Skip to content
Switch Properties
The properties for Switch Widget are:
accessibilityConfig Property
Enables you to control accessibility behavior and alternative text for the widget.
For more information on using accessibility features in your app, see the Accessibility appendix in the Volt MX IrisUser Guide.
Syntax
accessibilityConfig
Type
Object
Read/Write
Read + Write
Remarks
  • The accessibilityConfig property is enabled for all the widgets which are supported under the Flex Layout.
Note: From Volt MX Iris V9 SP2 GA version, you can provide i18n keys as values to all the attributes used inside the accessibilityConfig property. Values provided in the i18n keys take precedence over values provided in a11yLabel, a11yValue, and a11yHint fields.
The accessibilityConfig property is a JavaScript object which can contain the following key-value pairs.
Key Type Description ARIA Equivalent
a11yIndex Integer with no floating or decimal number. This is an optional parameter. Specifies the order in which the widgets are focused on a screen. For all widgets, this parameter maps to the aria-index, index, or taborder properties.
a11yLabel String This is an optional parameter. Specifies alternate text to identify the widget. Generally the label should be the text that is displayed on the screen. For all widgets, this parameter maps to the aria-labelledby property of ARIA in HTML. > Note: For the Image widget, this parameter maps to the alt attribute of ARIA in HTML.
a11yValue String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. This parameter is similar to the a11yLabel parameter. If the a11yValue is defined, the value of a11yValue is appended to the value of a11yLabel. These values are separated by a space.
a11yHint String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. For all widgets, this parameter maps to the aria-describedby property of ARIA in HTML.
a11yHidden Boolean This is an optional parameter. Specifies if the widget should be ignored by assistive technology. The default option is set to false. This option is supported on iOS 5.0 and above, Android 4.1 and above, and SPA For all widgets, this parameter maps to the aria-hidden property of ARIA in HTML.
a11yARIA Object This is an optional parameter. For each widget, the key and value provided in this object are added as the attribute and value of the HTML tags respectively. Any values provided for attributes such as aria-labelledby and aria-describedby using this attribute, takes precedence over values given in a11yLabel and a11yHint fields. When a widget is provided with the following key value pair or attribute using the a11yARIA object, the tabIndex of the widget is automatically appended as zero.{"role": "main"}``aria-label This parameter is only available on the Desktop Web platform.
Android limitations
  • If the results of the concatenation of a11y fields result in an empty string, then accessibilityConfig is ignored and the text that is on widget is read out.
  • The soft keypad does not gain accessibility focus during the right/left swipe gesture when the keypad appears.
SPA/Desktop Web limitations
  • When accessibilityConfig property is configured for any widget, the tabIndex attribute is added automatically to the accessibilityConfig property.
  • The behavior of accessibility depends on the Web browser, Web browser version, Voice Over Assistant, and Voice Over Assistant version.
  • Currently SPA/Desktop web applications support only a few ARIA tags. To achieve more accessibility features, use the attribute a11yARIA. The corresponding tags will be added to the DOM as per these configurations.
Example 1
This example uses the button widget, but the principle remains the same for all widgets that have an accessibilityConfig property.
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the accessibilityConfig Property for button widget.
/* You need to make a corresponding use of the accessibilityConfig property for other applicable widgets. */
Form1.myButton.accessibilityConfig = {
    "a11yLabel": "Label",
    "a11yValue": "Value",
    "a11yHint": "Hint"
Example 2
This example uses the button widget to implement internationalization in accessibilityConfig property, but the principle remains the same for all widgets.
/* Sample code to implement internationalization in accessibilityConfig property in Native platform. */
    "a11yLabel": voltmx.i18n.getLocalizedString("key1")
/* Sample code to implement internationalization in accessibilityConfig property in Desktop Web platform. */
    "a11yLabel": "voltmx.i18n.getLocalizedString(\"key3\")"
Platform Availability
  • Available in the IDE
  • iOS, Android, SPA, and Desktop Web
blur Property
You can enable or disable a blur-effect for a widget(for example, a FlexContainer) by making use of a constructor-level property, called blur. The blur property accepts a dictionary that contains the following keys: enabled, value and style. You must specify an appropriate value for the dictionary keys, otherwise the property will not be valid.
