Skip to content
You are here: Installation > Salient Features
Overview
The Volt Foundry Container Cluster Solution provides a flexible and scalable solution for deploying Volt Foundry on your on-premises setup, including scaling the installation to multi-node systems and robust logging capabilities.
Volt Foundry Container Cluster Solution On-Premises setup occurs with minimal manual intervention and leverages the following technologies:
  • Docker - To package different components as portable container images (with all the required binaries and libs).
  • Kubernetes - To orchestrate and maintain all the running containers. It will also have features like auto-scaling, secrets, deployment upgrades, and rollbacks.
You should use this installation if you plan to use docker to setup your on-premise production grade installation of Volt Foundry. If you want to setup a developer instance, please refer to the install instructions at Single container setup (On-Prem).
Salient Features
The Volt Foundry Container Cluster Solution provides developers with tools to build applications. The Volt Foundry Container Cluster Solution has the following features:
  1. Deploys Volt Foundry on Kubernetes environment.
  2. Supports deployment in Linux (RHEL 9).
Prerequisites
Software Requirements
  • Install OpenJDK 11.
  • Install Zip and Dig.
Supported OS Platform
Foundry Kubernetes cluster is supported on RHEL 9.
Supported Application Servers
Volt Foundry Container Cluster Solution supports only the Tomcat Application server. The Tomcat server comes bundled along with the installer.
All the Docker images built for Volt Foundry are built using the Tomcat version 9.0.123-jdk11 as the base image.
Supported Databases
Volt Foundry Container Cluster Solution supports the following database servers:
Database Type Version Supported
MySQL 8.4
Microsoft SQL Server 2019
MySQL Database HA ( active/passive ) Cluster 8.0
Oracle 19c
Note: You must have an existing external Database. The Database does not come bundled with the Installer.
Supported Kubernetes Version
Volt Foundry Container Cluster Solution supports the following Kubernetes package versions:
Docker 28.0.4
kubectl 1.32.3
kubelet 1.32.3
kubeadm 1.32.3
Date and Time
The date and time should be synchronized across all the nodes in a cluster.
Hardware Requirements
This setup requires a minimum of three machines (1 master node, 1 worker node, and 1 load balancer node) for a development environment and five machines (3 masters, 2 worker nodes, and 1 load balancer node) for a production grade environment.
Following is the hardware requirement for a development environment setup.
Component Requirement
RAM 4 GB for master node, 8 GB for worker node
Internal Storage 100 GB
CPU Cores Dual or above.
Following is the hardware requirement for a production grade cluster.
RAM 20 GB
Firewall Settings
You must ensure that the following ports are used to expose the required services when a Firewall is enabled on your system.
Required Open Ports
The following port ranges must be opened before installing Foundry on all nodes in a cluster.
  • 30000-32767/tcp
  • 6443-10252/tcp
  • 2379-2380/tcp
Run the following commands to open the ports:
sudo firewall-cmd --permanent --add-port=30000-32767/tcp --zone=public
sudo firewall-cmd --permanent --add-port=6443-10252/tcp --zone=public
sudo firewall-cmd --permanent --add-port=2379-2380/tcp --zone=public
The following ports must be opened explicitly when a firewall is enabled on all nodes. These are required by Weave CNI to avoid hostname issues.
  • 6783/udp, 6783/tcp
  • 6784/udp, 6784/tcp
sudo firewall-cmd --permanent --add-port=6783/udp --zone=public
sudo firewall-cmd --permanent --add-port=6783/tcp --zone=public
sudo firewall-cmd --permanent --add-port=6784/udp --zone=public
sudo firewall-cmd --permanent --add-port=6784/tcp --zone=public
The following ports should be opened on the load-balancer node.
  • 443/tcp
  • 80/tcp
sudo firewall-cmd --permanent --add-port=443/tcp --zone=public
sudo firewall-cmd --permanent --add-port=80/tcp --zone=public
At the end run the following command to load the new firewall settings.
sudo firewall-cmd --reload
Some of the app services in Foundry cluster use specific node ports to expose the services. Therefore, the ports mentioned below must be free on all nodes before installing the Foundry Kubernetes cluster.
Ports Services using the Port
30000 Prometheus
31000 Kubernetes Dashboard. (The default port value can be changed by changing value of KUBERNETES_DASHBOARD_PORT in the config.properties file)
30200 Internal nginx load balancer
30300 Kibana logging tool
30400 Grafana monitoring tool
Preinstallation Tasks
Following are the preinstallation tasks to be performed on all nodes before starting installation.
