SQL report examples
Examples of queries that can be run using the SQL custom reports.
This section provides some examples of queries that can be run using the SQL custom reports.
For each return code, this query returns the number of jobs that ended with the corresponding return code:
SELECT DISTINCT return_code AS
RC
count(job_name) AS
,#JOB
FROM mdl.job_history_v
GROUP BY return_code
RC | #JOB |
0 | 1670 |
5 | 11 |
6 | 1 |
50 | 2 |
127 | 352 |
For each job status, this query returns the number of jobs that ended with the corresponding job status and also the planned duration time, the total elapsed time, and total CPU time:
SELECT
job_status, count(job_name) AS
job count
, floor(sum(planned_duration/1000)) AS
planned
duration,
floor(sum(total_elapsed_time/1000))
AS
total elapsed,
floor(sum(total_cpu_time/1000))
AS
total cpu
FROM
mdl.job_history_v GROUP BY job_status
FROM
mdl.job_history_v
GROUP BY
return_code
JOB_STATUS | JOB COUNT | PLANNED DURATION | TOTAL ELAPSED | TOTAL CPU |
A | 366 | 0 | 21960 | 0 |
S | 1670 | 1413360 | 1423500 | 183 |
Jobs in a range of return code
This query returns the number of job in a range of return codes
SELECT
FROM (select DISTINCT return_code, count(job_name) AS
#JOB
GROUP BY return_code) AS temp
WHERE return_code > 0 AND return_code ˂ 6
RETURN_CODE | #JOB |
5 | 11 |
SELECT
WORKSTATION_NAME, JOB_NAME, JOB_RUN_DATE_TIME
FROM MDL.JOB_HISTORY_V
WHERE JOB_RUN_DATE_TIME BETWEEN '2008-05-19
10:00:00.0' AND '2008-05-19
21:00:00.0'
AND JOB_STATUS ˂> 'S'
ORDER
BY JOB_RUN_DATE_TIME
WORKSTATION_NAME | JOB_NAME | JOB_RUN_DATE_TIME |
NC122072 | PEAK_A_06 | 2008–08–03 23:23:00.0 |
NC122072 | JOB_RER_A | 2008–08–03 23:23:00.0 |
NC122072 | PEAK_A_13 | 2008–08–03 23:23:00.0 |
NC122072 | PEAK_A_20 | 2008–08–03 23:23:00.0 |
NC122072 | PEAK_A_27 | 2008–08–03 23:23:00.0 |
NC122072 | PEAK_A_43 | 2008–08–03 23:23:00.0 |
NC122072 | PEAK_B_19 | 2008–08–03 23:24:00.0 |