Syntax
blur
Input Parameters
  • enabled: Accepts a Boolean value that basically decides whether to enable or disable the blur-effect for the widget. This is a mandatory attribute.
  • value: Level of the blur-effect that needs to be set for the widget. It should ideally be between 0 to 100. If the level is set as 0 no blur is set, even when the enabled property is set as true. This is a mandatory attribute. Even when the enabled attribute is set as false, you need to specify a numerical value to this attribute.
  • style: Specifies the style in which the blur property can be applied to a widget. This is an optional parameter specific to iOS. The default value of this parameter is constants.BLUR_EFFECT_LIGHT. You can specify any of the following values to this parameter:
    • constants.BLUR_EFFECT_NONE
    • constants.BLUR_EFFECT_EXTRALIGHT
    • constants.BLUR_EFFECT_LIGHT (default)
    • constants.BLUR_EFFECT_DARK
    • constants.BLUR_EFFECT_REGULAR
    • constants.BLUR_EFFECT_PROMINENT
Read/Write
Read + Write
Remarks
  • If you set enabled as true, the blur-effect for the widget is enabled.
  • If you set enabled as false, the blur-effect for the widget is disabled.
  • If you specify value as less than 0, the value is taken as 0.
  • If you specify value as greater than 100, the value is taken as 100.
Limitations
  • For Android:
    • If a FlexContainer or a FlexScrollContainer contains a Map widget, the blur-effect is not applied to the map.
    • If a FlexContainer or a FlexScrollContainer contains a Browser or Video widget, the blur-effect is applied but does not get updated. For example, when the video starts playing, the new rendered frame does not get displayed with the blur-effect.
    • Even if you apply 100% blur for widgets that display any text( such as Label or Calendar widgets), the text on these widgets is not blurred. This is a Native Android limitation. To generate the blur effect for the text, apply a skin with darker background to the Label or Calendar widget. This is true even when the widgets are placed in a FlexContainer with blur effect and the widgets do not have a skin.
    • Blur effect will not work on widgets added inside BOX containers.
Example 1
To dynamically set the blur-effect for any widget, such as a FlexContainer, use the following code.
//Here, we have shown how to use the blur property for FlexContainer widget.
/*You need to make a corresponding use of the
blur property for other applicable widgets.*/
Form1.myFlexContainer.blur = {
    "enabled": true,
    "value": 60
Example 2
To dynamically set the blur-effect for any widget, such as a FlexContainer in iOS, use the following code.
Form1.widget1.blur = {
    "enabled": true,
    "value": 60,
    "style": constants.BLUR_EFFECT_DARK
  • Android, iOS, SPA , and Desktop web
bottom Property
This property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
The bottom property determines the position of the bottom edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the bottom edge of the parent container. In flow-vertical layout, the value is ignored. In flow-horizontal layout, the value is ignored.
The bottom property is used only if the Height property is not provided.
Syntax
bottom
Type
String
Read/Write
Read + Write
Remarks
The property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the bottom property is measured from the top edge of bottom sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and the top of the bottom sibling widget.
Example
//Sample code to set the bottom property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.bottom = "50dp";
frmHome.widgetID.bottom = "10%";
frmHome.widgetID.bottom = "10px";
  • iOS, Android, SPA and Desktop Web
centerX Property
This property determines the center of a widget measured from the left bounds of the parent container.
The centerX property determines the horizontal center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
centerX
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the centerX property is measured from right edge of the left sibling widget.
Example
//Sample code to set the centerX property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerX = "50dp";
frmHome.widgetID.centerX = "10%";
frmHome.widgetID.centerX = "10px";
  • iOS, Android,SPA and Desktop Web
centerY Property
This property determines the center of a widget measured from the top bounds of the parent container.
The centerY property determines the vertical center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-horizontal layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy.
Syntax
centerY
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the centerY property is measured from bottom edge of the top sibling widget.
Example
//Sample code to set the centerY property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerY = "50dp";
frmHome.widgetID.centerY = "10%";
frmHome.widgetID.centerY = "10px";
cursorType Property
In Desktop Web applications, when you hover the mouse over any widget, a mouse pointer appears. Using the cursorType property in Iris, you can specify the type of the mouse pointer.
Syntax
cursorType
Type
String.
