Skip to content
Alert Properties
The properties of the Alert widget are:
accessibilityConfig Property
Enables you to control accessibility behavior and alternative text for the widget.
For more information on using accessibility features in your app, see the Accessibility appendix in the VoltMX IrisUser Guide.
Syntax
accessibilityConfig
Type
Object
Read/Write
Read + Write
Remarks
  • The accessibilityConfig property is enabled for all the widgets which are supported under the Flex Layout.
Note: From VoltMX Iris V9 SP2 GA version, you can provide i18n keys as values to all the attributes used inside the accessibilityConfig property. Values provided in the i18n keys take precedence over values provided in a11yLabel, a11yValue, and a11yHint fields.
The accessibilityConfig property is a JavaScript object which can contain the following key-value pairs.
Key Type Description ARIA Equivalent
a11yIndex Integer with no floating or decimal number. This is an optional parameter. Specifies the order in which the widgets are focused on a screen. For all widgets, this parameter maps to the aria-index, index, or taborder properties.
a11yLabel String This is an optional parameter. Specifies alternate text to identify the widget. Generally the label should be the text that is displayed on the screen. For all widgets, this parameter maps to the aria-labelledby property of ARIA in HTML. > Note: For the Image widget, this parameter maps to the alt attribute of ARIA in HTML.
a11yValue String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. This parameter is similar to the a11yLabel parameter. If the a11yValue is defined, the value of a11yValue is appended to the value of a11yLabel. These values are separated by a space.
a11yHint String This is an optional parameter. Specifies the descriptive text that explains the action associated with the widget. On the Android platform, the text specified for a11yValue is prefixed to the a11yHint. For all widgets, this parameter maps to the aria-describedby property of ARIA in HTML.
a11yHidden Boolean This is an optional parameter. Specifies if the widget should be ignored by assistive technology. The default option is set to false. This option is supported on iOS 5.0 and above, Android 4.1 and above, and SPA For all widgets, this parameter maps to the aria-hidden property of ARIA in HTML.
a11yARIA Object This is an optional parameter. For each widget, the key and value provided in this object are added as the attribute and value of the HTML tags respectively. Any values provided for attributes such as aria-labelledby and aria-describedby using this attribute, takes precedence over values given in a11yLabel and a11yHint fields. When a widget is provided with the following key value pair or attribute using the a11yARIA object, the tabIndex of the widget is automatically appended as zero.{"role": "main"}``aria-label This parameter is only available on the Desktop Web platform.
Android limitations
  • If the results of the concatenation of a11y fields result in an empty string, then accessibilityConfig is ignored and the text that is on widget is read out.
  • The soft keypad does not gain accessibility focus during the right/left swipe gesture when the keypad appears.
SPA/Desktop Web limitations
  • When accessibilityConfig property is configured for any widget, the tabIndex attribute is added automatically to the accessibilityConfig property.
  • The behavior of accessibility depends on the Web browser, Web browser version, Voice Over Assistant, and Voice Over Assistant version.
  • Currently SPA/Desktop web applications support only a few ARIA tags. To achieve more accessibility features, use the attribute a11yARIA. The corresponding tags will be added to the DOM as per these configurations.
Example 1
This example uses the button widget, but the principle remains the same for all widgets that have an accessibilityConfig property.
//This is a generic property that is applicable for various widgets.
//Here, we have shown how to use the accessibilityConfig Property for button widget.
/*You need to make a corresponding use of the accessibilityConfig property for other applicable widgets.*/
Form1.myButton.accessibilityConfig = {
    "a11yLabel": "Label",
    "a11yValue": "Value",
    "a11yHint": "Hint"
Example 2
This example uses the button widget to implement internationalization in accessibilityConfig property, but the principle remains the same for all widgets.
