Skip to content
Camera Properties
The properties for Camera widget are:
accessibilityConfig Property
Enables you to control accessibility behavior and alternative text for the widget.
For more information on using accessibility features in your app, see the Accessibility appendix in the VoltMX IrisUser Guide.
Syntax
accessibilityConfig
Type
Object
Read/Write
Read + Write
Remarks
  • The accessibilityConfig property is enabled for all the widgets which are supported under the Flex Layout.
Note: From VoltMX Iris V9 SP2 GA version, you can provide i18n keys as values to all the attributes used inside the accessibilityConfig property. Values provided in the i18n keys take precedence over values provided in a11yLabel, a11yValue, and a11yHint fields.
The accessibilityConfig property is a JavaScript object which can contain the following key-value pairs.
Key Type Description ARIA Equivalent
a11yIndex Integer with no floating or decimal number. This is an optional parameter. Specifies the order in which the widgets are focused on a screen. For all widgets, this parameter maps to the aria-index, index, or taborder properties.
a11yLabel String This is an optional parameter. Specifies alternate text to identify the widget. Generally the label should be the text that is displayed on the screen. For all widgets, this parameter maps to the aria-labelledby property of ARIA in HTML. > Note: For the Image widget, this parameter maps to the alt attribute of ARIA in HTML.
a11yValue String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. This parameter is similar to the a11yLabel parameter. If the a11yValue is defined, the value of a11yValue is appended to the value of a11yLabel. These values are separated by a space.
a11yHint String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. For all widgets, this parameter maps to the aria-describedby property of ARIA in HTML.
a11yHidden Boolean This is an optional parameter. Specifies if the widget should be ignored by assistive technology. The default option is set to false. This option is supported on iOS 5.0 and above, Android 4.1 and above, and SPA For all widgets, this parameter maps to the aria-hidden property of ARIA in HTML.
a11yARIA Object This is an optional parameter. For each widget, the key and value provided in this object are added as the attribute and value of the HTML tags respectively. Any values provided for attributes such as aria-labelledby and aria-describedby using this attribute, takes precedence over values given in a11yLabel and a11yHint fields. When a widget is provided with the following key value pair or attribute using the a11yARIA object, the tabIndex of the widget is automatically appended as zero.{"role": "main"}``aria-label This parameter is only available on the Desktop Web platform.
Android limitations
  • If the results of the concatenation of a11y fields result in an empty string, then accessibilityConfig is ignored and the text that is on widget is read out.
  • The soft keypad does not gain accessibility focus during the right/left swipe gesture when the keypad appears.
SPA/Desktop Web limitations
  • When accessibilityConfig property is configured for any widget, the tabIndex attribute is added automatically to the accessibilityConfig property.
  • The behavior of accessibility depends on the Web browser, Web browser version, Voice Over Assistant, and Voice Over Assistant version.
  • Currently SPA/Desktop web applications support only a few ARIA tags. To achieve more accessibility features, use the attribute a11yARIA. The corresponding tags will be added to the DOM as per these configurations.
Example 1
This example uses the button widget, but the principle remains the same for all widgets that have an accessibilityConfig property.
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the accessibilityConfig Property for button widget.
/*You need to make a corresponding use of the accessibilityConfig property for other applicable widgets.*/
Form1.myButton.accessibilityConfig = {
    "a11yLabel": "Label",
    "a11yValue": "Value",
    "a11yHint": "Hint"
Example 2
This example uses the button widget to implement internationalization in accessibilityConfig property, but the principle remains the same for all widgets.
/*Sample code to implement internationalization in accessibilityConfig property in Native platform.*/
    "a11yLabel": voltmx.i18n.getLocalizedString("key1")
/*Sample code to implement internationalization in accessibilityConfig property in Desktop Web platform.*/
    "a11yLabel": "voltmx.i18n.getLocalizedString(\"key3\")"
Platform Availability
  • Available in the IDE
  • iOS, Android, SPA, and Desktop Web
accessMode Property
Specifies how the captured image must be stored.
Syntax
accessMode
Type
Number
Read/Write
Read + Write
Read only in the iOS platform.
Remarks
The default value for the property is constants.CAMERA_ACCESS_MODE_PUBLIC.
The options are:
  • constants.CAMERA_ACCESS_MODE_PUBLIC: The captured image or video is stored on the device and is accessible to all the applications on the device. For example, the captured images are accessible in the ImageGallery.
  • constants.CAMERA_ACCESS_MODE_PRIVATE: The captured image or video is stored on the device and is not accessible to any other application on the device.
Note: In the Android platform, CAMERA_ACCESS_MODE_PRIVATE is not respected when the enbaleOverlay property is set to false.
  • constants.CAMERA_ACCESS_MODE_INMEMORY: For videos, the option is supported only on the iOS platform. The captured camera image or video is stored in memory and is never written to the disk.
Note: In the Android platform, CAMERA_ACCESS_MODE_INMEMORY is not respected if the enableOverlay property is set to true and the captureMode is video, and even if the enableOverlay property is set to false.
For backward compatibility, the following options are also supported:
  • CAMERA_IMAGE_ACCESS_MODE_PUBLIC
  • CAMERA_IMAGE_ACCESS_MODE_PRIVATE
  • CAMERA_IMAGE_ACCESS_MODE_INMEMORY
Example
//Sample code to set accessMode property for Camera widget.
frmCamera.myCamera.accessMode=constants.CAMERA_ACCESS_MODE_PRIVATE;
Available in the IDE.
  • iPhone
  • iPad
  • Android
backgroundColor Property
Specifies the background color of the widget.
Syntax
backgroundColor
Type
Color constant or Hexadecimal number
Read/Write
Read + Write
Remarks
  • The initial value of backgroundColor has to be specified explicitly. If not, Iris will not deduce the values from the existing skin and this will lead to undefined behavior.
  • Colors can be specified using a 6 digit or an 8-digit hex value with alpha position. For example, ffff65 or ffffff00.
  • When the 4-byte color format (RGBA) string is used, an alpha (A) value of 65 specifies that the color is transparent. If the value is 00, the color is opaque. The Alpha value is in percentage and must be given in the hexadecimal value for the color (100% in hexadecimal value is 65).
    For example, red complete opaque is FF000000. Red complete transparent is FF000065. The values 0x and # are not allowed in the string.
  • A color constant is a String that is defined at the theme level. Ensure that you append the $ symbol at the beginning of the color constant.
  • This property does not have a default value.
  • This property has more priority than (and overrides) the background property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
  • The backgroundColor, backgroundColorTwoStepGradient, backgroundColoMultiStepGradient, and backgroundImage properties are mutually exclusive. The property that was set most recently is given higher priority over other properties.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColor property.
Form1.btn1.backgroundColor = "ea5075";
  • Android
  • iOS
  • Desktop Web (Not available on Desktop Web Legacy SDK)
backgroundColorMultiStepGradient Property
Specifies the multi-step gradient color for the background of the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Input Parameters
  • gradientType [Constant]: Specifies the configuration type of the gradient. This parameter can have the following constant values:
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP: Constant for the gradient type toTop.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_RIGHT: Constant for the gradient type toRight.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_BOTTOM: Constant for the gradient type toBottom.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_LEFT: Constant for the gradient type toLeft.