You must provide valid CSS cursor value such as wait, grab, help, etc. to the cursorType property.
Read/Write
Read + Write
Remarks
To add the cursorType property using Volt MX Iris in a Desktop Web application, follow these steps.
  1. In Volt MX Iris, open the Desktop Web application. From the Project explorer, expand Responsive Web/ Desktop> Forms and select the form to which you need to make the changes.
  2. On the canvas, select the widget for which you want to specify the cursor type. For example, button.
  3. From the Properties panel, navigate to the Skin tab > Hover Skin tab.
    You will find that the details of the hover skin is not enabled here.
  4. Check the Enable option to add a hover skin to your widget.
    The details and configurations of the hover skin is enabled.
  5. Under the General section, for the Platform option, click the ellipsis icon.
    The Fork Skin window appears.
  6. In the Fork Skin window, for Desktop, check under HTML5 SPA.
  7. Click Ok. You have successfully forked your hover skin for Desktop Web application.
    You can see that the Cursor Type property has been added under the General section.
  8. Select a value from the drop-down list to set the Cursor Type for the widget.
Example
 //This is a generic property and is applicable for many widgets.
/* The example provided is for the Button widget. Make the required changes in the example while using other widgets. */
frmButton.myButton.cursorType = "wait";
  • Available in IDE
  • Desktop Web
enable Property
The enable property is used to control the actionability of the widgets. In a scenario where you want to display a widget but not invoke any action on the widget, configure the enable property to false to achieve it.
This is a constructor level property and applicable for all widgets in Volt MX Iris.
Syntax
enable
Type
Boolean
Read/Write
Read + Write
Remarks
The default value of this property is true.
When enable property is configured to true, the action associated with a widget can be invoked by the user in the application.
When enable property is configured to false, the action associated with a widget cannot be invoked by the user in the application.
Example
### //This is a generic property and is applicable for many widgets.
/* The example provided is for the Button widget. Make the changes required in the example while using other widgets. */
frmButton.myBtn.enable= true;
  • Android, iOS, SPA and Desktop web
enableCache Property
The property enables you to improve the performance of Positional Dimension Animations.
Syntax
enableCache
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for this property is true.
Note: When the property is used, application consumes more memory. The usage of the property enables tradeoff between performance and visual quality of the content. Use the property cautiously.
Example
Form1.widgetID.enableCache = true;
  • Available in the IDE.
enableHapticFeedback Property
Allows you to enable or disable haptic feedback on the Switch widget.
Syntax
Type
Boolean.
If the enableHapticFeedback property is not specified, haptic feedback is not enabled on the Switch widget.
Read/Write
Read + Write
Remarks
  • The enableHapticFeedback property is supported for Switch widgets only when the onClick callback event is defined.
  • iOS
    • The Haptic Feedback feature is available on iPhone 7 devices and later. These devices have Taptic Engine hardware and users can enable/disable Haptics from Device Settings-> Sounds & Haptics-> System Haptics.
  • Android
    • Users can enable the Vibrate on touch feature from Settings-> Sound & notification-> Other sounds.
Limitations and Behavior
  • The enableHapticFeedback property is not available for iOS, as iOS native provides support for haptic functionality.
  • To disable the haptic feature for Switch widget on iOS devices, navigate to Settings-> Sounds & Haptics-> System Haptics.
Example
//Sample code to set the enableHapticFeedback property of a Switch widget.
frmSwitch.mySwitch.enableHapticFeedback= true;
  • Android
header Property
Specifies the header text to the switch.
Syntax
header
Type
String
Remarks
The default value for this property is None.
The following images illustrate the appearance of header text to the switch:
Example
FormSwitch.mySwitch.header = "Switch Header";
headerSkin Property
Specifies the skin to be applied to the header of the switch.
Syntax
headerSkin
Type
String
Remarks
The following images illustrate the appearance of header text skin of the switch:
Since the default color of the switch is black, define a new skin with text color other than black.
Example
//Setting the headerSkin property on an existing widget
Form1.mySwitch.headerSkin = "switchSkin"; //switchSkin must be created in the Skins tab on the IDE.
height Property
It determines the height of the widget and measured along the y-axis.
The height property determines the height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the height may be derived from either the widget or container’s contents by setting the height to “preferred”.
