Skip to content
Toolbar Properties
barButtonItems Property
This property contains an array of BarButtonItem objects.
Syntax
barButtonItems
Type
Array of objects.
Read/Write
Read + Write
Remarks
Example
/*Sample code to set the leftBarButtonItems and rightBarButtonItems property method of a ToolBar widget.*/
var btns = [item0, item1];
var btns1 = [item2];
frmToolBar.myToolbar.leftBarButtonItems = btns;
frmToolBar.myToolbar.rightBarButtonItems = btns1;
Platform Availability
  • iOS
barStyle Property
This property determines the toolbar bar appearance
Syntax
barStyle
Type
Constant
Read/Write
Read + Write
Remarks
The toolbar bar style can be one of the following:
  • constants.BAR_STYLE_DEAFULT
  • constants.BAR_STYLE_BLACK
Example
//Sample code to set the barStyle property of a ToolBar widget.
frmToolBar.myToolbar.barStyle=constants.BAR_STYLE_DEAFULT;
  • iOS
barTintColor Property
This property determines the tint color of the toolbar bar background.
Syntax
barTintColor
Type
String
Read/Write
Read + Write
Remarks
This property determines the tint color of the toolbar bar background. It is specified as a string that contains a hex value.
Remarks
//Sample code to set the barTintColor property of a ToolBar widget.
var item1 = new voltmx.ui.BarButtonItem({
    // All items must be created in the same manner.
    type: constants.BAR_BUTTON_SYSTEM_ITEM,
    style: constants.BAR_ITEM_STYLE_PLAIN,
    enabled: true,
    action: onClick,
    metaData: {
        systemItem: constants.SYSTEM_ITEM_REPLY
item1.barTintColor = "FF0000";
  • iOS
isToolBarBottomAttached Property
This property determines if the toolbar is docked to the bottom of the form.
Syntax
Type
Boolean
Read/Write
Read + Write
Remarks
If True, the toolbar is docked to the bottom of the form. Width and Height properties are disabled in this case.
Remarks
//Sample code to set the isToolBarBoottomAttached property of a ToolBar widget.
    enabled: true,
    action: onClick,
    metaData: {
item1.isToolBarBoottomAttached=true;
  • iOS
retainContentAlignment Property
This property is used to retain the content alignment property value, as it was defined.
Note: Locale-level configurations take priority when invalid values are given to this property, or if it is not defined.
The mirroring widget layout properties should be defined as follows.
function getIsFlexPositionalShouldMirror(widgetRetainFlexPositionPropertiesValue) {
    return (isI18nLayoutConfigEnabled &&
    localeLayoutConfig[defaultLocale]
    ["mirrorFlexPositionalProperties"] == true &&
    !widgetRetainFlexPositionPropertiesValue);
The following table illustrates how widgets consider Local flag and Widget flag values.
Properties Local Flag Value Widget Flag Value Action
Mirror/retain FlexPositionProperties true true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties true false Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties true not specified Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties false true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties false false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties false not specified Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties not specified false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified not specified Use the Design/Model-specific default layout.
Syntax
Type
Boolean
Read/Write
No (only during widget-construction time)
Example
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the retainContentAlignment property for Button widget.
/*You need to make a corresponding use of the
retainContentAlignment property for other applicable widgets.*/
var btn = new voltmx.ui.Button({
    "focusSkin": "defBtnFocus",
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "skin": "defBtnNormal",
    "text": "text always from top left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_TOP_LEFT,
    "displayText": true,
    "padding": [0, 0, 0, 0],
    "paddingInPixel": false,
    "retainFlexPositionProperties": false,
    "retainContentAlignment": true
  • Available in IDE
  • iOS, Android, and SPA
retainFlexPositionProperties Property
This property is used to retain flex positional property values as they were defined. The flex positional properties are left, right, and padding.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlexPositionProperties property for Button widget.
retainFlexPositionProperties property for other applicable widgets.*/
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "text": "always left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_CENTER,
    "retainFlexPositionProperties": true,
    "retainContentAlignment": false
  • Available in IDE
retainFlowHorizontalAlignment Property
This property is used to convert Flow Horizontal Left to Flow Horizontal Right.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlowHorizontalAlignment property for Button widget.
retainFlowHorizontalAlignment property for other applicable widgets. */
 "height": "50dp",
 "id": "myButton",
 "isVisible": true,
 "left": "0dp",
 "top": "0dp",
 "width": "260dp",
 "zIndex": 1
 "retainContentAlignment": false,
 "retainFlowHorizontalAlignment ": false
  • Available in IDE
tintColor Property
This property determines the tint color to apply to the toolbar items and bar button items. - hex string
Syntax
tintColor
Type
String
Read/Write
Read + Write
Remarks
The hex value is a 6 digit string. For example, red would be FF0000, green 00FF00, blue 0000FF, white FFFFFF, and black 000000.
Example
//Sample code to set the tintColor property of a ToolBar widget.
frmToolbar.myToolbar.tintColor="FFFFFF00";
  • iOS
translucent Property
This property indicates if the toolbar is translucent.
Syntax
translucent
Type
Boolean
Read/Write
Read + Write
Remarks
This property is a boolean value indicating whether the toolbar bar is translucent.
Example
//Sample code to set the translucent property of a ToolBar widget.
frmToolbar.myToolbar.translucent=true;
  • iOS
