Run Cycle Preview
This view applies only to job streams and shows the run cycles defined for the selected job stream.
It shows the days on which the job stream runs and the days on which it is explicitly excluded from running. You can see this view as a Month or full Year view, and use the navigation toolbar to go to the next or previous Month or Year.
When you modify a run cycle, the view is automatically updated.
Color coding and symbols are used to indicate included
and excluded days in the run cycle rule.
- Selecting a run cycle, the colors have the following meanings:
The run
cycle includes that day.
The run
cycle excludes that day.
- Selecting a job stream, the colors have the following meanings:
The job stream runs only once on that day.
The job stream runs more than once on that day.
The job stream runs, but some runs have been excluded.
The job stream runs more than once, but some runs
have been excluded.
The job stream does not run, because it is excluded by a
rule.
Non-working
day.
Click any highlighted day to view details about the run cycles occurring on the selected day.