Syntax
height
Type
Number, String, and Constant
Read/Write
Read + Write
Remarks
Following are the available measurement options:
  • %: Specifies the values in percentage relative to the parent dimensions.
  • px: Specifies the values in terms of device hardware pixels.
  • dp: Specifies the values in terms of device independent pixels.
  • default: Specifies the default value of the widget.
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred height of the widget as height and preferred size of the widget is determined by the widget and may varies between platforms.
Example – Setting the height property on an existing widget
Example
/* Sample code to set the height property for a Switch widget by using DP, Percentage and Pixels. */
frmSwitch.mySwitch.height="50dp";
frmSwitch.mySwitch.height="10%";
frmSwitch.mySwitch.height="10px";
  • iOS
  • Android
  • SPA
id Property
A unique identifier of Switch consisting of alpha numeric characters. Every Switch should have a unique id within a Form.
Syntax
id
Type
String
Read/Write
Read only
Example
//Defining the properties for Switch with the ID :"mySwitch"
var swtchBasic = {
    info: {
        key: "switch"
    leftSideText: "on",
    rightSideText: "off",
    skin: "swchSkin",
    selectedIndex: 0,
    isVisible: true
var swtchLayout = {
    margin: [5, 5, 5, 5],
    marginInPixel: false,
    widgetAlignment: constants.WIDGET_ALIGN_TOP_LEFT,
    containerWeight: 99
//Creating the Switch
var mySwitch= new voltmx.ui.Switch(swtchBasic, swtchLayout, {});
//Reading the ID of the Switch
alert("Switch ID is ::" + mySwitch.id);
  • iOS
  • Android
  • SPA
info Property
A custom JSObject with the key value pairs that a developer can use to store the context with the widget.
Syntax
info
Type
JSObject
Read/Write
Read + Write
Remarks
This will help in avoiding the globals to most part of the programming.
This is a non-Constructor property. You cannot set this property through widget constructor. But you can always read and write data to it.
Info property can hold any JSObject. After assigning the JSObject to info property, the JSObject should not be modified. For example,
var inf = {
    a: "hello"
widget.info = inf; //works
widget.info.a = "hello world";
//This will not update the widget info a property to hello world.
//widget.info.a will have old value as hello.
Example
//Sample code to set the info property for a Switch widget.
frmSwitch.mySwitch.info={
    key: "switch"
//Reading info of the Switch widget.
alert("Switch widget info is ::" +frmSwitch.mySwitch.info);
  • iOS
  • Android
  • SPA
isVisible Property
This property controls the visibility of a widget on the form.
Syntax
isVisible
Type
Boolean
Read/Write
Read + Write
Remarks
If set to false, the widget is not displayed.
If set to true, the widget is displayed.
This property is not applicable if the widget is placed in a SegmentedUI. When the widget is placed in a Segment, the default Visibility is set to true. If you want to change the value to false, you can do so using the SegmentedUI methods.
Example
//Sample code to set the isVisible property of a Switch widget.
frmSwitch.mySwitch.isVisible=true;
Note: You can set the visibility of a widget dynamically from code using the setVisibility method.
  • iOS
  • Android
  • SPA
left Property
This property determines the lower left corner edge of the widget and is measured from the left bounds of the parent container.
The left property determines the position of the left edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
left
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the left property is measured from right edge of the left sibling widget.
Example
//Sample code to set the left property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.left = "50dp";
frmHome.widgetID.left = "10%";
frmHome.widgetID.left = "10px";
leftSideText Property
Specifies the text to be displayed on the left portion of the Switch. You cannot apply image for this property.
Syntax
leftSideText
Type
String
Remarks
The text specified for this property will not be displayed in the Iris canvas for native channels.
Example
//Sample code to set the leftSideText property of a Switch widget.
frmSwitch.mySwitch.leftSideText="ON";
  • iOS
  • Android
  • SPA
Left Text i18n Key Property
Specifies the key to be used for internationalization of the string specified in the leftSideText property.
Syntax
leftSideText
Type
Example
/*Defining the properties for Switch with the leftSideText:
 voltmx.i18n.getLocalizedString("select").*/
var swtchBasic = {
    info: {
        key: "switch"
    leftSideText: voltmx.i18n.getLocalizedString("select"),
    skin: "swchSkin",
    selectedIndex: 0,
    isVisible: true
var swtchLayout = {
    containerWeight: 99
//Creating the Switch.
