Data design environment overview
The data design environment is a graphical interface to design all its components and data generation rules to generate test data on user demand. To design the components for data generation, you must log in to Rational® Test Automation Server, and then create a project.
You use various components to structure data in HCL® OneTest™ Data. The components of data design environment are:
  • Files
  • Connections
  • Schemas
The definitions of data stored in the schemas are used to define a map. The map specifies the transformation logic in the form of rules. The map identifies the data definition of a schema, validates the type properties of data by using rules, and compiles the rules to generate the real-time test data.
You can refer to workspace management to manage workspace in HCL® OneTest™ Data.