  1. All Kubernetes masters and nodes must have the swap disabled. This is the recommended deployment as per the Kubernetes community.
    a. Run the following command to disable swap. sudo swapoff -a
    b. Run the following command to update fstab so that the swap remains disabled even after a reboot. sudo sed -i '/ swap / s/^\(.\*\)$/#\1/g' /etc/fstab
    c. Restart the node after the swap is disabled.
  2. Download Foundry container artifacts from VoltMX Downloads.
  3. If the Foundry cluster is being reinstalled, you must execute the following command on all nodes and delete the .kube folder present in the root directory from all the master nodes. sudo kubeadm reset
Architecture
Following is the architecture diagram of the Volt Foundry Container Cluster Solution.
The complete Volt Foundry Container Cluster Solution will have a total of six pods.
Following is the list of pods present in the VoltMX Foundry Container Cluster Solution:
  • Console
  • API Developer Portal
  • Identity
  • Integration
  • Engagement
  • Database (exits on completion of the Database scripts execution)
The following is the list of Docker images used for the pods in the VoltMX Foundry Container Cluster Solution:
  • Foundry Console (Contains mfconsole.war,   workspace.war,  and  accounts.war)
  • API Developer Portal (Contains apiportal.war)
  • Identity (Contains authService.war)
  • Integration (Contains admin.war, services.war,  middleware.war, and apps.war)
  • Engagement (Contains vpns.war)
  • Database (Contains Database migration scripts)
The docker images will be pulled when you execute the installation scripts in the "HCL Volt Foundry Container Installer" found on MHS portal : https://my.hcl-software.com/downloads/voltmx/foundrycurrent
Volt Foundry Container Cluster Solution downloadable bundle contains the following directories and files:
  • install-foundry.sh - Installation script
  • install-actions.sh - Installation actions script which is internally used by install-foundry.sh.
  • templates - Directory containing the config template files
  • add-ons directory- Directory containing additional deployments and configurations for the Kubernetes cluster.
  • config.properties - Properties file to pass the inputs to install-foundry.sh instead of giving inputs in shell prompts.
  • lib - Folder containing the foundry-utils.jar file.
  • resources - Folder containing a few resources required for the Kubernetes CNI.
  • setup-loadbalancer.sh - Needs to be executed on a different machine to support the load balancer.
Installation Types
Inputs for installation can be gathered through two modes. Any of the following modes can be chosen for installation.
  • Command Line - Volt Foundry Container Cluster Solution can be installed using the bundled install shell script, which will prompt the user for required values.
    The syntax for installing through the Command Line:
    sudo ./install-foundry.sh
  • Silent Installation - The installation script also supports silent installation if the config.properties file is passed as an argument (for example, /path/install-foundry.sh config.properties). Using this, you can have additional ability to pass custom Tomcat JAVA_OPTS, Heap memory settings, and time-zone settings as well.
    The syntax for installing using the config.properties:
    sudo ./install-foundry.sh config.properties
Configuration
The following parameters are to be provided by the user during Installation:
  1. INSTALL_ENV_NAME - The install environment name can be anything in lowercase (String). The possible values are: dev, qa, prod, or eastusprod.
    Note: The Install Environment Name must not contain numbers.
    • IMAGE_REGISTRY_USERNAME: - This is the email ID you use to log in.
    • IMAGE_REGISTRY_PASSWORD: - This is the CLI secret found under your User Profile in HCL Harbor.
  2. Install Components: The following properties must be set to either Y (yes) or N (no). If ALL_COMPONENTS_ENABLED is set to Y, the rest of the inputs can be left empty. If ALL_COMPONENTS_ENABLED is set to N then at least one of the following input properties must be set to Y.
    • ALL_COMPONENTS_ENABLED
    • INTEGRATION_ENABLED
    • IDENTITY_ENABLED
    • MESSAGING_ENABLED
    • CONSOLE_ENABLED
    • APIPORTAL_ENABLED
  3. Application Server Details
    • SERVER_DOMAIN_NAME: The Domain Name for Volt Foundry. This value should be the hostname of the LoadBalancer. For example: abc.companyname (DNS name).
    Note: Domain name cannot be an IP address or 'localhost'.
    • COM_PROTOCOL: The communication protocol for Volt Foundry. This value can be either http or https.
    • HTTPS_CERT_FILE: The path to the existing certificate and key files. This value can be empty if the communication protocol is HTTP. The path should point to a valid pem file.
