Basic product usage information and programming language reference information.
Lotus® Connectors provide native access to a wide variety of DBMS products, ODBC, the platform File system, Enterprise Resource Planning systems, and Transaction Processing systems.
Accessibility features assist users who have a disability, such as restricted mobility or limited vision, to use information technology content successfully.
Welcome to the Application Design section of Domino® Designer Help.
Welcome to the Application Management section of Domino® Designer Help.
Domino Query Language (DQL) is a facility running in Domino core allowing for a terse shorthand syntax for finding documents according to a wide variety of complexity of terms. It leverages existing design elements without the need to write detailed code to access them.
Composite applications are a key element in a service-oriented architecture (SOA) and contextual collaboration strategy. The ability to create and edit composite applications lets you easily integrate different types of components and technologies.
Domino® Designer includes two types of design elements to assist you in managing data contained in DB2® enabled Notes® databases:
This section contains general guidelines and examples that show where to use Java, LotusScript, and the formula language.
This section documents the formula language.
Welcome to the LotusScript® Language section of Domino® Designer Help.
This section documents the Java/CORBA classes.
This chapter provides information about DCTEST and CONTEST. These programs test system and application connectivity to external data sources.
This chapter provides instructions and information for setting up and testing connectivity to the following database systems:
This chapter provides introductory information about each of the supplied IBM® Lotus® connectors.
This chapter provides information about the Lotus® Connector for Notes®, including descriptions of the fields in the connection document.
This chapter provides information about the Lotus® Connector for DB2®, including descriptions of the fields in the connection document.
This chapter provides information about the Lotus® Connector for File System, including descriptions of the fields in the connection document.
For complete information on the Lotus® Connector for ODBC, refer to the documentation on the Notes® Domino® Application Development wiki.
This chapter provides information about the Lotus® Connector for Oracle, including descriptions of the fields in the connection document.
This chapter provides information about the Lotus® Connector for OLE DB, including descriptions of the fields in the connection document.
This chapter provides information about the Lotus® Connector for Sybase, including descriptions of the fields in the connection document.
This chapter provides information about the Lotus® Connector for Text, including descriptions of the fields in the connection document.
This chapter provides an introduction to LEI Metaconnectors and contains information for creating and using the different types of Metaconnectors.
LotusScrip Extensions for Lotus® Connectors (LC LSX) enhances the power of Notes® by extending its scripting to data outside of Notes through the use of Lotus Connectors. The programming model is independent of the individual connector. This eliminates the need to learn each individual system, while at the same time allowing experienced users to access the individual features of a specific system.
LS:DO has been in maintenance mode since R5. Developers are advised not to use it. Developers should use the Lotus® Connector LSX for (LCLSX) when accessing external data sources.
As part of providing additional Java™ reference documentation, Domino® Designer ships with a help plugin that contains Javadoc™ for additional Domino Designer related APIs.
