GetCustomTableRecordwithfilters
This custom table records function is available on intellisense location MCLD.Functions.CustomTables.GetCustomTableRecords.
Method Signature:
GetCustomTableRecords (tableName, async, callback, addparam, camelCase)
Sample Response:
'{"totalRecords":4,"records":[{"autoId":"1","workflowName":"Create workflow","executionMoid":"xxx"},
{"autoId":"2","workflowName":"Delete Workflow","executionMoid":"xxxxx"},
{"autoId":"3","workflowName":"Test","executionMoid":""},{"autoId":"4","workflowName":"","executionMoid":"1"}]}'
Parameter Details:
| Parameter Name | Type | Mandatory | Description |
| Table Name | String | Y | User must pass the Table Name which are visible under Master> Custom table menu. |
| Async | Boolean | N |
In case it’s False: Function will be called in synchronous mode. i.e. Current execution will wait for method execution to complete In case it’s True: Function will be called asynchronously. Execution will not wait for method execution completion. It will jump to next statement. |
| Callback | Function | N | User can pass function name that can be executed on completion of Parent function call. |
| addlparam | Object | N |
Addlparam is used for filtering and sorting the records. It contains 3 properties filter/sortby/sortorder. To Filter: To filter records based on column name received from output. e.g., filter="keyname='keyvalue'" To Sort by: To sort the data based on column name. e.g., sortby="keyname" To Sort Order: To define sorting order either ASC (Ascending) or DESC (descending). e.g., sortorder="ASC” |
| camelCase | Boolean | N | Convert custom table column casing. If true custom table column will be converted to camel case else it will be returned as it is. Default value is true. |