    • HTTPS_KEY_FILE: The path to the existing certificate and key files. This value can be empty if the communication protocol is HTTP. The path should point to a valid pem file.
  4. Database Details:
    • DB_TYPE - This is the Database type you want to use for hosting Volt Foundry. The possible values are:
    • For MySQL DB server: mysql
    • For Azure MSSQL or SQL Server: sqlserver
    • For Oracle DB server: oracle
    • DB_HOST - This is the Database Server hostname used to connect to the Database Server.
    Note: If the Database Hostname is an IP address, it should be a static IP address.
    • DB_PORT– This is the Port Number used to connect to the Database Server. This can be empty for cloud manage service.
    • DB_USER - This is the Database Username used to connect to the Database Server.
    • DB_PASS - This is the Database Password used to connect to the Database Server.
    • DB_PREFIX – This is the Database server prefix for Volt Foundry Schemas/Databases.
    • DB_SUFFIX – This is the Database server suffix for Volt Foundry Schemas/Databases.
    • Database Prefix and Suffix are optional inputs.
    • In case of upgrade, ensure that the values of the Database Prefix and Suffix that you provide are the same as you had provided during the initial installation.
    • If DB_TYPE is set as oracle, the following String values need to be provided:
    • DB_DATA_TS: Database Data tablespace name.
    • DB_INDEX_TS: Database Index tablespace name.
    • DB_LOB_TS: Database LOB tablespace name.
    • DB_SERVICE: Database service name.
    • USE_EXISTING_DB: If you want to use an existing databases from a previous Volt Foundry instance set this variable to Y. If not the set the USE_EXISTING_DB variable to N.
    You must provide the location of the previously installed artifacts (the location should contain upgrade.properties file).
    For example: PREVIOUS_INSTALL_LOCATION = /C/voltmx-foundry-containers-onprem/kubernetes.
  5. VoltMX Foundry Account Registration Details: The following properties are required for owner registration. It is not required for an upgrade. If OWNER_REGISTRATION_REQUIRED is set to Y (yes), then you must provide all the following inputs:
    • OWNER_REGISTRATION_REQUIRED - Y/N.
    • OWNER_USER_ID – E-mail ID used for Volt Foundry Registration.
    • OWNER_PASSWORD – Password used for Volt Foundry Registration.
    • OWNER_FIRST_NAME – First Name used for Volt Foundry Registration.
    • OWNER_LAST_NAME – Last Name used for Volt Foundry Registration.
    • OWNER_ENV_NAME – Environment name to which the generated applications should be published.
  6. TIME_ZONE - The Time Zone of the Database used for Volt Foundry installation. The Time Zone variable must be set to maintain consistency between the Application server and the Database server. For determining what value to set for the time zone you can refer to List of tz database time zones on Wikipedia.
    Note: The Time Zone is an optional value. If you do not provide any Time Zone, it is set to Etc/UTC.
  7. Readiness and Liveness Probes Details: Following variables are set with default values in seconds. You can modify them in the config.properties file.
    • IDENTITY_READINESS_INIT_DELAY: The readiness probe initial delay for Identity, in seconds. The default value is 180.
    • IDENTITY_LIVENESS_INIT_DELAY: The liveness probe initial delay for Identity, in seconds. The default value is 300.
    • CONSOLE_READINESS_INIT_DELAY: The readiness probe initial delay for Console, in seconds. The default value is 300.
    • CONSOLE_LIVENESS_INIT_DELAY: Liveness probe initial delay for Console, in seconds. The default value is 600.
    • INTEGRATION_READINESS_INIT_DELAY: The readiness probe initial delay for Integration, in seconds. The default value is 300.
    • INTEGRATION_LIVENESS_INIT_DELAY: Liveness probe initial delay for Integration, in seconds. The default value is 600.
    • ENGAGEMENT_READINESS_INIT_DELAY: The readiness probe initial delay for Engagement, in seconds. The default value is 180.
    • ENGAGEMENT_LIVENESS_INIT_DELAY: The liveness probe initial delay for Engagement, in seconds. The default value is 300.
  8. Minimum and Maximum RAM percentage Details: The following variables are set with default String values. You can modify them in the config.properties file.
    • CONSOLE_MIN_RAM_PERCENTAGE: Minimum RAM percentage for Console. The default value is "50".
    • CONSOLE_MAX_RAM_PERCENTAGE: Maximum RAM percentage for Console. The default value is "80".
