Project management
You can create a project to manage the data design environment that is used to generate the test data. If the data design environment that you created is no longer required, then you can archive or delete the project. If you do want to use an archived project, you can unarchive it.
While you manage your project, the following components of HCL® OneTest™ Data are impacted:
  • Projects
  • Schemas
  • Jobs
  • Data files
  • API history
  • Map files
  • Files
  • Connections
  • Actions
If you want to modify the name of your HCL® OneTest™ Data project, then you can rename the project in HCL OneTest™ Server.
Note: When you delete any archived project, then that project is deleted based on the configured job settings.