    • voltmx.skin.MULTI_STEP_GRADIENT_TYPE_CUSTOM: Constant for the gradient type custom.
      For the custom gradient type, you must specify the angle by using the angle property.
    • angle [Number]: Specifies the angle for the gradient in degrees, counted counter-clockwise. This property is only applicable for the custom gradient type.
    • colors [Array]: Specifies the colors for the multi-step gradient. Colors is an array of color hex values that indicate the reference color values of the gradient. This parameter contains an array of hexadecimal numbers that represent the colors or constants defined at the theme level.
    • colorStops [Array]: Specifies the color stops for the multi-step gradient. Color Stops are the locations of the reference colors on the gradient, from 0 (the start of the gradient) to 100 (the final value of the gradient). This parameter contains an array of numbers that represent the color stops.
Remarks
  • The default value of the gradientType key is voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColorMultiStepGradient property.
Form1.btn1.backgroundColorMultiStepGradient = {
    "gradientType": voltmx.skin.MULTI_STEP_GRADIENT_TYPE_CUSTOM
    "angle": 45,
    "colors": ["ea5075", "f1fa70", "eefd04"],
    "colorStops": [0, 90, 100]
  • Android
  • iOS
backgroundColorTwoStepGradient Property
Specifies the two-step gradient color for the background of the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Input Parameters
  • topColor [Constant or Hex]: Specifies the top color of the two-step gradient. The value of this parameter can be a hexadecimal number that represents a color or a constant that is defined at the theme level.
  • bottomColor [Constant or Hex]:Specifies the bottom color of the two-step gradient. The value of this parameter can be a hexadecimal number that represents a color or a constant that is defined at the theme level.
  • style [Constant]: Specifies the configuration style of the two-step gradient. This parameter can have the following constant values:
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT: Constant for the vertical gradient style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_SPLIT: Constant for the vertical split style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_HORIZONTAL_GRADIENT: Constant for the horizontal gradient style.
    • voltmx.skin.TWO_STEP_GRADIENT_STYLE_HORIZONTAL_SPLIT: Constant for the horizontal split style.
Remarks
  • The default value of the style key is voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundColorTwoStepGradient property.
Form1.btn1.backgroundColorTwoStepGradient = {
     "topColor": "ea5075",
    "bottomColor": "eefd04",
    "style": voltmx.skin.TWO_STEP_GRADIENT_STYLE_VERTICAL_GRADIENT
  • Android
  • iOS
backgroundImage Property
Sets the image for the background of the widget.
Syntax
backgroundImage
Type
String
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the backgroundImage property.
Form1.btn1.backgroundImage = "bgImg.png";
  • Android
  • iOS
base64 Property
Returns the base64-encoded string of the image raw bytes. If the image source is a URL, and if the image is not downloaded, or if it encounters an error while downloading, null/nil is returned.
Syntax
base64
Type
JSObject
Read/Write
Read + Write
Remarks
This is a non-constructor property. You cannot set the property through a widget constructor. But you can read and write data to the property.
Example
//Using base64 property in a form frmOnclick
function customhandlerbase64(camerawidget){
    frmOnclick2.img1.base64 = camerawidget.base64;
    frmOnclick2.show();
  • Not available in the IDE
  • Android
  • iOS
  • Desktop Web
borderColor Property
Specifies the border color of the widget.
Syntax
borderColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the border property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderColor property.
Form1.btn1.borderColor = "ea5075";
  • Android
  • iOS
borderColorGradient Property
Specifies the multi-step gradient color for the border of the widget.
Syntax
borderColorGradient
Type
JSON Object
Read/Write
Read + Write
Input Parameters
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderColorGradient property.
Form1.btn1.borderColorGradient = {
    "angle": 45,
  • Android
  • iOS
borderStyle Property
Specifies the border style for the widget.
Syntax
borderStyle
Type
Constant
Read/Write
Read + Write
Remarks
  • This property can have the following constant values:
    • voltmx.skin.BORDER_STYLE_PLAIN: Constant for the plain border style.
    • voltmx.skin.BORDER_STYLE_ROUNDED_CORNER: Constant for the rounded corner style.
    • voltmx.skin.BORDER_STYLE_COMPLETE_ROUNDED_CORNER: Constant for the complete rounded corner style.
    • voltmx.skin.BORDER_STYLE_CUSTOM: Constant for the custom border style.
    • The cornerRadius property is only applicable when the borderStyle is voltmx.skin.BORDER_STYLE_CUSTOM.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderStyle property.
Form1.btn1.borderStyle = voltmx.skin.BORDER_STYLE_PLAIN;
  • Android
  • iOS
borderWidth Property
Specifies the width of the border for the widget in pixels.
Syntax
borderWidth
Type
Number or JSON Object
Read/Write
Read + Write
Remarks
  • The default unit for the value of this property is pixels.
  • The Desktop Web platform supports both Number and JSON Object (with the top, bottom, right, and left keys) values for the borderWidth parameter. The Android and iOS platforms support only Number values for the borderWidth parameter.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the borderWidth property.
 Form1.btn1.borderWidth = 2;
  • Android
  • iOS
bottom Property
This property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
The bottom property determines the position of the bottom edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the bottom edge of the parent container. In flow-vertical layout, the value is ignored. In flow-horizontal layout, the value is ignored.
The bottom property is used only if the Height property is not provided.
Syntax
bottom
Type
String
Read/Write
Read + Write
Remarks
The property determines the bottom edge of the widget and is measured from the bottom bounds of the parent container.
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the bottom property is measured from the top edge of bottom sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and the top of the bottom sibling widget.
Example
//Sample code to set the bottom property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.bottom = "50dp";
frmHome.widgetID.bottom = "10%";
frmHome.widgetID.bottom = "10px";
  • iOS, Android, SPA , and Desktop Web
cameraOptions Property
Specifies the camera options that can be used on a form.
Syntax
cameraOptions
Type
JSObject
Read/Write
Read + Write
Remarks
The following are the configurable properties:
  • flashMode:Enables you to control the flash on the device when the camera is turned on.
    Note: Devices may have different flash capabilities that are dependent on the camera driver.
    Default:constants.FLASH_MODE_AUTO
    The options are:
    • constants.FLASH_MODE_AUTO: Specifies the flash must be turned on when required.
    • constants.FLASH_MODE_ON: Specifies the flash must be turned on when you take a picture.
    • constants.FLASH_MODE_OFF: Specifies the flash must not be turned on even when you take a picture.
    • constants.FLASH_MODE_ALWAYS_ON: Specifies the flash must not be turned on constantly when the camera is open. On the Android platform, the option is respected only when the overlay form is enabled.
    • hideControlBar:Enables you to show or hide the default control bar (capture and cancel buttons) of the respective platforms. Default:false
    Note: For the iOS 7 and later versions, when the hideControlBar is set to true, there will be a blank space (black or white color) in place of camera control bar in an iPhone device. The space of the control bar depends on the device model (iPhone 5 has 96px and iPhone 4 has 54 px).Note the space of the control bar when designing the overlay form for the camera.
