Use the Linux™ tasks to update the controller software, on
a Linux computer. These tasks apply any new enhancements and
fixes that are included in the chosen version to the controller configuration that is already
installed. To initiate a task, complete the following steps:
- Click in the navigation tree.
Select the Fixlet that is relevant to the version of controller that you want to upgrade to.
For example, Updated IBM® BigFix® Remote Control Controller for
Linux is now available! (Version 9.1.2).
In the Task window, review the description and follow the instructions in
the Actions box to initiate the task.
In the Take Action window on the Target tab, select the relevant option
for determining which targets to install the controller update on.
- Click OK and enter your Private
Key Password.
The summary screen shows the progress of the task. The controller software on the selected
targets is upgraded to the version of the chosen update.