//Sample code to set the i18n key for leftSideText property of a Switch widget.
frmSwitch.mySwitch.leftSideText=voltmx.i18n.getLocalizedString("select");
  • iOS
  • Android
  • SPA
maxHeight Property
This property specifies the maximum height of the widget and is applicable only when the height property is not specified.
The maxHeight property determines the maximum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxHeight value overrides the preferred, or “autogrow” height, if the maxHeight is less than the derived content height of the widget.
Syntax
maxHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxHeight = "50dp";
frmHome.widgetID.maxHeight = "10%";
frmHome.widgetID.maxHeight = "10px";
maxWidth Property
This property specifies the maximum width of the widget and is applicable only when the width property is not specified.
The Width property determines the maximum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxWidth value overrides the preferred, or “autogrow” width, if the maxWidth is less than the derived content width of the widget.
Syntax
maxWidth
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxWidth = "50dp";
frmHome.widgetID.maxWidth = "10%";
frmHome.widgetID.maxWidth = "10px";
minHeight Property
This property specifies the minimum height of the widget and is applicable only when the height property is not specified.
The minHeight property determines the minimum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minHeight value overrides the preferred, or “autogrow” height, if the minHeight is larger than the derived content height of the widget.
Syntax
minHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the minHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minHeight = "50dp";
frmHome.widgetID.minHeight = "10%";
frmHome.widgetID.minHeight = "10px";
minWidth Property
This property specifies the minimum width of the widget and is applicable only when the width property is not specified.
The minWidth property determines the minimum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minWidth value overrides the preferred, or “autogrow” width, if the minWidth is larger than the derived content width of the widget.
Syntax
minWidth
Type
Number
Read/Write
Read only
Example
//Sample code to set the minWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minWidth = "50dp";
frmHome.widgetID.minWidth = "10%";
frmHome.widgetID.minWidth = "10px";
nativeThumbLook Property
Provides the native thumb look of the Switch.
Syntax
nativeThumbLook
Type
Boolean
Read/Write
Read + Write
Example
Setting the nativeThumbLook property on an existing widget
Form1.mySwitch.nativeThumbLook = true;
iOS
opacity Property
Specifies the opacity of the widget. The value of this property must be in the range 0.0 (transparent) to 1.0 (opaque). Any values outside this range are fixed to the nearest minimum or maximum value.
Specifies the opacity of the widget. Valid opacity values range from 0.0 (transparent), to 1.0 (opaque). Values set to less than zero will default to zero. Values more than 1.0 will default to 1. Interaction events set on a transparent widget will still be fired. To disable the events, also set the “isVisible” property to “false”.
Syntax
opacity
Type
Number
Read/Write
Read + Write
Remarks
Note: This property has more priority compared to the values coming from the configured skin.
Example
//Sample code to make the widget transparent by using the opacity property.
frmHome.widgetID.opacity = 0;
//Sample code to make the widget opaque by using the opacity property.
frmHome.widgetID.opacity = 1;
  • Not available in the IDE.
padding Property
This property defines the space between the content of the widget and the widget boundaries. You can use this option to define the top, left, right, and bottom distance between the widget content and the widget boundary.
When you are defining the padding (for any platform) the first time, the value that you enter in the padding field (top, left, right, or bottom) is auto-populated across all the platforms.
The following image illustrates a widget with a defined padding:
Syntax
padding
Type
Array of numbers
Read / Write
Read+Write
Limitations
  • Desktop Web/ SPA platforms do not support padding property in Image widget, Slider widget and Switch widget.
  • If no skin is applied to a Button, then Padding is not supported on iPhone. This is due to iOS Safari browser limitation. If you want the padding to be applied, apply a skin to the button and then apply padding
Example
//Sample code to set the padding property for widgetID Button widget in frmHome Form.
frmHome.widgetID.padding= [2,2,2,2];
  • Available in IDE
  • Android, iOS, Desktop Web and SPA
paddingInPixel Property
This property specifies whether the padding property is to be applied in pixels or in percentage.