    • ENGAGEMENT_MIN_RAM_PERCENTAGE: Minimum RAM percentage for Engagement. The default value is "50".
    • ENGAGEMENT_MAX_RAM_PERCENTAGE: Maximum RAM percentage for Engagement. The default value is "80".
    • IDENTITY_MIN_RAM_PERCENTAGE: Minimum RAM percentage for Identity. The default value is "50".
    • IDENTITY_MAX_RAM_PERCENTAGE: Maximum RAM percentage for Identity. The default value is "80".
    • INTEGRATION_MIN_RAM_PERCENTAGE: Minimum RAM percentage for Integration. The default value is "50".
    • INTEGRATION_MAX_RAM_PERCENTAGE: Maximum RAM percentage for Integration. The default value is "80".
    • APIPORTAL_MIN_RAM_PERCENTAGE: Minimum RAM percentage for API Portal. The default value is "50".
    • APIPORTAL_MAX_RAM_PERCENTAGE: Maximum RAM percentage for API Portal. The default value is "80".
  9. Container resource limits for memory and CPU: The following variables are set with default String values. You can modify them in the config.properties file.
    • IDENTITY_RESOURCE_MEMORY_LIMIT: The resource memory limit for Identity. The default value is "1.2G".
    • IDENTITY_RESOURCE_REQUESTS_MEMORY: The resource memory requests for Identity. The default value is "1G".
    • IDENTITY_RESOURCE_REQUESTS_CPU: The resource CPU requests for Identity. The default value is "200m".
    • CONSOLE_RESOURCE_MEMORY_LIMIT: The resource memory limit for Console. The default value is "2.2G".
    • CONSOLE_RESOURCE_REQUESTS_MEMORY: The resource memory requests for Console. The default value is "2G".
    • CONSOLE_RESOURCE_REQUESTS_CPU: The resource CPU requests for Console. The default value is "300m".
    • APIPORTAL_RESOURCE_MEMORY_LIMIT: The resource memory limit for API Portal. The default value is "1.2G",
    • APIPORTAL_RESOURCE_REQUESTS_MEMORY: The resource memory requests for API Portal. The default value is "1G".
    • APIPORTAL_RESOURCE_REQUESTS_CPU: The resource CPU requests for API Portal. The default value is "200m",
    • INTEGRATION_RESOURCE_MEMORY_LIMIT: The resource memory limit for Integration. The default value is "2.2G".
    • INTEGRATION_RESOURCE_REQUESTS_MEMORY: The resource memory requests for Integration. The default value is "2G".
    • INTEGRATION_RESOURCE_REQUESTS_CPU: The resource CPU requests for Integration. The default value is "300m".
    • ENGAGEMENT_RESOURCE_MEMORY_LIMIT: The resource memory limit for Engagement. The default value is "1.2G".
    • ENGAGEMENT_RESOURCE_REQUESTS_MEMORY: The resource memory requests for Engagement. The default value is "1G".
    • ENGAGEMENT_RESOURCE_REQUESTS_CPU: The resource CPU requests for Engagement. The default value is "200m".
  10. Custom JAVA_OPTS Details: The following variables can be set with default String values. You can modify them in the config.properties file.
    • CONSOLE_CUSTOM_JAVA_OPTS: The custom JAVA_OPTS for Console.
    • ENGAGEMENT_CUSTOM_JAVA_OPTS: The custom JAVA_OPTS for Engagement
    • IDENTITY_CUSTOM_JAVA_OPTS: The custom JAVA_OPTS for Identity.
    • INTEGRATION_CUSTOM_JAVA_OPTS: The custom JAVA_OPTS for Integration.
    • APIPORTAL_CUSTOM_JAVA_OPTS: The custom JAVA_OPTS for API Portal.
  11. Number of instances to be deployed for each component: The following variables can be set with default integer values. You can modify them in the config.properties file.
    • IDENTITY_REPLICAS: The number of instances of Identity. The default value is 1.
    • CONSOLE_REPLICAS: The number of instances of Console. The default value is 1.
    • APIPORTAL_REPLICAS: The number of instances of API Portal. The default value is 1.
    • INTEGRATION_REPLICAS: The number of instances of Integration. The default value is 1.
    • ENGAGEMENT_REPLICAS: The number of instances of Engagement. The default value is 1.
  12. The port on which the Kubernetes Dashboard can be accessed:
    • KUBERNETES_DASHBOARD_PORT: The default value is 31000.