    Note: The hideControlBar is applicable only when the enableOverlay property is set to true.
  • focusMode: Specifies the focus mode for the camera. This option is available only for Android platform and is respected when the enableOverlay is set to true. The different values that can be assigned to this property are as follows:
    • constants.CAMERA_FOCUS_MODE_AUTO (Default value for photo mode)
    • constants.CAMERA_FOCUS_MODE_CONTINUOUS (Default value for video mode)
Example
//Sample code to set cameraOptions property for Camera widget.
frmCamera.myCamera.cameraOptions={
        flashMode: "constants.FLASH_MODE_ON",
        hideControlBar: true,
        focusMode: "constants.FOCUS_MODE_CONTINUOUS"
  • iPhone
  • iPad
  • Android
captureOrientation Property
Specifies the orientation of the captured image.
Syntax
captureOrientation
Type
Number
Read/Write
Read + Write
Remarks
The default value for the property is CAMERA_CAPTURE_ORIENTATION_DEFAULT
Note: The property works for the complete image and not for the cropped image when referenceImageToCrop is not provided. In cases where referenceImageToCrop is provided, the property is ignored.
The options are:
  • CAMERA_CAPTURE_ORIENTATION_LANDSCAPE: On the device the camera is always turned sideways so that the height of the screen becomes the width.
  • CAMERA_CAPTURE_ORIENTATION_PORTRAIT: On the device the camera is always displayed such that the horizontal sides are shorter than the vertical sides.
Example
//Sample code to set captureOrientation property for Camera widget.
frmCamera.myCamera.captureOrientation=constants.CAMERA_CAPTURE_ORIENTATION_LANDSCAPE;
  • iPhone
  • iPad
captureMode Property
Specifies the capture mode of the camera.
Syntax
captureMode
Type
Number
Read/Write
Read + Write
Remarks
Note: For Android platform, any changes to this property is ignored when the preview is on.
The options are:
  • constants.CAMERA_CAPTURE_MODE_PHOTO (Default)
  • constants.CAMERA_CAPTURE_MODE_VIDEO
Note: In the Android platform, set the app level permissions CAMERA, WRITE_EXTERNAL_STORAGE and CAMERA_RECORD_AUDIO to record a video.
Example
//Sample code to set captureMode property for Camera widget.
frmCamera.myCamera.captureMode=constants.CAMERA_CAPTURE_MODE_VIDEO;
  • iPhone
  • iPad
  • Android
cameraSource Property
Specifies the source of the camera, either front or rear.
Syntax
cameraSource
Type
Number
Read/Write
Read + Write
Remarks
The options are:
  • constants.CAMERA_SOURCE_DEFAULT (Default Value)
  • constants.CAMERA_SOURCE_REAR
  • constants.CAMERA_SOURCE_FRONT
Note: For the Android platform when the cameraSource is set to default, the platform checks for the rear camera. If the rear camera does not exist, the platform checks for the front camera. The property is not supported when the property enableOverlay is set to false.
Note: For the Android platform, in video mode, changing this property when the preview is on, requires setting the videoQualityLevel appropriately. otherwise, the onFailure event is invoked with an error code as CAMERA_PREVIEW_UNAVAILABLE. This happens because different camera sources have different quality levels supported, so before using particular source, supported level value needs to be set.
The following table illustrates the various differences between Native Camera UI and Custom Camera UI.
Native Camera UI Custom Camera UI
Brightness settings option is available. Brightness settings option is not available.
You can resize the camera window, even though Maximize and Minimize buttons are not available. You cannot resize the camera window.
After you capture an image, the captured image is displayed for saving or deleting. The captured image is automatically saved in the Pictures folder/application local location/in phone memory, based on the Camera widget access mode .
Once you save the captured image, the UI closes automatically. The captured image is automatically saved but the UI dialog does not close; you must close it by clicking the X button at the upper right corner of the screen.
You can move the camera window. You cannot move the camera window.
Native Camera UI
Custom Camera UI
Example
//Sample code to set cameraSource property for Camera widget.
frmCamera.myCamera.cameraSource=constants.CAMERA_SOURCE_FRONT;
  • iPhone
  • iPad
  • Android
  • Desktop Web
centerX Property
This property determines the center of a widget measured from the left bounds of the parent container.
The centerX property determines the horizontal center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
centerX
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the centerX property is measured from right edge of the left sibling widget.
Example
//Sample code to set the centerX property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerX = "50dp";
frmHome.widgetID.centerX = "10%";
frmHome.widgetID.centerX = "10px";
centerY Property
This property determines the center of a widget measured from the top bounds of the parent container.
The centerY property determines the vertical center of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-horizontal layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy.
Syntax
centerY
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the centerY property is measured from bottom edge of the top sibling widget.
Example
//Sample code to set the centerY property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.centerY = "50dp";
frmHome.widgetID.centerY = "10%";
frmHome.widgetID.centerY = "10px";
compressionLevel Property
Specifies the compression level or picture quality with which the captured image must be stored. You can specify the compression level value between 0 (best picture quality) and 100 (low picture quality).
Syntax
compressionLevel
Type
Number
Read/Write
Read + Write
Remarks
The default value for the property is 0. The property is applicable only when the imageFormat is jpeg.
Note: In the Android platform, the compressionLevel property is respected only when the enableOverlay is set to true and the captureMode is set to camera mode. Even if the enableOverlay is set to true and if the captureMode is set as video mode, the compressionLevel property is not respected.
Example
//Sample code to set compressionLevel property for Camera widget.
frmCamera.myCamera.compressionLevel=25;
  • Available on all platforms except SPA.
contentAlignment Property
This property specifies the alignment of the text on the widget with respect to its boundaries.
Syntax
contentAlignment
Type
Number
Read/Write
Read+Write
Remarks
The default value for the property is CONTENT_ALIGN_CENTER.
The following are the available options:
  • constants.CONTENT_ALIGN_TOP_LEFT
  • constants.CONTENT_ALIGN_TOP_CENTER
  • constants.CONTENT_ALIGN_TOP_RIGHT
  • constants.CONTENT_ALIGN_MIDDLE_LEFT
  • constants.CONTENT_ALIGN_CENTER
  • constants.CONTENT_ALIGN_MIDDLE_RIGHT
  • constants.CONTENT_ALIGN_BOTTOM_LEFT
  • constants.CONTENT_ALIGN_BOTTOM_CENTER
  • constants.CONTENT_ALIGN_BOTTOM_RIGHT
Limitations
Desktop Web/ SPA platforms do not support contentAlignment property in Camera widget, ComboBox widget and ListBox widget.
Example
/*Sample code to set the contentAlignment property of the widgetID Button widget in frmHome Form.*/
frmHome.widgetID.contentAlignment=constants.CONTENT_ALIGN_TOP_LEFT;
  • Available in IDE
cornerRadius Property
Specifies the radius of the border for the widget.
Syntax
cornerRadius
### Type
Read/Write
Read + Write
Remarks
  • For a Responsive Web app, a corner radius of value zero applies a plain border, and a corner radius value greater than zero applies a rounded border.
