Clara supports installation with both Docker and Podman.
Before starting to install Clara, you must check the following system prerequisites:
Verify that Docker and docker-compose or Podman are installed, configured, and ready to use. For the required version, see: System Requirements.
If you don't have Docker and docker-compose or Podman already installed, see: Installing Docker and docker-compose
Podman installation or Installing Podman on iOS and Windows
Clara requires some values to be set for ulimit parameter, for Linux OS. See: How to verify and set ulimit parameter.
Verify the available virtual memory. See: How to verify and set the available virtual memory.
If you are installing Clara on RHEL or CentOS distros, SELinux must be set to Permissive or Disabled. See: How to set SELinux to permissive.
To install and configure Clara, run the following procedure.
From HCL License Portal download the appropriate Clara installation package:
Clara is available with 2 different types of installation packages:
Installation package for offline installation: HCL_CLARA_2.0.0.4_OFFLINE.tar.gz containing:
clara.tar.gz
HCL_CLARA_IMAGES.tar.gz
install.sh
Installation package for online installation: HCL_CLARA_2.0.0.4_ONLINE.tar.gz containing:
clara.tar.gz
install.sh
The online installation requires a working internet connection to reach the Entitled Registry that contains Clara images. Contact your HCL sales representative for the login details required to access the Entitled Registry.
Execute the following command to log into the Entitled Registry:
docker login -u <your_username> -p <your_entitled_key> hclcr.io
podman login -u <your_username> -p <your_entitled_key> localhost:5000
Clara images are as follows:
hclcr.io/slt/clara/clara-manager:2.0.0.4
hclcr.io/slt/clara/clara-rasa:2.0.0.4
hclcr.io/slt/clara/clara-rag-service-vector-db:2.0.0.4
hclcr.io/slt/clara/clara-rag-service-backend:2.0.0.4
hclcr.io/slt/clara/clara-ui:2.0.0.4
hclcr.io/slt/clara/clara-keycloak:2.0.0.4
hclcr.io/slt/clara/clara-asyncservice:2.0.0.4
hclcr.io/slt/clara/clara-rabbitmq:2.0.0.4
hclcr.io/slt/clara/clara-datastore:2.0.0.4
For the selected installation package (offline or online), extract the content of the tar.gz file(s) into <BUILD_DIR>, a directory of your choice, using one of the extraction tools available on your system or downloadable from the internet. The tool you use must be able to keep the file permissions on the extracted files.
You can properly modify the <BUILD_DIR>/clara/config/Clara-WA.env.TEMPLATE configuration file to set some common properties and customize Clara integration with Slack and Teams messaging tools. See below the sections about Customizing environment files and Integration with Slack and Teams.
Notes:
After Clara installation, you can change or complete Clara customization by using Clara Control Panel. For details, see Clara Control Panel.
Open a bash shell and get ready to install Clara.
From the <BUILD_DIR> directory, run the command:
./install.sh [--load-images] --install [--install-path <install_path>] [--port <port_number>] [--img-repo <img_repo>]
where:
--load-images is for offline installation only. Its is required to load Clara images into your environment.
--install-path <install_path> is optional if you want to change the installation directory of your choice (default value is /opt/hcl).
--port <port_number> is optional if you want to change the HTTPS port to use with Clara (default port is 443).
--img-repo <img_repo> is for online installation only. It is optional if you want to specify an Entitled Registry prefix different from the default prefix hclcr.io/solutions/clara/.
By default, before starting the installation, Clara checks the installation prerequisites. If you want to skip this check, add the --noprereq parameter. For details, see the install.sh command usage.
The installation script checks the prerequisites.
The installation script dispalys the HCL Master License Agreement (MLA) for your acceptance. Scroll down or press the "q" key to quit. Type "Y" to accept the MLA.
The installation script runs the installation process, and verifies its successful completion.
Note:The installation commands for Clara are consistent across all environments. The installation script automatically detects the presence of either Docker or Podman on your system and dynamically adjusts to execute the required commands with the detected container runtime.
When the installation is completed, you can access:
Clara Web Interface at the link https://<IP:PORT>
Clara Control Panel at the link https://<IP:PORT>/control-panel
where:
IP is the IP address of Clara machine.
PORT is the port of Clara machine. You can skip it if you use the default port (443).
Clara Control Panel can also be accessed from the drop-down menu of Clara chat window.
The installation script generates two Clara users:
userid solutions, password Hclsolutions00, with user role.
userid admin, password Hclsolutions00, with administrator role.
Use the Keycloak administration console to define new Clara users, new roles, or change default passwords. You can access Keycloak administration console https://<IP:PORT>/keycloak/auth/admin by using the following default credentials:
userid=admin
password=Hclsolutions00
You can also reach the Keycloak administration console from Clara Control Panel, by clicking Manage roles in the Account icon drop-down menu on the Control Panel header.
To change the Keycloak default password or the default SSL certificates, see Configuring Security.
If you want to enable multiple languages with Clara through HCL Translator, see Installing and configuring HCL Translator.
Before you start chatting with Clara, you must:
As a Clara administrator, define the product environments that you want to manage with Clara and identify the default environment.
From Clara Control Panel go to Environments. For details, see Managing the product environments.
As a Clara user, define credentials for the product environments you want to manage with Clara. The Access Manager component, accessible from Clara Control Panel, helps you map your product environment credentials with your Clara credentials (each Clara user can only manage his own product environment credentials). For additional details, see Managing User Access.
You can use the Control Panel to complete Clara settings regarding:
User access
Clara intents
Clara integration in the Dynamic Workload Console
Product environments that you want to manage with Clara
SMTP server for email notification
Translation services
HERO integration
To start/stop Clara containers and services, see clara.sh command options.
