MAX_RUNNING_DOTS_TASKLETS
Specifies the maximum number of tasklets that can be executed in a Domino OSGI Tasklet Service (DOTS) environment.
Syntax: MAX_RUNNING_DOTS_TASKLETS = number of tasklets
Description: This configuration setting is used when you want to restrict the number of tasklets running in a DOTS environment. If this setting is isn't in the NOTES.INI file, the default value 20 is set in the server. You can configure the value between 1 to 100, where 1 is the minimum and 100 is the maximum value.
Applies to: Servers
Default: 20
UI equivalent: None, although you can specify this setting in the NOTES.INI Settings tab of the Configuration Settings document in the Domino® Directory.
