Establishing an SAP IDoc or DXOB interface connection with HCL OneTest Data
When you want to generate a schema for an SAP IDoc or DXOB file, you must establish a connection with the SAP IDoc or DXOB interface.
You must have imported the SAP IDoc or DXOB file into your project.
  1. Select your project in Rational® Test Automation Server and navigate to the Data Fabrication page.
  2. Click Connections.
  3. Click New to create a new connection type.
  4. Select SAP IDoc from the Type drop-down list, and then click Next.
  5. Set the following properties under Connection Properties:
    • Enable Bypass Client Connection.
    • Select 2 (Unicode) as Bytes Per Character.
  6. Click Next, and then provide a name to the established connection.
  7. Click OK.
    You can see the name of the SAP IDoc connection under the Connections tab.
You have successfully established the connection between HCL® OneTest™ Data and the SAP IDoc or DXOB interface.
What to do next
You must generate a schema in HCL OneTest Data by using the SAP IDoc or DXOB file. See Generating schema by using an SAP IDoc or DXOB file.
