GetARMLoadBalancer (AZURE Load Balancer)
This method is used to return the list of Azure load balancer in HCL BigFix CLM.
Method Signature:
GetARMLoadBalancer(regionName, loadBalancerName, controlId, async, servicePlanId, callback, addlparam, endpointId)
Sample Response:
 [{"EntityID":"LB-CA0487D4-A16D-4B1B-AF0E-D978DC1326ED",
"Name":"LBtesting","ID":"1","IsActive":"Y",
"ActualIdOnEnvironment":"d566e97b-3068-4dd5-b657-26dfadc4ae9a",
"LBType":"","PlatformEntityID":"ARM-EF5CA4B6-67BE-4B48-BA7C-5F6FC4DAEA3E",
"RegionName":"eastus","ResourceGroupName":"RG","text":"LBtesting"}]
Parameter Details:
Table 1. GetARMLoadBalancer
Parameter Name Type Mandatory Description
regionName String N
If region name is passed, then details of passed region’s load balancer are returned.
If blank “” is passed, then detail of all AZURE’s load balancer will be returned/bind to the control.
loadBalancerName String N
If load balancer name is passed, then details of load balancer are returned.
controlId String N
Id of ‘Select’ control to be populated.
If Id Control of dynamic UI is passed, then control will be populated with values return from this function Else “Result set” will be returned in JSON format.
async Boolean N
In case it’s False:
Function will be called in synchronous mode. i.e., Current execution will wait for method execution to complete
In case it’s True:
Function will be called asynchronously. Execution will not wait for method execution completion. It will jump to next statement.
servicePlanId String N Service Plan ID is UNIQUE ID.
Callback Function N User can pass function name that can be executed on completion of Parent function call.
addlparam Object N
Addlparam is used for filtering and sorting the records. It contains 3 properties filter/sortby/sortorder.
To Filter:
To filter records based on column name received from output. e.g., filter="keyname='keyvalue'"
To Sort By:
To sort the data based on column name. e.g., sortby="keyname"
To Sort Order:
To define sorting order either ASC (Ascending) or DESC (descending). e.g., sortorder="ASC”
endpointId String N To filter the list on specific Cloud Account Id