  • The Android and Desktop Web platforms support both Number and JSON Object (with the top, bottom, right, and left keys) values for the cornerRadius parameter. The iOS platform supports only Number values for the cornerRadius parameter.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the cornerRadius property.
 Form1.btn1.cornerRadius = 60;
  • Android
  • iOS
cursorType Property
In Desktop Web applications, when you hover the mouse over any widget, a mouse pointer appears. Using the cursorType property in Iris, you can specify the type of the mouse pointer.
Syntax
cursorType
Type
String.
You must provide valid CSS cursor value such as wait, grab, help, etc. to the cursorType property.
Read/Write
Read + Write
Remarks
To add the cursorType property using VoltMX Iris in a Desktop Web application, follow these steps.
  1. In VoltMX Iris, open the Desktop Web application. From the Project explorer, expand Responsive Web/ Desktop> Forms and select the form to which you need to make the changes.
  2. On the canvas, select the widget for which you want to specify the cursor type. For example, button.
  3. From the Properties panel, navigate to the Skin tab > Hover Skin tab.
    You will find that the details of the hover skin is not enabled here.
  4. Check the Enable option to add a hover skin to your widget.
    The details and configurations of the hover skin is enabled.
  5. Under the General section, for the Platform option, click the ellipsis icon.
    The Fork Skin window appears.
  6. In the Fork Skin window, for Desktop, check under HTML5 SPA.
  7. Click Ok. You have successfully forked your hover skin for Desktop Web application.
    You can see that the Cursor Type property has been added under the General section.
  8. Select a value from the drop-down list to set the Cursor Type for the widget.
Example
 //This is a generic property and is applicable for many widgets.
/*The example provided is for the Button widget. Make the required changes in the example while using other widgets.*/
frmButton.myButton.cursorType = "wait";
  • Available in IDE
  • Desktop Web
disabledStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is disabled or blocked.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the disabledSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the disabledStateSkinProperties property.
Form1.btn1.disabledStateSkinProperties= {
     background: {
        backgroundType: voltmx.skin.BACKGROUND_TYPE_MULTI_STEP_GRADIENT,
        backgroundColorMultiStepGradient : {
            gradientType: voltmx.skin.MULTI_STEP_GRADIENT_TYPE_TO_TOP,
            colors: ["ea5075", "f1fa70", "eefd04"],
            colorStops: [0, 90, 100]
    border: {
        borderType: voltmx.skin.BORDER_TYPE_SINGLE_COLOR,
        borderColor: "ea5075",
        borderStyle: voltmx.skin.BORDER_STYLE_PLAIN,
        borderWidth: 50
    fonts: {
        fontColor: "ea5075",
        fontFamily: "Serif",
        fontSize: '100',
        fontStyle: voltmx.skin.FONT_STYLE_NONE,
        fontWeight: voltmx.skin.FONT_WEIGHT_NORMAL
    textShadow: {
        textShadowRadius: 5,
        textShadowColor: "ea5075",
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
enable Property
The enable property is used to control the actionability of the widgets. In a scenario where you want to display a widget but not invoke any action on the widget, configure the enable property to false to achieve it.
This is a constructor level property and applicable for all widgets in VoltMX Iris.
Syntax
enable
Type
Boolean
Read/Write
Read + Write
Remarks
The default value of this property is true.
When enable property is configured to true, the action associated with a widget can be invoked by the user in the application.
When enable property is configured to false, the action associated with a widget cannot be invoked by the user in the application.
Example
/*The example provided is for the Button widget. Make the changes required in the example while using other widgets.*/
frmButton.myBtn.enable= true;
  • Android, iOS, SPA, and Desktop web
enableCache Property
The property enables you to improve the performance of Positional Dimension Animations.
Syntax
enableCache
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for this property is true.
Note: When the property is used, application consumes more memory. The usage of the property enables tradeoff between performance and visual quality of the content. Use the property cautiously.
Example
Form1.widgetID.enableCache = true;
  • Available in the IDE.
enableOverlay Property
The camera is launched with capability of over-lay a Form UI over the camera view.
Syntax
enableOverlay
Type
Boolean
Read/Write
No
Remarks
The default value for the property is false. If set to true, the camera preview is overlaid on the form. If set to false, the camera preview is not overlaid on the form.
Example
//Sample code to set enableOverlay property as true for Camera widget.
frmCamera.myCamera.enableOverlay=true;
  • iPhone
  • iPad
  • Android
enablePhotoCropFeature Property
Enables you to crop the captured image.
Syntax
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for the property is false. If set to true, the photo crop feature is enabled. If set to false, the photo crop feature is not enabled.
Note: The property is ignored when you set the enableOverlay property as true.
Example
//Sample code to set enablePhotoCropFeature property as true for Camera widget.
frmCamera.myCamera.enablePhotoCropFeature=true;
enableZoom Property
Set this property as true to enable pinch to zoom of the camera preview in the overlay mode. The property is supported only when the enableOverlay property is set to true.
Syntax
enableZoom
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for the property is false. If set to true, the pinch to zoom of the camera preview is enabled. If set to false, the pinch to zoom of the camera preview is disabled.
Note: The property works only on devices with Android 2.2.x and later versions, which support camera zooming . When the camera is zoomed, the actual picture size may be smaller than the picture size setting based on Native Android Documentation.
Note: In the Android platform, the enableZoom property is not respected when enableOverlay property is set to false.
Example
//Sample code to set enableZoom property as true for Camera widget.
frmCamera.myCamera.enableZoom=true;
  • Android
  • Android Tablet
focusSkin Property
Specifies the look and feel of the widget when in focus.
Syntax
focusSkin
Type
String
Read/Write
Read + Write
Example
//Sample code to set the focusSkin property for Camera widget.
frmCamera.myCamera.focusSkin="camFSkin";
  • Available on all platforms except server-side Mobile Web and SPA.
focusStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is in focus.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the focusSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the focusStateSkinProperties property.
 Form1.btn1.focusStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
  • iOS
fontColor Property
Specifies the font color of the widget.
Syntax
fontColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the fonts property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontColor property.
Form1.btn1.fontColor = "ea5075";
  • Android
  • iOS
fontFamily Property
Specifies the font family for the font of the widget.
Syntax
fontFamily
Type
String
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontFamily property.
 Form1.btn1.fontFamily = "Serif";
  • Android
  • iOS
fontSize Property
Specifies the font size for the widget in percentage (%) units.
Syntax
fontSize
Type
Number
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontSize property.
 Form1.btn1.fontSize = 150;
  • Android
  • iOS
fontStyle Property
Specifies the font style for the widget.
Syntax
fontStyle
Type
Constant
Read/Write
Read + Write
Remarks
    • voltmx.skin.FONT_STYLE_NONE: Constant for the normal font style.
    • voltmx.skin.FONT_STYLE_ITALIC: Constant for the italic font style.
    • voltmx.skin.FONT_STYLE_UNDERLINE: Constant for the underline font style.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontStyle property.
Form1.btn1.fontStyle = voltmx.skin.FONT_STYLE_NONE;
  • Android
fontWeight Property
Specifies the weight for the font of the widget.