Syntax
paddingInPixel
Type
Boolean
Read/Write
Read Only
Remarks
The default value of this property is false.
If the value of this property is true, the padding are applied in pixels.
If the value of this property is false, the padding are applied as set in padding property.
Limitations
Desktop Web/ SPA platforms do not support paddingInPixel property in Image widget, Slider widget and Switch widget.
Example
//Sample code to read paddingInPixel property for widgetID Button widget in frmHome form.
voltmx.print("PaddingInPixel property value is:"+fromHome.widgetID.paddingInPixel);
  • iOS, Android, Desktop Web and SPA.
parent Property
Helps you access the parent of the widget. If the widget is not part of the widget hierarchy, the parent property returns null.
Syntax
parent
Read/Write
Read only
Remarks
Note: The property works for all the widgets inside a FlexForm, FlexContainer or FlexScrollContainer.
Example
function func() {
    voltmx.print("The parent of the widget" + JSON.stringify(Form1.widgetID.parent));
retainContentAlignment Property
This property is used to retain the content alignment property value, as it was defined.
Note: Locale-level configurations take priority when invalid values are given to this property, or if it is not defined.
The mirroring widget layout properties should be defined as follows.
function getIsFlexPositionalShouldMirror(widgetRetainFlexPositionPropertiesValue) {
    return (isI18nLayoutConfigEnabled &&
    localeLayoutConfig[defaultLocale]
    ["mirrorFlexPositionalProperties"] == true &&
    !widgetRetainFlexPositionPropertiesValue);
The following table illustrates how widgets consider Local flag and Widget flag values.
Properties Local Flag Value Widget Flag Value Action
Mirror/retain FlexPositionProperties true true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties true false Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties true not specified Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties false true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties false false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties false not specified Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties not specified false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified not specified Use the Design/Model-specific default layout.
Syntax
Type
Boolean
Read/Write
No (only during widget-construction time)
Example
//Here, we have shown how to use the retainContentAlignment property for Button widget.
retainContentAlignment property for other applicable widgets.*/
var btn = new voltmx.ui.Button({
    "focusSkin": "defBtnFocus",
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "skin": "defBtnNormal",
    "text": "text always from top left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_TOP_LEFT,
    "displayText": true,
    "padding": [0, 0, 0, 0],
    "paddingInPixel": false,
    "retainFlexPositionProperties": false,
    "retainContentAlignment": true
  • Available in IDE
  • iOS, Android, and SPA
retainFlexPositionProperties Property
This property is used to retain flex positional property values as they were defined. The flex positional properties are left, right, and padding.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlexPositionProperties property for Button widget.
retainFlexPositionProperties property for other applicable widgets.*/
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "text": "always left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_CENTER,
    "retainFlexPositionProperties": true,
    "retainContentAlignment": false
  • Available in IDE
retainFlowHorizontalAlignment Property
This property is used to convert Flow Horizontal Left to Flow Horizontal Right.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlowHorizontalAlignment property for Button widget.
retainFlowHorizontalAlignment property for other applicable widgets. */
 "height": "50dp",
 "id": "myButton",
 "isVisible": true,
 "left": "0dp",
 "top": "0dp",
 "width": "260dp",
 "zIndex": 1
 "retainContentAlignment": false,
 "retainFlowHorizontalAlignment ": false
  • Available in IDE
right Property
This property determines the lower right corner of the widget and is measured from the right bounds of the parent container.
The right property determines the position of the right edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, value is ignored. In flow-horizontal layout, the value is ignored.
The right property is used only if the width property is not provided.
Syntax
right
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the right property is measured from left edge of the right sibling widget. The horizontal space between two widgets is measured from right of the left sibling widget and left of the right sibling widget.
Example
//Sample code to set the right property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.right = "50dp";
frmHome.widgetID.right = "10%";
frmHome.widgetID.right = "10px";
rightSideText Property
Specifies the text to be displayed on the right portion of the Switch. You cannot apply image for this property.
Syntax
rightSideText
Type
String
Remarks
Example
//Sample code to set the rightSideText property of a Switch widget.
frmSwitch.mySwitch.rightSideText="OFF";
  • iOS
  • Android
  • SPA
Right Text i18n Key Property
Specifies the key to be used for internationalization of the string specified in the rightSideText property.
