GetARMRedisCache (AZURE RedisCache)
This method is used to return the list of Azure RedisCache in HCL BigFix CLM.
Method Signature:
GetARMRedisCache(servicePlanName, controlId, async, callback, queryParams, endpointId)
Sample Response:
 "redisCacheId": "/subscriptions/xxxxxx/resourceGroups/demo-rg/providers/Microsoft.Cache/Redis/demo-redis",
 "entityId": "REDIS-9B8F7A61-0E4C-4A0C-A9F5-B5FA5C6E9123",
 "redisCacheName": "demo-redis",
 "type": "Microsoft.Cache/Redis",
 "location": "Central India",
 "provisioningState": "Succeeded",
 "redisVersion": "6",
 "skuName": "Standard",
 "skuFamily": "C",
 "skuCapacity": "1",
 "enableNonSslPort": false,
 "instancesslPort": "6380",
 "isMaster": false,
 "isPrimary": true,
 "minimumTlsVersion": "1.2",
 "publicNetworkAccess": "Enabled",
 "maxMemoryPolicy": "allkeys-lru",
 "maxclients": "10000",
 "maxMemoryReserved": "200",
 "maxFragmentationMemoryReserved": "100",
 "maxMemoryDelta": "50",
 "accessKeys": {
 "primaryKey": "XXXXXXXXXXXXXXXXXXXXXXX",
 "secondaryKey": "YYYYYYYYYYYYYYYYYYYYYYY"
 "hostName": "demo-redis.redis.cache.windows.net",
 "port": "6379",
 "sslPort": "6380",
 "linkedServers": [],
 "updateChannel": "Stable",
 "disableAccessKeyAuthentication": false,
 "isActive": true,
 "platformEntityId": "ARM-REDIS-13C4A7E9-4321-4D8A-BB56-9FC8A99A7F00",
 "associatedServicePlans": []
Parameter Details:
GetARMRedisCache
Parameter Name Type Mandatory Description
endpointId String N To filter the list on specific Cloud Account Id
servicePlanName String N To filter the list on specific service Plan
controlId String N
Id of ‘Select’ control to be populated.
If Id Control of dynamic UI is passed, then control will be populated with values return from this function else “Result set” will be returned in JSON format.
Async Boolean N
In case it’s False:
Function will be called in synchronous mode. i.e. Current execution will wait for method execution to complete
In case it’s True:
Function will be called asynchronously. Execution will not wait for method execution completion. It will jump to next statement.
Callback Function N User can pass function name that can be executed on completion of Parent function call.
queryParams Object N
queryParams is used for filtering and sorting the records. It contains 3 properties filter/sortby/sortorder.
To Filter:
To filter records based on column name received from output. e.g., filter="keyname='keyvalue'"
To Sort By:
To sort the data based on column name. e.g., sortby="keyname"
To Sort Order:
To define sorting order either ASC (Ascending) or DESC (descending). e.g., sortorder="ASC”
