Creating and editing items in the Database
This section describes creating and editing items in the database.
In this section you can find information about creating and editing scheduling items from the Dynamic Workload Console by using the Graphical Designer, the right place to start designing your environment and define the automation of your business processes.
By using the Graphical Designer, you have full control over your orchestration: you can create job streams, add new jobs, create internal or external dependencies, add join conditions, triggers and constraints to your job streams. You can save items in the database, edit definitions, reuse existing items and perform any operation useful to make your orchestration as smooth as possible.
