Server settings
These tables list the settings for several system-wide settings for the server.
| Field | Description |
| External Agent URL* | This is the URL that the HCL Launch server provides to agents as their point of contact. When an agent wants to contact the server, it retrieves this URL and opens a connection on it. This URL must point to the HTTP or HTTPS port of the server. |
| External User URL* | The URL that users enter to connect to the HCL Launch server. The URL is also used when creating a notification template and when integrating blueprints with HCL Launch. |
| Message of the Day | This message will be displayed on user login or user navigation within web UI. |
| Enable Maintenance Mode | Maintenance mode stops activity on the server so you can run important tasks that require the server to be idle. |
| Validate Agent IP | Requires that the agent IP and host name are validated against values that are used the first time that the agent is connected to the HCL Launch server. |
| Skip Property Updates for Existing Agents | When this toggle button is set to On, when new agents come online, the server does not update their properties. This improves performance, but in this case, agent properties can become out of date. |
| Enable UI Debugging | Facilitates debugging with the user interface. If this setting is enabled, the performance of the user interface might be affected. |
| Create Default Children for Plugins | When this option is enabled, empty groups are created when plugins use the auto discovery feature. |
| Require a Comment For Process Design Changes | Requires that the user provides a comment when the user changes processes. |
| Default Locale | The default language for the user interface. |
| Default Snapshot Lock Type | Determines the default lock type when users create snapshots. Lock types are the following values: Only Component Versions, Only Configuration, or Component Versions and Configuration. The initial value is Component Versions and Configuration. Changes are effective after the server is restarted. |
| Components copy to CodeStation by default | If this toggle is set to On, newly created components copy artifacts to CodeStation by default. You can still change this setting on individual components. |
| Enforce Deployed Version Integrity | When this toggle button is set to On, deployed component version artifacts cannot be changed. |
| Automatic Version Import Check Period (seconds)* | The number of seconds between the times that HCL Launch polls components for new versions. If this value is changed, the server must be restarted before the change becomes effective. Set this value no lower than 15 seconds. |
| Use Agent Tag For Integration | Enables any agent that is identified by a specific tag to import component versions. If this setting is selected, the Agent Tag for version imports field is shown. Otherwise, the Agent for Version Imports field is displayed. For information about tagging objects, see Adding tags to objects |
| Agent for Version Imports | The agent that is used to import component versions. The agent must have access to component artifacts. The agent becomes the default agent for new components. This value can be overridden when a component is created. This field is displayed if the Use Agent Tag for Integration toggle button is set to Off. To import artifacts from the server location, install an agent in the same location and specify that agent. |
| Version Import Records to Retain | The number of version import records to retain during cleanup. Default is 100. |
| Agent Tag for version imports | Any agent with the specified tag can import component versions. All tagged agents must have access to the artifacts. Tagged agents become the default values for new components. This value can be overridden when a component is created. This field is displayed if the Use Agent Tag for Integration toggle button is set to On. |
| Enable Safe Edit of Component Processes | Enables you to test component processes before making them available in normal environments. Make updates to your component process, test those updates safely, and then promote to a new version when you are ready, when toggle is set to On. |
| Require Approval to Promote Component Process | When this option is enabled, any draft component process must be approved by an authorized user before it can be promoted and used in deployments. |
| Allow Process Locking | When this option is enabled, users with 'Manage Process Lock' permission will be able to lock component processes for editing. Users can also force unlock a process locked by another user. |
| Require Process Locking | When this option is enabled, users will not be able to edit component processes without locking the process first. |
| Daily Cleanup Start Time* | The time when versions are cleaned. The value must be an integer from 0 (midnight) to 23 (11 pm). To preview the component versions that are scheduled for cleaning, click Preview Version Cleanup. See Cleaning up component versions. |
| Default Application Snapshot Retention (days)* | The number of days application snapshots are kept, by default. A
value of -1 means that they are kept indefinitely. Component and environment
settings can override this setting. |
| Default Component Version Retention (days)* | The number of component versions to keep, by default. A value of
-1 specifies that all are kept. Component and environment settings can override
this setting. |
| Default Number of Version to Retain* | The number of versions to retain for each component. |
| Archive Path | The path where the compressed file that contains the archived component versions is written. If this field is blank, the compressed file is not written, and no archive is kept. |
| Preview Version Cleanup | To see the versions that are archived using the current settings, click Preview Version Cleanup. See Cleaning up component versions. |
| Enable Deployment History Cleanup | When this toggle button is set to On, deployment history files are reduced. See Cleaning up deployment history files. |
| Daily Cleanup Start Time | The hour that the daily cleanup process starts. |