Installation
Run the Volt Foundry Container Cluster install script to generate and deploy Volt Foundry containers.
Steps to Install Volt Foundry Container Cluster Solution on an On-Premises setup:
  1. Setting up HAProxy LoadBalancer
    Note: This step is optional if you have your own load balancer setup. You must provide the pre-configured load balancer hostname as the SERVER_DOMAIN_NAME input in the installation process instead of performing the following instructions.
  2. Setting up Cluster
  3. Resuming installation in Master Node
Before starting the cluster installation, a loadbalancer must be set up. Without the loadbalancer the cluster setup cannot be started. The HAProxy is a certified external loadbalancer for the Foundry container cluster setup. Installation and configuration of HAProxy is taken care of by the script. Initially, the installation script configures the loadbalancer with one master. Going forward you can edit the haproxy.cfg file to add other masters to the loadbalancer.
Perform the following steps to setup the HAProxy loadbalancer through a script file.
  1. Download the VoltMXFoundryContainersOnPrem-9.0.0.0_GA.zip from the Download Link and extract it. sudo unzip VoltMXFoundryContainersOnPrem-9.0.0.0_GA.zip -d VoltMXFoundryContainerOnPrem-9.0.0.0_GA
  2. Navigate to foundry container artifact folder. cd VoltMXFoundryContainerOnPrem-9.0.0.0_GA
  3. Run setup-loadbalancer.sh. It prompts for master node hostname and communication protocol. The loadbalancer is then installed and configured. sudo ./setup-loadbalancer.sh
  4. Check if haproxy gets successfully started by executing the systemctl status haproxy command. If it throws the "cannot bind socket [0.0.0.0:xxxx|https://stackoverflow.com/questions/34793885/haproxy-cannot-bind-socket-0-0-0-08888]" error. Run the following command and restart haproxy. setsebool -P haproxy_connect_any=1
Before setting up master nodes, all the IPs of master nodes should be configured in HAProxy loadbalancer. If any master node IP is not listed and you try to set the master node, that node will not be added to cluster. To add master node IPs, edit the file /etc/haproxy/haproxy.cfg and make the following two changes for each master node IP to be added.
  1. In the Configure HAProxy SecureBackend section, add the following line at the end. List all the other master node IPs in the same way. server k8s-api-2 <IP-ADDRESS>:6443 check
  2. In the Configure HAProxy Foundry Backend section, add the following line at the end. List all the other master node IPs in the same way. server foundry-1 <IP-ADDRESS>:30200 check
Setting up Cluster
In setting up a cluster a minimum of one master can be configured. To improve failure tolerance and ensure cluster availability it is recommended to have an odd number (minimum three) of master nodes. To start cluster setup choose one node as starting point of installation which should be the master node.
  1. Download the voltmx-foundry-containers-onprem_9.0.0.0_GA.zip from the Download Link and extract it. sudo unzip VoltMXFoundryContainersOnPrem-9.0.0.0_GA.zip -d VoltMXFoundryContainerOnPrem-9.0.0.0_GA
  3. Run the following command to setup the master. It downloads and installs cluster packages, initializes kubeadm, sets up Weave CNI, generates token and waits for the worker node to join the master to proceed further. sudo ./install-foundry.sh config.properties
    Note: You must provide execute permissions to run the install-foundry.sh file on Linux.
  4. To join other nodes as master/worker, copy the setup-node.zip file which is available in the Foundry Container artifact folder(VoltMXFoundryContainerOnPrem-9.0.0.0_GA) into the node to join as the master/worker and then perform the following steps.
    1. Extract the setup-nodes.zip file.
      sudo unzip setup-node.zip -d setup-node
    2. Navigate to the setup-nodes folder.
      cd setup-node
    3. Execute the following command.
      For Master:
      sudo ./setup-node.sh control-plane
      For Worker:
  5. After the cluster setup is done to get the list of nodes in cluster, use below command.
    kubectl get nodes
Resuming Installation In Master Node
After joining masters and worker nodes, you must press enter in the master node terminal to resume the installation.
  1. Kubernetes Dashboard and DB Migrations
  2. Foundry and Ingress configuration
  3. EFK , Prometheus, and Grafana Monitoring tool configuration.
  4. Foundry healthcheck
  5. Run the following command to check status of pods.
    sudo kubectl get pods
Known Issues and Limitations
Volt Foundry Container Cluster Solution has the following known issues and limitations:
  • Support for SPA / Desktop Web is only available for zipped SPA apps, not for WARs.