To integrate Clara with Slack and Teams messaging tools, you must run the following steps:
Install Clara on a machine having a public internet connection.
Provide the required Slack and Teams parameters in the <BUILD_DIR>/clara/config/Clara-WA.env.TEMPLATE configuration file.
Ensure that the email id that you set in Clara Control Panel > Access Manager for your Clara user, matches the email id you set on Slack and Teams.
Run some configuration steps for the messaging tools:
Slack
Additional bot events:
app_home_opened
Additional scopes:
users.profile:read
users:read.email
Interactivity & Shortcuts -> Request URL:
https://<clara_url>/webhooks/slack_auth/webhook
Event Subscriptions -> Request URL:
Teams
Register Clara's bot with Azure by following the instructions contained in the Azure documentation. You can also watch a useful tutorial video.
Define Clara app on Teams. A tutorial video for this step is also available.
On Teams, set the parameter Configuration -> Messaging endpoint: https:///<clara_url>/webhooks/botframework_auth/webhook.
On Teams, go to App Details -> Descriptions to set the name, and the short and long descriptions for the app, as indicated in the App settings table below.
Go to App Details -> Branding to set the app icon as indicated in the App settings table below.
App settings |
App name |
Clara |
Short description |
Your automation Virtual Assistance |
Long description |
HCL Clara is an Intelligent Virtual Assistant that enhances HCL Workload Automation and HCL Universal Orchestrator customer experience with Natural Language Processing (NLP) interactions, enabling customized self-service automation with immediate 24x7 response. HCL Clara is the product expert that users can consult to learn the product capabilities, execute routine tasks and get troubleshooting assistance. |
App icon for Teams |
Download Teams_icon.zip |
App icon for Slack |
Download Slack_icon.zip |
Background color for Teams |
#71D9F3 |
Background color for Slack |
#01539B |
You can follow your conversation with Clara even using both channels. For example, you can ask your question to Clara on Slack, and then continue the conversation on Teams.
Google Workspace account with access to Google Chat
Google Cloud project (PROJECT_ID)
In the Google Cloud console, enable the Google Chat API.
Clara has to be reachable from Google Chat API.
To integrate Clara with Google Chat messaging tools, you must run the following steps:
Provide the required Google Chat parameters in the <BUILD_DIR>/clara/config/Clara-WA.env.TEMPLATE configuration file.
Update the environment with GCP project ID, for example:PROJECT_ID="channel".
Map the email ID of your Google Chat with the Clara user ID in Clara Control Panel > Access Manager.
Add the Clara app to your Google Chat/Space.
You can now run the Clara actions from the Google Chat.
To configure Clara with Google Chat API, you must run the following steps, you can also watch a useful tutorial video.
Both for Workload Automation and Universal Orchestrator, before starting Clara installation, modify the <BUILD_DIR>/clara/config/Clara-WA.env.TEMPLATE configuration file to set Clara common properties and optionally configure Clara integration with Slack and Teams messaging tools.
Common properties |
NGINX_PORT |
TCP/IP Port to use with Clara [Default: 443] |
NGINX_CERTS |
Path where nginx certificates for Clara are stored [Default: ./certs/nginx] |
Properties for Clara integration with Messaging tools (Slack and Teams) |
BOTFRAMEWORK_APP_ID |
ID for Clara Teams account |
BOTFRAMEWORK_APP_PASSWORD |
Password for Clara Teams account |
SLACK_TOKEN |
The token generated by the Slack bot |
SLACK_CHANNEL |
The Slack bot channel ID |
SLACK_SIGNING_SECRET |
The Slack unique string for Clara. |
| GOOGLE_PROJECT_ID | ID for GCP project |
Properties for source docker images |
IMG_PREFIX |
Clara docker image repo prefix when images are not available locally. [Default: |
TAG |
Tag for Clara docker images based on Clara version, optional. [Default: 2.0.0.4] |
After Clara installation, if a re-configuration is needed, for example to integrate Clara with Slack or Teams messaging tools, you must modify the .env file created during the installation process and located in the folder <BUILD_DIR>/clara. Then, run the following command to activate the updates:
clara.sh --up --nc
install.sh [options]
OPTIONS:
-h Show this message
-c, --prereq Prerequisites (skip any other option if present)
--noprereq Pass this parameter to skip all OS prereq checks
--load-images Load Clara images from HCL_CLARA_IMAGES.tar.gz
--install [--install-path <install_path>] Install Clara
Add --install-path <path> to change path from /opt/hcl
--port <port_number> Pass this parameter to overwrite the HTTPS Port to use with Clara.
Default HTTPS port for Clara is 443.
--img-repo <img_repo> Set source repo prefix for Clara images when they are not available
locally. Example: --img-repo example.com/clara/
Steps:
1. Check Clara prerequisites. Run the command:
./install.sh -c
2. Load Clara images (run only if you need to import new images for an offline installation). Run the command:
./install.sh --load-images
3. Install Clara. Run the command:
./install.sh --install [--install-path /opt/hcl] --accept-license --noprereq
clara.sh [options]
OPTIONS:
Help:
-h Help
To control Clara services:
--up [up options] Create and start Clara container
where [up options] can be:
[--nc] Specify --nc to get the new configuration from the .env file
--down [--vol] Stop and remove Clara containers and network
Specify --vol to remove also persistent volumes
--start Start Clara services
--stop Stop Clara services
--restart Restart (stop and start) Clara containers
--join-net Link Clara network to WA/UnO network when they are both running on the same network
--remove Print commands to clean-up Clara containers, persistent volumes and network manually
--print-urls Print Clara URLS
Examples:
First Clara start-up:
./clara.sh --up
Stop Clara containers:
./clara.sh --stop