Syntax
fontWeight
Type
Constant
Read/Write
Read + Write
Remarks
    • voltmx.skin.FONT_WEIGHT_NORMAL: Constant for the normal font weight.
    • voltmx.skin.FONT_WEIGHT_BOLD: Constant for the bold font weight.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the fontWeight property.
Form1.btn1.fontWeight = voltmx.skin.FONT_WEIGHT_NORMAL;
  • Android
height Property
It determines the height of the widget and measured along the y-axis.
The height property determines the height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the height may be derived from either the widget or container’s contents by setting the height to “preferred”.
Syntax
height
Type
Number, String, and Constant
Read/Write
Read + Write
Remarks
Following are the available measurement options:
  • %: Specifies the values in percentage relative to the parent dimensions.
  • px: Specifies the values in terms of device hardware pixels.
  • dp: Specifies the values in terms of device independent pixels.
  • default: Specifies the default value of the widget.
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred height of the widget as height and preferred size of the widget is determined by the widget and may varies between platforms.
Example
//Sample code to set the height property for widgets by using DP, Percentage and Pixels.
frmHome.camera1.height="50dp";
frmHome.camera1. height="10%";
frmHome.camera1. height="10px";
  • iOS
  • Android
  • SPA
  • Desktop Web
hoverSkin Property
Specifies the look and feel of a widget when the cursor hovers on the widget.
Syntax
hoverSkin
Type
String
Read/Write
Read + Write
Example
Setting the hoverSkin property on an existing widget
FormHover.widgetID.hoverSkin="theHoverSkin";
//the Hover Skin is a hover skin created under Skins tab
Note: To apply hoverSkin for dynamically created widgets or cloned widgets, assign hoverSkin dynamically after adding the widget to the form hierarchy. This is applicable for the Desktop web platform.
formid.widgetid.hoverSkin = "skinname";
hoverStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the cursor hovers on the widget.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the hoverSkin property of the configured skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the hoverStateSkinProperties property.
 Form1.btn1.hoverStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
id Property
id is a unique identifier of the Camera Widget consisting of alphanumeric characters. Every Camera Widget should have a unique id within a Form.
Syntax
id
Type
String - [Mandatory]
Read/Write
Read only
Example
//Defining the properties for a Camera with id:"camera1".
var camBasic = {
    skin: "camSkin",
    focusSkin: "camFSkin",
    text: "Camera",
    isVisible: true
var camLayout = {
    padding: [5, 5, 5, 5],
    margin: [5, 5, 5, 5],
    paddingInPixel: true,
    marginInPixel: true,
    hExpand: true,
    vExpand: true
var camPSP = {};
//Creating the Camera.
var camera1 = new voltmx.ui.Camera(camBasic, camLayout, camPSP);
//Reading id of Camera.
alert("Camera id::" + camera1.id);
  • Android
  • iOS
  • Desktop Web
imageFormat Property
Specifies if the image must be stored as a PNG (Portable Network Graphics) or a JPEG (Joint Photographic Experts Group) image.
Syntax
imageFormat
Type
Number
Read/Write
Read + Write
Remarks
The default value for the property is CAMERA_IMAGE_FORMAT_PNG.
  • CAMERA_IMAGE_FORMAT_PNG:When you select the option, the image is always stored in the PNG format.
  • CAMERA_IMAGE_FORMAT_JPEG:When you select the option, the image is always stored in the PEG format.
Note: In the Android platform, the imageFormat property is respected only when the enableOverlay is set to true and the captureMode is set to camera. The imageFormat property is not respected when the captureMode is set to video, even if the enableOverlay is set to true.
Example
//Sample code to set the imageFormat property for Camera widget.
frmCamera.myCamera.imageFormat=constants.CAMERA_IMAGE_FORMAT_PNG;
  • iPhone
  • iPad
info Property
A custom JSObject with the key-value pairs that a developer can use to store the context with the widget. The info Property helps you avoid globals in programming.
Syntax
info
Type
JSObject
Read/Write
Read + Write
Remarks
Note: This is a non-constructor property. You cannot set the property through a widget constructor. You can read and write data to the property.
The info property can hold any JSObject. After assigning the JSObject to the info property, you should not modify t. For example,
var inf = {a: 'hello'};
widget.info = inf; //works
widget.info.a = 'hello world';
//This will not update the widget info a property to Hello world.
//widget.info.a will have old value as hello.
Example
//Sample code to set info property for a Camera widget
frmCamera.myCamera.info = {
    key: "camera images"
//Reading the info of the Camera widget.
voltmx.print("Camera info ::" +frmCamera.myCamera.info);
  • Not available in the IDE.
  • Available on all platforms except on server-side Mobile Web and SPA.
isVisible Property
The property controls the visibility of a widget on the form.
Syntax
isVisible
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for the property is true. If set to false, the widget is not displayed. If set to true, the widget is displayed.
Note: The visibility of the widget can be controlled using the setVisibility method.
Example
//Here, we have shown how to use the isVisible Property for camera widget.
isVisible Property for other applicable widgets.*/
frmCamera.myCamera.isVisible=true;
  • Android, iOS and Desktop Web
left Property
This property determines the lower left corner edge of the widget and is measured from the left bounds of the parent container.
The left property determines the position of the left edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, the distance is measured from the left edge of the parent container. In flow-horizontal layout, the distance is measured from the right edge of the previous sibling widget in the hierarchy.
Syntax
left
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the left property is measured from right edge of the left sibling widget.
Example
//Sample code to set the left property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.left = "50dp";
frmHome.widgetID.left = "10%";
frmHome.widgetID.left = "10px";
maxHeight Property
This property specifies the maximum height of the widget and is applicable only when the height property is not specified.
The maxHeight property determines the maximum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxHeight value overrides the preferred, or “autogrow” height, if the maxHeight is less than the derived content height of the widget.
Syntax
maxHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxHeight = "50dp";
frmHome.widgetID.maxHeight = "10%";
frmHome.widgetID.maxHeight = "10px";
maxSideOfTheImage Property
Specifies the width of the camera picture/image. The property sets the resolution (width * height) of the camera picture. For example, if maxSideOfTheImage = 1600, if the device has exact matching resolution (in width ie. 1600*1200), then 1600 * 1200 resolution is used to set the camera picture size.
Syntax
maxSideOfTheImage
Type
Number
Read/Write
Read + Write
Remarks
Note: In the Android platform, the maxSideOfTheImage property is respected only when the enableOverlay is set to true and the captureMode is set to camera. The maxSideOfTheImage property is not respected when the captureMode is set to video, even if the enableOverlay is set to true.
Example
//Sample code to set maxSideOfTheImage property for a Camera widget
frmCamera.myCamera.maxSideOfTheImage=20;
maxWidth Property
This property specifies the maximum width of the widget and is applicable only when the width property is not specified.
The Width property determines the maximum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The maxWidth value overrides the preferred, or “autogrow” width, if the maxWidth is less than the derived content width of the widget.
Syntax
maxWidth
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the maxWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.maxWidth = "50dp";
frmHome.widgetID.maxWidth = "10%";
frmHome.widgetID.maxWidth = "10px";
minHeight Property
This property specifies the minimum height of the widget and is applicable only when the height property is not specified.