| Daily Cleanup Duration (hours) | The number of hours that the cleanup process runs daily. |
| Days to Retain Deployment History | The number of days to retain deployment history. This setting can be overridden with the related environment setting. |
| Enable Audit Log Entries for Read Events | When this option is disabled, no READ events are recorded in the audit log. |
| Enable Audit Log Cleanup | When this option is enabled, audit log entries older than the number of days specified in the Days to Retain Audit Log Entries field are removed beginning at the time specified by the Daily Cleanup Start Time field. By default, this option is disabled. See Creating a rotating audit log file. Deleting audit logs from creates a log entry of event type Audit Log Cleanup that are non-deletable. |
| Daily Cleanup Start Time | If Enable Audit Log Cleanup is enabled, the time the audit log cleanup starts. The default value is 12:00 AM. |
| Days to Retain Audit Log Entries | If Enable Audit Log Cleanup is enabled, the number of days that audit log records are retained. The default value is 30. |
| Minimum Password Length* | Determines the minimum length for passwords. |
| Require Uppercase Characters in Passwords | If enabled, passwords must contain at least one uppercase character. |
| Require Lowercase Characters in Passwords | If enabled, passwords must contain at least one lowercase character. |
| Require Special Characters in Passwords | If enabled, passwords must contain at least one special character. |
| Require Number Characters in Passwords | If enabled, passwords must contain at least one numeric character. |
| Require Password to be Unique From User Information | If enabled, passwords must not match username, actual name, or configured email. |
| Discovery Auth Token Expiration Delay(seconds) | Delay in seconds for auth tokens that are created for Auto Discovery Steps to expire. Must be 300 seconds or more. |
| Configure Auth Token Expiration Delay(seconds) | Delay in seconds for auth tokens that are created for Auto Configure Steps to expire. Must be 300 seconds or more. |
| Version Import Auth Token Expiration Delay(seconds) | Delay in seconds for auth tokens that are created for Version Import Steps to expire. Must be 300 seconds or more. |
| Plugin Step Auth Token Expiration Delay(seconds) | Delay in seconds for auth tokens that are created for Plug-in Steps to expire. Must be 300 seconds or more. |
| Use Default Auth Token Restriction if not specified | Enable the default authentication token restriction for processes that are created in HCL Launch 6.2.6.x and earlier. For these versions, the default token is applied to the most current process version but not other versions. If you want to apply the default token restriction to all pre-6.2.7 process versions, turn on this option. By default, the option is turned off. For more information, see Restricting authentication tokens. |
| "Keep me logged in" duration (hours) | The number of hours a user remains logged in after checking 'Keep me logged in'. |
| WinRS Agent | The agent that is used to run agent installation processes on Windows™ computers. The WinRS agent is configured to use the Windows™ winrs command, which enables remote systems to run Windows™ commands. Typically, the agent that is designated as the WinRS agent is used exclusively for this purpose. Note that a WinRS agent must be designated before agents can be installed remotely on Windows™ computers. |
| WinRS User | The user name for Windows™ Remote Management. |
| WinRS Password | The user password for Windows™ Remote Management. |
| Mail Server Host | The host name of the mail server that is used for notifications. HCL Launch can send notifications to users based on user-configured trigger events (to set up notifications, see Creating Notifications in a Notification Scheme). HCL Launch requires an external SMTP mail server to send messages. To disable notifications, leave the field blank. |
| Mail Server Port | The SMTP port that is used by the notifications mail server. |
| Secure Mail Server Connection | Specifies whether the SMTP connection is secure. The default value is Off. |
| Mail Server Sender Address | The sender address for email notifications. |
| Mail Server Username | The user name for sending email notifications. Some email servers and firewalls treat emails with different sender and user names suspiciously. Therefore, consider specifying the same name for both fields. |
| Mail Server Password | The user password for sending email notifications. |
| Enable "Prompt On Use" | Controls whether user-entered values can be specified at process run time. If this parameter is inactive (the default setting), values must be entered on the plug-in step during process creation. If this option is selected, process designers have the option of requiring users to enter values during run time. |
| Enable "Allow Failure" | Shows an Allow Failure check box on steps. |
| Fail Processes With Unresolved Properties | Any running process that cannot resolve a property automatically fails. This setting is enabled by default. |
| Component Environment Properties Override Environment Properties | If this is enabled, component environment properties will override environment properties when using ${p:propName} notation as opposed to ${p:environment/propName}. |
| Use Agent Pool For External Approvals | Turn the toggle on to use an agent pool for external approval processes. |
| Enable "Prompt On Use" | If checked, the option to set "Prompt On Use" for properties in workflow steps will be displayed. |
| Fail Processes With Unresolved Properties | If enabled, any running process which comes across a property it cannot resolve will automatically fail. |
| Component Environment Properties Override Environment Properties | If enabled, component environment properties will override environment properties when using ${p:propName} notation as opposed to ${p:environment/propName}. |
| Enable Deleting Resources From Environment Resource Tree | If enabled, resources can be deleted globally from a specific environment's resource sub-tree. |