Syntax
rightSideText
Type
Example
//Sample code to set the i18n key for rightSideText property of a Switch widget.
frmSwitch.mySwitch.rightSideText=voltmx.i18n.getLocalizedString("select");
  • iOS
  • Android
  • SPA
selectedIndex Property
This property is accessible only from code and it specifies the option of the Switch that must be shown as selected when rendered.
Syntax
selectedIndex
Type
Number
Read/Write
Read + Write
Remarks
In JavaScript, the possible values for this property are 0 and 1. By default, the selected Index is set to 1, and the option in the right portion of the Switch is selected. If you change the selected index to 0, the option in the left portion of the Switch is selected.
If data contains the sections then the selectedIndex indicates the selected row index within the section.
Example
//Sample code to set the selectedIndex property of a Switch widget.
frmSwitch.mySwitch.selectedIndex=0;
//Reading the selectedIndex of the Switch widget.
alert("Switch selectedIndex is ::" + frmSwitch.mySwitch.selectedIndex);
  • iOS
  • Android
  • SPA
skin Property
Specifies a background skin for Switch widget.
Syntax
skin
Type
String
Read/Write
Read + Write
Remarks
In iOS 7 platform, if the skin is not applied, you will get the look and feel of native switch. If the skin is applied you will not get the native look.
Example
//Sample code to set the skin property of a Switch widget.
frmSwitch.mySwitch.skin="switchSkin";
  • iOS
  • Android
  • SPA
switchColor Property
Specifies the foreground color( sliding bar) to the Switch.
Syntax
switchColor
Type
String
Remarks
The color property follows RGB format. By default, grey color is selected.
The following images illustrate the appearance of switch color set to red color:
Example
Form2.mySwitch.switchColor="ff0000";
top Property
This property determines the top edge of the widget and measured from the top bounds of the parent container.
The top property determines the position of the top edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy. In flow-horizontal layout, the distance is measured from the left edge of the parent container.
Syntax
top
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the top property is measured from the bottom edge of the top sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and top of the bottom sibling widget.
Example
//Sample code to set the top property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.top = "50dp";
frmHome.widgetID.top = "10%";
frmHome.widgetID.top = "10px";
widgetSwipeMove Property
This property is used to enable and configure left or right swipe actions for a widget. The widgetSwipeMove Property can be used for all widgets . The most common use case is for implementing swipe action for individual rows in Segment.
Syntax
widgetSwipeMove
Type
String
Read/Write
Read + Write
Input Parameters
Parameter Name Type Default Value Description
translate Boolean true This is an optional parameter. When the value of this parameter is set as true, the widget moves along with the swipe in the same direction.
Xboundaries Array Size of the current widget This is an optional parameter and it defines the boundaries of the swipe in the X-axis.
swipeLeft/swipeRight JS Object   This is an optional parameter and it is used to define the configuration of the widget while swiping to the left/ right. Each swipeLeft or swipeRightparameter is an array of configuration attributes containing translateRange , callback , translatePos , and translate. This JS Object defines the behavior of the widget during the swipe action.
translateRange Array Size of the current widget This is an optional parameter and it defines the sub-boundaries for the action when the swipe action ends.
translatePos Array Previous position of the widget This is an optional parameter and it determines the final translation position to be applied to the widget when the widget swipe reaches the translateRange value.
callback JS Object null This is an optional parameter and it defines the callback which needs to be triggered when the finger swipe reaches the sub boundary defined in translateRange. The attributes inside this parameter are described in the following table.
The following table consists of the parameters of the callback parameter:
Parameter Name Type Description
widgetHandle   This parameter consists of the widget handle or ID of the widget on which the swipe action has been performed.
context JS Object This is applicable only for widgets inside the Segment with row templates. Each context parameter consists of rowIndex, sectionIndex and widgetref
rowIndex Number This parameter stores the row index of the Segment containing the swiped widget.
sectionIndex Number This parameter stores the section index of the Segment containing the swiped widget.
widgetref widgetHandle This parameter stores the handle of the Segment containing the swiped widget.
Remarks
  • For a Segment, the widgetSwipeMove Property is configured while setting the data of the Segment.