The minHeight property determines the minimum height of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minHeight value overrides the preferred, or “autogrow” height, if the minHeight is larger than the derived content height of the widget.
Syntax
minHeight
Type
Number
Read/Write
Read + Write
Example
//Sample code to set the minHeight property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minHeight = "50dp";
frmHome.widgetID.minHeight = "10%";
frmHome.widgetID.minHeight = "10px";
minWidth Property
This property specifies the minimum width of the widget and is applicable only when the width property is not specified.
The minWidth property determines the minimum width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. The minWidth value overrides the preferred, or “autogrow” width, if the minWidth is larger than the derived content width of the widget.
Syntax
minWidth
Type
Number
Read/Write
Read only
Example
//Sample code to set the minWidth property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.minWidth = "50dp";
frmHome.widgetID.minWidth = "10%";
frmHome.widgetID.minWidth = "10px";
nativeUserInterface Property
Specifies if the camera must have the native interface on camera view (an interface with the default platform controls for camera) or the user interface with custom options.
Syntax
nativeUserInterface
Type
Boolean
Read/Write
Read + Write
Remarks
The default value for the property is true. If set to false, the user interface with custom options is displayed. If set to true, the native interface of the camera is displayed based on the platforms.
Note: For iOS devices, avoid the overlayForm option when the nativeUserInterface is set to true.
Example
//Sample code to enable nativeUserInterface property for a Camera widget
frmCamera.myCamera.nativeUserInterface=true;
  • iPhone
  • iPad
opacity Property
Specifies the opacity of the widget. The value of this property must be in the range 0.0 (transparent) to 1.0 (opaque). Any values outside this range are fixed to the nearest minimum or maximum value.
Specifies the opacity of the widget. Valid opacity values range from 0.0 (transparent), to 1.0 (opaque). Values set to less than zero will default to zero. Values more than 1.0 will default to 1. Interaction events set on a transparent widget will still be fired. To disable the events, also set the “isVisible” property to “false”.
Syntax
opacity
Type
Number
Read/Write
Read + Write
Remarks
Note: This property has more priority compared to the values coming from the configured skin.
Example
//Sample code to make the widget transparent by using the opacity property.
frmHome.widgetID.opacity = 0;
//Sample code to make the widget opaque by using the opacity property.
frmHome.widgetID.opacity = 1;
overlayConfig Property
Specifies the overlay configuration parameters for overlaying a form.
Syntax
overlayConfig
Type
JSObject
Read/Write
Read + Write
Remarks
The following are the configurable properties applicable to iOS and Android platforms:
  • overlayForm:Specifies the reference of the form to be rendered over the camera view. When the option is set, the captureOrientation property is not respected. The overlayForm parameter is ready only in the iOS platform.
Default:None
  • referenceImageToCrop:Specifies the reference of the Image Widget in the overlayForm which guides the camera to crop the captured image to the referenceImage dimensions. Default:None
  • tapAnywhere:Specifies to capture an image with a tap on the camera overlay view. This option is applicable to Android platforms only. Default:false
Following are the configurable properties supported on iOS and Android platforms for the video capture mode.
  • captureButtonSkin:Specifies the skin for a captured button. The option is applicable to the Android platform only.
  • captureButtonText:Specifies the text for a captured button. The option is applicable to the Android platform only.
  • startVideoButtonSkin: Specifies the skin to the button to start the video.
  • stopVideoButtonSkin: Specifies the skin to the button to stop the video.
  • startVideoButtonText: Specifies the text to the button to start the video.
  • stopVideoButtonText: Specifies the text to the button to stop the video.
  • timerControlSkin: Specifies the skin to the timer control.
Example
/*Sample code to set overlayConfig property for a Camera widget where frmSample is the overlay form.*/
frmCamera.myCamera.overlayConfig = {
 overlayForm: "frmSample",
 referenceImageToCrop: "refImg.png",
 tapAnywhere: false,
 captureButtonSkin: "snap.png",
 captureButtonText: "Back"
  • iPhone
  • iPad
  • Android
parent Property
Helps you access the parent of the widget. If the widget is not part of the widget hierarchy, the parent property returns null.
Syntax
parent
Read/Write
Read only
Remarks
Note: The property works for all the widgets inside a FlexForm, FlexContainer or FlexScrollContainer.
Example
function func() {
    voltmx.print("The parent of the widget" + JSON.stringify(Form1.widgetID.parent));
poster Property
This property helps you to define an image to be displayed on the Camera widget, when the device camera is not open.
Syntax
poster
Type
String
Read/Write
Read + Write
Example
//Sample code to set poster property for a Camera widget
frmCamera.myCamera.poster="cameraicon.png";
  • Desktop Web
pressedStateSkinProperties Property
Specifies the skin properties that define the look and feel of the widget, when the widget is pressed or clicked.
Syntax
Type
JSON Object
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the pressedSkin property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the pressedStateSkinProperties property.
Form1.btn1.pressedStateSkinProperties = {
     background: {
    border: {
        borderWidth: 5
    fonts: {
        fontSize: '100',
    textShadow: {
        textShadowOffset: {
            x: 20,
            y: 4
  • Android
rawBytes Property
Specifies the rawbytes representing an Image (usually the image captured from the camera) that can be used as a background for the Camera. You cannot assign rawBytes directly to a button widget. The rawBytes has to be assigned to an Image widget or Button widget that has image skin.
Syntax
rawBytes
Type
JSObject
Read/Write
Read + Write
Remarks
Note: You can only retain the rawBytes obtained by using the Camera widget once in Android. If you need to reuse the rawBytes captured by the camera, you must assign the rawBytes to a variable in the JS code.
Example
//Sample code to set rawBytes property for a Camera widget
frmCamera.myCamera.rawBytes="1111";
//Sample code to read the rawBytes of a Camerawidget.
alert("Camera rawBytes::" + frmCamera.myCamera.rawBytes);
retainContentAlignment Property
This property is used to retain the content alignment property value, as it was defined.
Note: Locale-level configurations take priority when invalid values are given to this property, or if it is not defined.
The mirroring widget layout properties should be defined as follows.
function getIsFlexPositionalShouldMirror(widgetRetainFlexPositionPropertiesValue) {
    return (isI18nLayoutConfigEnabled &&
    localeLayoutConfig[defaultLocale]
    ["mirrorFlexPositionalProperties"] == true &&
    !widgetRetainFlexPositionPropertiesValue);
The following table illustrates how widgets consider Local flag and Widget flag values.
Properties Local Flag Value Widget Flag Value Action
Mirror/retain FlexPositionProperties true true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties true false Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties true not specified Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties false true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties false false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties false not specified Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties not specified false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified not specified Use the Design/Model-specific default layout.
