Installation Guide
The data contained in this document shall not be duplicated, used, or disclosed in whole or in part for any purpose. If a contract is awarded to chosen parties because of or in connection with the submission of this data, the client or prospective client shall have the right to duplicate, use, or disclose this data to the extent provided in the contract. This restriction does not limit the client’s or prospective client’s right to use the information contained in the data if it is obtained from another source without restriction. The data subject to this restriction is contained in all marked sheets.
HCL has more than 200 offices worldwide. Addresses, phone numbers, and fax numbers are listed on the HCL website at www.hcltechsw.com.
Copyright © 2025 HCL Technologies Limited.
Document Revision History
This table provides the revision history of this Installation Guide.
Version Date Description
October, 2019 HCL_iAutomate_v4.0_Installation_Guide
May, 2020 HCL_iAutomate_v5.0_Installation_Guide
September, 2020 HCL_iAutomate_v6.0_Installation_Guide
November, 2020 HCL_iAutomate_v6.0.1_Installation_Guide
January, 2021 HCL_iAutomate_v6.0.2_Installation_Guide
April, 2021 HCL_iAutomate_v6.0.3_Installation_Guide
October, 2021 HCL_iAutomate_v6.1_Installation_Guide
March, 2022 HCL_iAutomate_v6.1.1_Installation_Guide
October, 2022 HCL_iAutomate_v6.2_Installation_Guide
November, 2022 HCL_iAutomate_v6.2.1_Installation_Guide
October, 2023 HCL_iAutomate_v6.3_Installation_Guide
December, 2023 HCL_iAutomate_v6.3.2_Installation_Guide
June, 2024 HCL_iAutomate_v6.4_Installation_Guide
August, 2024 HCL_iAutomate_v6.4.1_Installation_Guide
November, 2024 HCL_iAutomate_v6.4.2_Installation_Guide
February, 2025 HCL_iAutomate_v6.5_Installation_Guide
April, 2025 HCL_iAutomate_v6.5.1_Installation_Guide