Note: It is not recommended to assign the widgetSwipeMove property on a top Flex container of the segment template widget.
Limitations
  • When a translation animation is applied to the same widget that has widgetSwipeMove already configured, the action which has been performed last takes precedence. For example, if you have set a translation animation on a FlexContainer and then set the widgetSwipeMove property, the actions set in widgetSwipeMove take precedence over the translation animation.
  • The state of the swipe transition of the widget is not retained.
  • In a Segment, the widgetSwipeMove Property must be configured for the rows so that they reset to the previous position.
  • If the widgetSwipeMove property is configured on a top level Flex container of a segment template, the onRowClick event will not be triggered. - Applicable on iOS, Android, and SPA.
  • Android limitation: On Android devices, when the user lifts their finger, the transition occurs immediately.
Example
Following is a code snippet for a mail app. Here we have used a Segment for listing the mail and the widgetSwipeMove Property has been configured for the SwipeFlex FlexContainer.
//Here, we have shown how to use the widetSwipeMove property for Button widget.
widgetSwipeMove property for other applicable widgets.*/
//Example of a swipe move configuration.
var swipeMoveConfig = {
 "translate": true,
 "Xboundaries": ["-60%", "60%"],
 "swipeLeft": [{
  "translateRange": ["-60%", "0%"],
  "callback": null,
  "translatePos": "-60%",
  "translate": true
  "translateRange": ["0%", "60%"],
  "callback": null,
  "translatePos": "0%",
  "translate": true
 "swipeRight": [{
  "callback": null,
  "translate": true
  "callback": this.onCallback1,
  "translatePos": "60%",
  "translate": true
this.view.myButton.widgetSwipeMove=swipeMoveConfig;
  • iOS, SPA
width Property
This property determines the width of the widget and is measured along the x-axis.
The width property determines the width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the width may be derived from either the widget or container’s contents by setting the width to “preferred”.
Syntax
width
Type
Read/Write
Read + Write
Remarks
Following are the options that can be used as units of width:
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred width of the widget as width and preferred size of the widget is determined by the widget and may varies between platforms.
Example
//Sample code to set the width property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.width = "50dp";
frmHome.widgetID.width = "10%";
frmHome.widgetID.width = "10px";
zIndex Property
This property specifies the stack order of a widget. A widget with a higher zIndex is always in front of a widget with a lower zIndex.
The zIndex property is used to set the stack, or layer order of a widget. Widgets with higher values will appear “over”, or “on top of” widgets with lower values. Widgets layered over other widgets will override any interaction events tied to widgets beneath. Modifying the zIndex does not modify the order of the widgets in the Volt MX Iris hierarchy, inside of a flexContainer or form. The zIndex property accepts only positive values.
Syntax
zIndex
Type
Number
Read/Write
Read + Write
Remarks
The default value for this property is 1.
Note: Modifying the zIndex does not modify the order of the widgets inside the FlexContainer. If zIndex is same for group of overlapping widgets then widget order decides the order of overlapping. The last added widget is displayed on top.
From Volt MX Iris V9 SP2 FP7, developers can configure the Z Index value for a Responsive Web app as Auto or Custom. When the selected Z Index value is Auto, the default Z Index value of 1 is applied. When the selected Z Index value is Custom, developers can specify a desired numeric value.
Prior to the V9 SP2 FP7 release, the default value for the Z Index was 1. When developers imported any third-party libraries with the Z index set as Auto, content overflow was disabled as the value of Auto is less than 1.
Note: The Z Index value Auto is supported only when the Enable JS Library mode is configured as unchecked.
For existing components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Custom with 1 as the value.
For new components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Auto or 1 based on the project level settings.
Note: If ModalContainer property is set to true in any of the FlexContainer widget, the Z Index value of that container and all of its parent containers should be set to Custom.
voltmx.flex.ZINDEX_AUTO : Constant to configure the Z Index value as auto programmatically.
//Sample code to set the ZIndex value to Auto
 var flx = new voltmx.ui.FlexContainer({
  "id": "flx"
  "zIndex": voltmx.flex.ZINDEX_AUTO
flx.zIndex = voltmx.flex.ZINDEX\_AUTO;
Example
//Sample code to set the zIndex property for widgets.
frmHome.widgetID.zIndex = 300;
