara provides tips, in the form of action buttons, to suggest the next action you can run.
To quit a conversation, type Cancel.
Copy and share Clara's messages via email
When chatting with Clara, by hovering over Clara's messages, two options are available for each message: Copy and Send email
By selecting Copy, you can copy the message to clipboard, and paste it later on.
By selecting Send email, the message text is copied into a new e-mail in your default e-mail program.
Leave feedback