/*Sample code to implement internationalization in accessibilityConfig property in Native platform.*/
    "a11yLabel": voltmx.i18n.getLocalizedString("key1")
/*Sample code to implement internationalization in accessibilityConfig property in Desktop Web platform.*/
    "a11yLabel": "voltmx.i18n.getLocalizedString(\"key3\")"
Platform Availability
  • Available in the IDE
  • iOS, Android, SPA, Desktop Web and Desktop Native.
alertIcon Property
Specifies the Icon to be displayed to visually indicate the type of alert.
Syntax
alertIcon
Type
String
Read/Write
No
Remarks
In Android platform, the alert icon can be either a string specifying a local resource, or an image object created using the API: voltmx.image.
In iOS platform, you can provide the alert icon only as a string. iOS platform does not support the use of the image object.
Examples
Using a local resource for the alert icon:
//Creating the alert with the alertIcon:"icon.png"
var alertBasic = {
    message: "Sample Alert",
    alertIcon: "icon.png"
//The icon.png should be available in resources folder.
var alertPSP = {};
var alert = voltmx.ui.Alert(alertBasic, alertPSP);
Using an image object:
//Creating the alert with an image object
imgObjRef = voltmx.image.createImage("local.png");
pspConfig = {};
var alert = voltmx.ui.Alert({
    "message": "Alert text",
    "alertType": constants.ALERT_TYPE_INFO,
    "alertTitle": "Alert Title",
    "yesLabel": "Yes",
    "noLabel": "",
    "alertIcon": imgObjRef,
    "alertHandler": null
}, pspConfig);
  • iOS (does not support the image object)
  • Android
alertTitle Property
Specifies the Title of the alert.
Syntax
alertTitle
Type
String
Accessible from Code
No
Example
//Creating the alert with the alertTitle:"Confirmation"
var alertBasic = {
    alertTitle: "Confirmation"
var alertPSP = {};
Accessible from IDE
Yes
Available on all platforms
alertType Property
Specifies the Type of the alert window to be displayed. You can select one of the following:
  • Confirmation - This type is used when you want the user to verify or accept something. For example, In this type, the user has to click either "OK" or "Cancel" buttons to proceed or exit.
  • error - This type is used to display when user enters incorrect value. For example, username or password in a login screen.
  • info (Default)- This type is used to display some information to the user.
Use the below constants to display alert type using constructor:
  • ALERT_TYPE_CONFIRMATION
  • ALERT_TYPE_ERROR
  • ALERT_TYPE_INFO (Default)
Syntax
alertType
Type
Number
No
Example
//Creating the alert with the alertType:constants.ALERT_TYPE_CONFIRMATION
var alertBasic = {
    alertType: constants.ALERT_TYPE_CONFIRMATION
var alertPSP = {};
Accessible from IDE
Yes
cursorType Property
In Desktop Web applications, when you hover the mouse over any widget, a mouse pointer appears. Using the cursorType property in Iris, you can specify the type of the mouse pointer.
Syntax
cursorType
Type
String.
You must provide valid CSS cursor value such as wait, grab, help, etc. to the cursorType property.
Read/Write
Read + Write
Remarks
To add the cursorType property using VoltMX Iris in a Desktop Web application, follow these steps.
  1. In VoltMX Iris, open the Desktop Web application. From the Project explorer, expand Responsive Web/ Desktop> Forms and select the form to which you need to make the changes.
  2. On the canvas, select the widget for which you want to specify the cursor type. For example, button.
  3. From the Properties panel, navigate to the Skin tab > Hover Skin tab.
    You will find that the details of the hover skin is not enabled here.
  4. Check the Enable option to add a hover skin to your widget.
    The details and configurations of the hover skin is enabled.
  5. Under the General section, for the Platform option, click the ellipsis icon.
    The Fork Skin window appears.
  6. In the Fork Skin window, for Desktop, check under HTML5 SPA.
  7. Click Ok. You have successfully forked your hover skin for Desktop Web application.
    You can see that the Cursor Type property has been added under the General section.
  8. Select a value from the drop-down list to set the Cursor Type for the widget.
Example
//This is a generic property and is applicable for many widgets.
