Enabling FIPS compliance on a server installation with a stand-alone WebSphere Application Server
The IBM® BigFix® Remote Control Server uses the middleware infrastructure that is provided by WebSphere® secure HTTP communications. Therefore, to enable FIPS for a manual IBM BigFix Remote Control Server installation requires that you configure WebSphere for FIPS-compliant mode. You must also configure the IBM BigFix Remote Control Server through a setting in the common.properties configuration file.
To enable FIPS compliance for a manual installation, complete the following steps:
Note: The FIPS enablement changes in WebSphere affect all other applications that are running on
the server. Therefore, browser settings for the users who access the other applications must be
changed to support Transport Layer Security (TLS), if required by their browser version.
For example, to enable TLS in Internet Explorer complete the following steps:
- Click .
- On the Advanced tab, select Use TLS 1.0.
- Click Apply
- Click OK.
