Flow Command Server
Deploy a flow from the HCL Link to the local filesystem using Execution flow server definition.
Use the Flow Command Server to override the flow settings and execute the deployed flow from the command line.
Override flow inputs and outputs
Set flow variables
Enable trace
Enable debug mode
Define flow audit option
Define resource file
Set flow execution UUID
Environment variables may need to be set to execute the flow command server. These variables can be set with a setup script which is appropriate for the installation platform. Additional information on special environment variables is given as necessary in other help sections.
On Windows, DTXcommon.bat can be executed before executing a flow command server command line. DTXcommon.bat is in the primary Link installation directory.
$ cd <Link post-installation directory for native binaries, e.g., tomcat-context/install>
$ . ./setup
$ flowcmdserver -h