/*The example provided is for the Button widget. Make the required changes in the example while using other widgets.*/
frmButton.myButton.cursorType = "wait";
  • Available in IDE
  • Desktop Web
  • Desktop Native
message Property
Specifies the message description of the alert to be displayed.
Syntax
message
Type
String
No
Example
//Creating the alert with the message:"Sample Alert"
var alertBasic = {
var alertPSP = {};
Accessible from IDE
Yes
noLabel Property
Specifies the descriptive Text for the "No" label.
Syntax
noLabel
Type
String
No
Example
//Creating the alert with the noLabel:"No"
var alertBasic = {
    alertType: constants.ALERT_TYPE_CONFIRMATION,
    noLabel: "No"
var alertPSP = {};
Accessible from IDE
Yes
retainContentAlignment Property
This property is used to retain the content alignment property value, as it was defined.
Note: Locale-level configurations take priority when invalid values are given to this property, or if it is not defined.
The mirroring widget layout properties should be defined as follows.
function getIsFlexPositionalShouldMirror(widgetRetainFlexPositionPropertiesValue) {
    return (isI18nLayoutConfigEnabled &&
    localeLayoutConfig[defaultLocale]
    ["mirrorFlexPositionalProperties"] == true &&
    !widgetRetainFlexPositionPropertiesValue);
The following table illustrates how widgets consider Local flag and Widget flag values.
Properties Local Flag Value Widget Flag Value Action
Mirror/retain FlexPositionProperties true true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties true false Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties true not specified Use Mirror FlexPositionProperties since locale-level Mirror is true.
Mirror/retain FlexPositionProperties false true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties false false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties false not specified Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified true Use the designed layout from widget for all locales. Widget layout overrides everything else.
Mirror/retain FlexPositionProperties not specified false Use the Design/Model-specific default layout.
Mirror/retain FlexPositionProperties not specified not specified Use the Design/Model-specific default layout.
Syntax
Type
Boolean
Read/Write
No (only during widget-construction time)
Example
//Here, we have shown how to use the retainContentAlignment property for Button widget.
retainContentAlignment property for other applicable widgets.*/
var btn = new voltmx.ui.Button({
    "focusSkin": "defBtnFocus",
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "skin": "defBtnNormal",
    "text": "text always from top left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_TOP_LEFT,
    "displayText": true,
    "padding": [0, 0, 0, 0],
    "paddingInPixel": false,
    "retainFlexPositionProperties": false,
    "retainContentAlignment": true
  • Available in IDE
  • iOS, Android, and SPA
retainFlexPositionProperties Property
This property is used to retain flex positional property values as they were defined. The flex positional properties are left, right, and padding.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlexPositionProperties property for Button widget.
retainFlexPositionProperties property for other applicable widgets.*/
    "height": "50dp",
    "id": "myButton",
    "isVisible": true,
    "left": "0dp",
    "text": "always left",
    "top": "0dp",
    "width": "260dp",
    "zIndex": 1
    "contentAlignment": constants.CONTENT_ALIGN_CENTER,
    "retainFlexPositionProperties": true,
    "retainContentAlignment": false
  • Available in IDE
retainFlowHorizontalAlignment Property
This property is used to convert Flow Horizontal Left to Flow Horizontal Right.
Syntax
Type
Boolean
Read/Write
Example
//Here, we have shown how to use the retainFlowHorizontalAlignment property for Button widget.
retainFlowHorizontalAlignment property for other applicable widgets. */
 "height": "50dp",
 "id": "myButton",
 "isVisible": true,
 "left": "0dp",
 "top": "0dp",
 "width": "260dp",
 "zIndex": 1
 "retainContentAlignment": false,
 "retainFlowHorizontalAlignment ": false
  • Available in IDE
yesLabel Property
Specifies the descriptive Text for the "Yes" label.
Syntax
yesLabel
Type
String
No
Example
//Creating the alert with the yesLabel:"Yes"
var alertBasic = {
    yesLabel: "Yes"
var alertPSP = {};
Accessible from IDE
Yes
