Enabling NIST SP800-131A compliance on a server with a stand-alone WebSphere Application Server
The IBM® BigFix® Remote Control Server uses the middleware infrastructure that is provided by WebSphere® secure HTTP communications. Therefore, to enable NIST SP800-131A compliance for a manual IBM BigFix Remote Control Server installation you must configure IBM BigFix Remote Control Server and WebSphere.
To enable NIST SP800-131A compliance for a manual server installation, complete the following steps after you install the server.
Note: NIST SP800-131A enablement changes in WebSphere
affect all other applications that are running on that server. Therefore, browser settings for the
users who access those other applications must be changed to support Transport Layer Security (TLS).
To enable TLS in Internet Explorer, complete the following steps.
- Click .
- On the Advanced tab, select Use TLS 1.2.
- Click Apply.
- Click OK.
To enable TLS in Firefox, complete the following steps.
- In the browser, go to the about:config page.
- Click I'll be careful, I promise.
- In the search field search for security.tls.version.max.
- Set the value to 3.
