GetScvmmNetwork (Hyper V2 Network))
This method is used to return the list of Hyper V2 network (Hyper 2012) in HCL BigFix CLM.
Method Signature:
GetScvmmNetwork(cloudName, hostName, controlId, async, servicePlanId, callback, addlparam)
Sample Response:
 [{"ActualIDOnEnvironment":"20748a05-8223-419a-a248-8c29c7249bd3","Name":"VMNetwork",
"EntityID":"NTW-0D77B629-0B99-4766-A9F3-55B088122640","text":"VMNetwork"}]
Parameter Details:
Table 1. GetScvmmNetwork
Parameter Name Type Mandatory Description
cloudName String Y User has to pass cloud name, then details of passed cloud are returned.
hostName String Y User has to pass host name, then details of passed cloud are returned.
controlId String N
Id of ‘Select’ control to be populated.
If Id Control of dynamic UI is passed, then control will be populated with values return from this function else “Result set” will be returned in JSON format.
async Boolean N
In case it’s False:
Function will be called in synchronous mode. i.e., Current execution will wait for method execution to complete
In case it’s True:
Function will be called asynchronously. Execution will not wait for method execution completion. It will jump to next statement.
servicePlanId String N Service Plan ID is a plan related to cost model created by provider and map to the resource in HCL BigFix CLM.
callback Function N User can pass function name that can be executed on completion of Parent function call.
addlparam Object N
Addlparam is used for filtering and sorting the records. It contains 3 properties filter/sortby/sortorder.
To Filter:
To filter records based on column name received from output. e.g., filter="keyname='keyvalue'"
To Sort by:
To sort the data based on column name. e.g., sortby="keyname"
To Sort Order:
To define sorting order either ASC (Ascending) or DESC (descending). e.g., sortorder="ASC”
