Error Logging and Problem Determination
Error logging and problem determination features exist to aid the user in troubleshooting events.
Error Logging
If a Connector operation produces an error, the Connector retrieves the error from DB2® and returns it to the appropriate log or message area.
When programming with LotusScript®, you can use the Lotus® Connector for DB2's trace facility to aid with problem determination during the programmed task. You can enable tracing of all SQL statements by setting TraceSql to True (1).
In IBM® Lotus Enterprise Integrator® (LEI), you can also use the Trace Metaconnector.
