HCL BigFix Cloud Lifecycle Management Features
‘Self Service Catalog’ based Provisioning and Auto-decommissioning:
Self Service Catalog based Provisioning & Auto-decommissioning– Provisioning of IaaS, PaaS, and multi-machine blueprints in a multi-cloud environment, through an intuitive self-service catalog and auto-decommissioning post a defined interval to avoid cost leakages.
Metering & Show back:
Track utilization of resources across BUs, enabling transparency and visibility.
Dynamic User interface:
Flexibility to customize the service request form templates to capture configuration parameters while placing provisioning requests.
Dynamic Process Workflows:
Enables automation of generic & custom tasks like installing agents, machine cloning etc. with support for parallel execution.
Script Library:
Creates new or leverage out-of-the-box scripts in process workflows across environments.
Forecasting & RI recommendation:
Enables cost optimization and resource utilization by analyzing the past usage patterns & recommending the most optimal resource types on AWS and Azure.
Role Based Access Control:
Manages user privileges based on their roles, eligibility, and policies.
Policy driven Orchestration:
Be in control of your cloud orchestration ecosystem aligned to your organizational policies.
Rich Integration Ecosystem:
Enables integration with industry leading third party tools through REST APIs and CLI.
Enterprise-Grade Security:
Ensures security of end-to-end cloud management and orchestration ecosystem through various mechanisms.