Syntax
Type
Boolean
Read/Write
No (only during widget-construction time)
Example
//Here, we have shown how to use the retainContentAlignment property for Button widget.
retainContentAlignment property for other applicable widgets.*/
var btn = new voltmx.ui.Button({
    "focusSkin": "defBtnFocus",
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "skin": "defBtnNormal",
    "text": "text always from top left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_TOP_LEFT,
    "displayText": true,
    "padding": [0, 0, 0, 0],
    "paddingInPixel": false,
    "retainFlexPositionProperties": false,
    "retainContentAlignment": true
  • Available in IDE
  • iOS, Android, and SPA
retainFlexPositionProperties Property
This property is used to retain flex positional property values as they were defined. The flex positional properties are left, right, and padding.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlexPositionProperties property for Button widget.
retainFlexPositionProperties property for other applicable widgets.*/
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "text": "always left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_CENTER,
    "retainFlexPositionProperties": true,
    "retainContentAlignment": false
  • Available in IDE
retainFlowHorizontalAlignment Property
This property is used to convert Flow Horizontal Left to Flow Horizontal Right.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlowHorizontalAlignment property for Button widget.
retainFlowHorizontalAlignment property for other applicable widgets. */
 "height": "50dp",
 "id": "myButton",
 "isVisible": true,
 "left": "0dp",
 "top": "0dp",
 "width": "260dp",
 "zIndex": 1
 "retainContentAlignment": false,
 "retainFlowHorizontalAlignment ": false
  • Available in IDE
right Property
This property determines the lower right corner of the widget and is measured from the right bounds of the parent container.
The right property determines the position of the right edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the left edge of the parent container. In flow-vertical layout, value is ignored. In flow-horizontal layout, the value is ignored.
The right property is used only if the width property is not provided.
Syntax
right
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_HORIZONTAL, the right property is measured from left edge of the right sibling widget. The horizontal space between two widgets is measured from right of the left sibling widget and left of the right sibling widget.
Example
//Sample code to set the right property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.right = "50dp";
frmHome.widgetID.right = "10%";
frmHome.widgetID.right = "10px";
  • iOS, Android, SPA and Desktop Web
scaleFactor Property
Specifies the ratio by which the captured image is reduced. You can set the scale factor between 10 and 100. If you set the scale factor as 100, no reduction takes place, and the actual image is returned. If you set the value as 10, the image returned is reduced to 10 percent of the actual captured image.
Syntax
scaleFactor
Type
Number
Read/Write
Read + Write
Remarks
Note: In the Android platform, the scaleFactor property is respected only when the enableOverlay is set to true and the captureMode is set to camera. The scaleFactor property is not respected when the captureMode is set to video, even if the enableOverlay is set to true.
Note: This is a non-Constructor property. You cannot set this property through widget constructor. But you can read and write data to it.
Example
//Sample code to set scaleFactor property for a Camera widget
frmCamera.myCamera.scaleFactor=25;
  • Android
  • iOS
  • Desktop Web
shadowColor Property
Specifies the color for the shadow of the widget.
Syntax
shadowColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the shadow property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowColor property.
Form1.btn1.shadowColor = "ea5075";
  • iOS
shadowOffset Property
This property specifies the current coordinates of the shadow region in the widget.
Syntax
shadowOffset
Type
JSON Object
Read/Write
Read + Write
Remarks
  • The JSON Object contains the X-coordinate and Y-coordinates for the offset in the following format:
    {x: value in pixels, y: value in pixels}
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowOffset property.
Form1.btn1.shadowOffset= {
    "x": "3",
    "y": "27"
  • iOS
shadowRadius Property
Specifies the radius for the blur value of the shadow.
Syntax
shadowRadius
Type
Number
Read/Write
Read + Write
Remarks
  • The default value of the shadowRadius property for a Responsive Web app is 0.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the shadowRadius property.
 Form1.btn1.shadowRadius = 6;
  • iOS
skin Property
Specifies the look and feel of the camera when it is not in focus.
Syntax
skin
Type
String
Read/Write
Read + Write
Example
//Sample code to set skin property for a Camera widget
frmCamera.myCamera.skin="camSkin";
  • Android
  • iOS
  • Desktop Web
supportedVideoQualityLevels Property
The property returns an array of possible quality levels for the given device for the configured camera source. You can set one of the values from the returned array.
Syntax
Type
Array
Read/Write
Read only
Remarks
Below are the video resolutions possible for Android devices. When you query the video resolutions of your device, all the available resolutions are returned in an array.
Value Description
constants.CAMERA_VIDEO_QUALITY_HIGH Quality level corresponding to the highest available resolution.
constants.CAMERA_VIDEO_QUALITY_2160P Quality level corresponding to the 2160p (3840x2160) resolution.
constants.CAMERA_VIDEO_QUALITY_1080P Quality level corresponding to the 1080p (1920 x 1080) resolution.
constants.CAMERA_VIDEO_QUALITY_720P Quality level corresponding to the 720p (1280 x 720) resolution.
constants.CAMERA_VIDEO_QUALITY_480P Quality level corresponding to the 480p (720 x 480) resolution.
constants.CAMERA_VIDEO_QUALITY_CIF Quality level corresponding to the cif (352 x 288) resolution.
constants.CAMERA_VIDEO_QUALITY_QVGA Quality level corresponding to the QVGA (320x240) resolution.
constants.CAMERA_VIDEO_QUALITY_LOW Quality level corresponding to the lowest available resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_HIGH High speed ( >= 100fps) quality level corresponding to the highest available resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_2160P High speed ( >= 100fps) quality level corresponding to the 2160p (3840 x 2160) resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_1080P High speed ( >= 100fps) quality level corresponding to the 1080p (1920 x 1080 or 1920x1088) resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_720P High speed ( >= 100fps) quality level corresponding to the 720p (1280 x 720) resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_480P High speed ( >= 100fps) quality level corresponding to the 480p (720 x 480) resolution.
constants.CAMERA_VIDEO_QUALITY_HIGH_SPEED_LOW High speed ( >= 100fps) quality level corresponding to the lowest available resolution.
Note: When the enableOverlay property is set to false, only one option is supported that is constants.CAMERA_VIDEO_QUALITY_HIGH.
Example
var camBasic = {
    skin: "camSkin",
    text: "Camera",
    isVisible: true,
    onFailure: onFailureCalBck
var camLayout = {
    hExpand: true,
    vExpand: true
var camPSP = {};
//Using supportedVideoQualityLevels property for Camera
alert("Supported Video Quality Levels::" + camera1.supportedVideoQualityLevels);
  • Android
text Property
Specifies a general or descriptive text for the Camera Widget.
Syntax
text
Type
String
Read/Write
Read + Write
Example
//Sample code to set text property for a Camera widget
frmCamera.myCamera.text="Camera";
textShadowColor Property
Specifies the color for the text shadow of the widget.
Syntax
textShadowColor
Type
Read/Write
Read + Write
Remarks
  • This property has more priority than (and overrides) the textShadow property of the configured skin. Even if there is no skin configured for the widget, this property updates the skin.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowColor property.
Form1.btn1.textShadowColor = "ea5075";
  • Android
  • iOS
textShadowOffset Property
This property specifies the current coordinates of the text shadow region in the widget.
Syntax
textShadowOffset
Type
JSON Object
Read/Write
Read + Write
Remarks
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowOffset property.
Form1.btn1.textShadowOffset = {
    "x": "2",
    "y": "24"
  • Android
  • iOS
textShadowRadius Property
Specifies the radius for the blur value of the text shadow.
