Node settings
Access the node settings by right-clicking on the node in the flow.
The settings are not displayed in a modal dialog like other node settings. Instead settings are displayed in an accordion dialog. When displayed it looks like the card settings of a map. This should be like the edit card settings for a map card in a flow.
There are differences in the properties:
- The action properties should not include map related properties such as transaction scope, backup, and retry. These properties are only available in the context of a map.
- The schema allows you to select a schema or generate a schema for certain connection types (for example JDBC, and Salesforce). The schema page, however, is not required in order to specify a schema. This allows a map to be automatically generated between existing nodes.
