On-demand target installation methods
The on-demand target installation method is determined by properties in the ondemand.properties files and the browser that is used by the target user and the configuration of the target computer.
When the target user enters the connection code on the landing page and clicks I agree, the on-demand target installation process begins automatically. The installation method that is used is first determined by properties in the ondemand.properties files and then the browser that the target user is using.
The following properties are available in the ondemand.properties file. You can configure the properties to determine which installation method is used for the on-demand target.
ondemand.enable.plugins
Use this property to enable or disable the plug-in installation method.
ondemand.enable.jnlp
It is strongly recommended to use the executable file installation method. The Java Web Start and plug-in installation methods are deprecated and will be removed soon. The ondemand.enable.plugins, ondemand.enable.jnlp, and ondemand.enable.executable properties in the ondemand.properties file are deprecated and will be removed soon.
Use this property to enable or disable the Java Web Start installation method.
Use this property to enable or disable the executable installation method.
For more information about the properties, see OnDemand properties file.
The installation of the Firefox plug-in does not complete successfully on Firefox Version 57 or higher as Mozilla dropped support for legacy add-ons. The support for this installation method was deprecated in Remote Control starting from Version 9.1.4 IF0003 (Build Number 0309) and it was permanently removed starting from Version 10 IF0008 (Build Number 0802).
All of the properties are enabled by default. Therefore, the installation method that is used is determined by the browser that the target user is using. The ActiveX method is used when the target user is using Internet Explorer. The Firefox plug-in method is used when a Firefox browser is used. The Java Applet method is used if a browser other than Internet Explorer or Firefox is used, and a Java plug-in is detected in the browser. For example, The Java Applet method is used when a Chrome browser is used and a Java plug-in is detected in the browser.
The executable installation method is the only method available when you are using the on-demand target on a macOS device.
If Internet Explorer is being used and ActiveX is enabled, the ActiveX control installation method is used to install the target. If the browser is not enabled for using ActiveX, the target is installed by using the Java Web Start installation method.
If the target user is using Firefox, the Firefox plug-in installation method is used to install the target.
Finally, the on-demand target can also be installed by using a Java Applet.
In all cases, a launching page is displayed with specific instructions.
If the on-demand target fails to start, failover links are provided for the target user to use for more installation methods. The Java Web Start method or an executable file can be used. For more information about determining the installation method when you configure the properties, see Determine which installation method is used for the on-demand target
If JavaScript is not enabled on the target computer, a launching page is displayed after the user clicks I agree. The target user must enable JavaScript on the computer and click Start on the launching page.