Syntax
textShadowRadius
Type
Number
Read/Write
Read + Write
Remarks
  • The default value of the textShadowRadius property for a Responsive Web app is 0.
Example
This example uses the button widget, but the principle remains the same for all widgets that have the textShadowRadius property.
 Form1.btn1.textShadowRadius = 6;
  • Android
  • iOS
toolTip Property
Specifies the information text that appears when the cursor hovers over a widget, without clicking it. The text entered in the toolTip property appears as a small box.
Syntax
toolTip
Type
String
Read/Write
Read + Write
Example
//Sample code to set toolTip property for a Camera widget
frmCamera.myCamera.toolTip="Click Here";
top Property
This property determines the top edge of the widget and measured from the top bounds of the parent container.
The top property determines the position of the top edge of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. In freeform layout, the distance is measured from the top edge of the parent container. In flow-vertical layout, the distance is measured from the bottom edge of the previous sibling widget in the hierarchy. In flow-horizontal layout, the distance is measured from the left edge of the parent container.
Syntax
top
Type
String
Read/Write
Read + Write
Remarks
If the layoutType is set as voltmx.flex.FLOW_VERTICAL, the top property is measured from the bottom edge of the top sibling widget. The vertical space between two widgets is measured from bottom of the top sibling widget and top of the bottom sibling widget.
Example
//Sample code to set the top property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.top = "50dp";
frmHome.widgetID.top = "10%";
frmHome.widgetID.top = "10px";
videoStabilization Property
The property enables you to reduce the shaking of the camera while shooting a video.
Syntax
videoStabilization
Type
Boolean
Read/Write
Read + Write
Remarks
The default value is false.
Note: In the Android platform, the videoStabilization property is respected only when the enableOverlay is set to true and the captureMode is set to video. The videoStabilization property is not respected when the captureMode is set to camera, even if the enableOverlay is set to true.
Example
//Sample code to enable videoStabilization property for a Camera widget
frmCamera.myCamera.videoStabilization=true;
Platform Availability
  • Available only in Android/Android Tablet
videoFormat Property
The property specifies the video format of the captured video.
Syntax
videoFormat
Type
Number
Read/Write
Read + Write
Remarks
The options are:
  • CAMERA_VIDEO_FORMAT_MP4 (Default)
  • CAMERA_VIDEO_FORMAT_MOV
Example
//Sample code to enable videoFormat property for a Camera widget
frmCamera.myCamera.videoFormat=constants.CAMERA_VIDEO_FORMAT_MOV;
  • iPhone
  • iPad
videoDuration Property
Use the property to specify the length of the captured video in seconds. Only positive numbers are accepted.
Syntax
videoDuration
Type
Number
Read/Write
Read + Write
Remarks
Note: The value is assumed as undefined if you set zero or any other invalid values.
Note: In the Android platform, the videoDuration property is respected only when the enableOverlay is set to true and the captureMode is set to video. The videoDuration property is not respected when the captureMode is set to camera, even if the enableOverlay is set to true.
Example
//Sample code to set videoDuration property for a Camera widget
frmCamera.myCamera.videoDuration=10;
  • iPhone
  • iPad
  • Android
  • Desktop Web
videoQualityLevel Property
Use the property to specify the quality of the video.
Syntax
videoQualityLevel
Type
Number
Read/Write
Read + Write
Remarks
Note: In the Android platform, the videoQualityLevel property is respected only when the enableOverlay is set to true and the captureMode is set to video. The videoQualityLevel property is not respected when the captureMode is set to camera, even if the enableOverlay is set to true.
The options for iOS platform are:
  • CAMERA_VIDEO_QUALITY_MEDIUM (Default)
  • CAMERA_VIDEO_QUALITY_HIGH
  • CAMERA_VIDEO_QUALITY_LOW
  • CAMERA_VIDEO_QUALITY_640x480
  • CAMERA_VIDEO_QUALITY_1280x720
  • CAMERA_VIDEO_QUALITY_960x540
The options for Android platform are:
Value Description
Example
//Sample code to set videoQualityLevel property for a Camera widget
frmCamera.myCamera.videoQualityLevel=constants.CAMERA_VIDEO_QUALITY_HIGH;
  • iPhone
  • iPad
  • Android
width Property
This property determines the width of the widget and is measured along the x-axis.
The width property determines the width of the widget’s bounding box. The value may be set using DP (Device Independent Pixels), Percentage, or Pixels. For supported widgets, the width may be derived from either the widget or container’s contents by setting the width to “preferred”.
Syntax
width
Type
Read/Write
Read + Write
Remarks
Following are the options that can be used as units of width:
  • voltmx.flex.USE_PREFERED_SIZE: When this option is specified, the layout uses preferred width of the widget as width and preferred size of the widget is determined by the widget and may varies between platforms.
Example
//Sample code to set the width property for widgets by using DP, Percentage and Pixels.
frmHome.widgetID.width = "50dp";
frmHome.widgetID.width = "10%";
frmHome.widgetID.width = "10px";
  • iOS, Android,SPA, and Desktop Web
zIndex Property
This property specifies the stack order of a widget. A widget with a higher zIndex is always in front of a widget with a lower zIndex.
The zIndex property is used to set the stack, or layer order of a widget. Widgets with higher values will appear “over”, or “on top of” widgets with lower values. Widgets layered over other widgets will override any interaction events tied to widgets beneath. Modifying the zIndex does not modify the order of the widgets in the VoltMX Iris hierarchy, inside of a flexContainer or form. The zIndex property accepts only positive values.
Syntax
zIndex
Type
Number
Read/Write
Read + Write
Remarks
The default value for this property is 1.
Note: Modifying the zIndex does not modify the order of the widgets inside the FlexContainer. If zIndex is same for group of overlapping widgets then widget order decides the order of overlapping. The last added widget is displayed on top.
From VoltMX Iris V9 SP2 FP7, developers can configure the Z Index value for a Responsive Web app as Auto or Custom. When the selected Z Index value is Auto, the default Z Index value of 1 is applied. When the selected Z Index value is Custom, developers can specify a desired numeric value.
Prior to the V9 SP2 FP7 release, the default value for the Z Index was 1. When developers imported any third-party libraries with the Z index set as Auto, content overflow was disabled as the value of Auto is less than 1.
Note: The Z Index value Auto is supported only when the Enable JS Library mode is configured as unchecked.
For existing components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Custom with 1 as the value.
For new components, the value of the Z Index is configured as 1 for the Native channel. For the Responsive Web channel, the Z Index will be set as Auto or 1 based on the project level settings.
Note: If ModalContainer property is set to true in any of the FlexContainer widget, the Z Index value of that container and all of its parent containers should be set to Custom.
voltmx.flex.ZINDEX_AUTO : Constant to configure the Z Index value as auto programmatically.
//Sample code to set the ZIndex value to Auto
 var flx = new voltmx.ui.FlexContainer({
  "id": "flx"
  "zIndex": voltmx.flex.ZINDEX_AUTO
flx.zIndex = voltmx.flex.ZINDEX\_AUTO;
Example
//Sample code to set the zIndex property for widgets.
frmHome.widgetID.zIndex = 300;
  • iOS, Android, SPA, and Desktop Web
